1 Reply Latest reply on Jul 20, 2016 8:19 AM by kerrishotts
    Crosswalk lite not support by Cordova/Phonegap
    appitoolv
      I try the following plugin by building locally but it does not work.
      Crosswalk Lite support in phonegap build
      Cordova version is 6.2, Crosswalk version is 1.7 and 1.8 and android version is 5.1.1.
      I added plugin by typing 'cordova plugin add cordova-plugin-crosswalk-webview@1.7.0 --variable XWALK_MODE="lite" and cordova-plugin-crosswalk-webview --variable XWALK_MODE="lite".
      I built Apps by typing 'cordova build android' and I tried to install the debug apk (about 10M bigger) to Keynote's real device or Genymotion simulators with different Android versions 4.2 - 6.0 but Message 'Decompressing crosswalk project' was showed and then the app was stopped.
      I found this article but useless and also not work in next boot. Customize Crosswalk for Cordova project
      Actually, I use the Crosswalk due to play html 5 audio and video without Media Plugin for Android versions 4 - 6. Also, It gives better performance of JQUERY MOBILE popup transition showing.(less delay). But it produces a big size APP.
