2 Replies Latest reply on Jul 20, 2016 3:48 PM by ryanskihead
    Android Build Failed. XWalkCordova errors in log.
    danielw66507254
      Hello.
      Whenever i try to build my project for android i get the error message:
      Oh geez. Your build failed. Sorry, but a problem occurred on the build server
      Looking at the Log, there are about a hundred errors in Java complication to do with XWalkCordova - mostly in that they do not exist in one form or another.
      I will post the Log at the bottom.
      I appreciate any help at this stage.
      LOG:
      Build Date: 2016-07-20 14:19:30 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-crosswalk-webview" via npm
      Installing "cordova-plugin-crosswalk-webview" at "1.8.0" for android
      Fetching plugin "cordova-plugin-whitelist" via npm
      Installing "cordova-plugin-whitelist" at "1.2.2" for android
        This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
      COMPILE OUTPUT
      Executing: ant debug -f /project/build.xml
      Buildfile: /project/build.xml
      -check-env:
      [checkenv] Android SDK Tools Revision 25.1.7
      -setup:
        [echo] Project Name: .AsteroidsAhead
        [gettype] Project Type: Application
      -pre-clean:
      clean:
      [getlibpath] Library dependencies:
      [getlibpath]
      [getlibpath] ------------------
      [getlibpath] Ordered libraries:
      -set-mode-check:
      -set-debug-files:
      -check-env:
      -setup:
      -set-debug-mode:
      -debug-obfuscation-check:
      -pre-build:
      -build-setup:
      nodeps:
      -check-env:
      -setup:
        [gettype] Project Type: Android Library
      [getbuildtools] Using latest Build Tools: 23.0.1
      -pre-clean:
      clean:
        [echo] Resolving Build Target for .AsteroidsAhead...
      BUILD SUCCESSFUL
      Total time: 1 second
      [gettarget] Project Target: Android 5.1.1
      [gettarget] API level: 22
        [echo] ----------
        [echo] Creating output directories if needed...
        [mkdir] Created dir: /project/bin
        [mkdir] Created dir: /project/bin/res
        [mkdir] Created dir: /project/bin/rsObj
        [mkdir] Created dir: /project/bin/rsLibs
        [mkdir] Created dir: /project/gen
        [mkdir] Created dir: /project/bin/classes
        [mkdir] Created dir: /project/bin/dexedLibs
        [echo] ----------
        [echo] Resolving Dependencies for .AsteroidsAhead...
      [dependency] Library dependencies:
      [dependency]
      [dependency] ------------------
      [dependency] Ordered libraries:
      [dependency]
        [echo] ----------
        [echo] Building Libraries with 'debug'...
      nodeps:
      -set-mode-check:
      -set-debug-files:
      -check-env:
      -setup:
      -set-debug-mode:
      -pre-build:
      -build-setup:
        [echo] ----------
        [mkdir] Created dir: /project/CordovaLib/res
        [mkdir] Created dir: /project/CordovaLib/libs
        [mkdir] Created dir: /project/CordovaLib/bin
        [mkdir] Created dir: /project/CordovaLib/bin/res
        [mkdir] Created dir: /project/CordovaLib/bin/rsObj
        [mkdir] Created dir: /project/CordovaLib/bin/rsLibs
        [mkdir] Created dir: /project/CordovaLib/gen
        [mkdir] Created dir: /project/CordovaLib/bin/classes
        [mkdir] Created dir: /project/CordovaLib/bin/dexedLibs
        [echo] ----------
      [dependency] No Libraries
      [dependency]
      -code-gen:
      [mergemanifest] Merging AndroidManifest files into one.
      [mergemanifest] Manifest merger disabled. Using project manifest only.
        [echo] Handling aidl files...
        [aidl] No AIDL files to compile.
        [echo] ----------
        [echo] Handling RenderScript files...
        [echo] ----------
        [echo] Handling Resources...
        [aapt] Generating resource IDs...
        [echo] ----------
        [echo] Handling BuildConfig class...
      [buildconfig] Generating BuildConfig class.
      -pre-compile:
      -compile:
        [javac] Compiling 36 source files to /project/CordovaLib/bin/classes
        [javac] Note: Some input files use or override a deprecated API.
        [javac] Note: Recompile with -Xlint:deprecation for details.
        [echo] Creating library output jar file...
        [jar] Building jar: /project/CordovaLib/bin/classes.jar
      -post-compile:
      -obfuscate:
      -dex:
        [echo] Library project: do not convert bytecode...
      -crunch:
        [crunch] Crunching PNG Files in source dir: /project/CordovaLib/res
        [crunch] To destination dir: /project/CordovaLib/bin/res
        [crunch] Crunched 0 PNG files to update cache
      -package-resources:
        [echo] Library project: do not package resources...
      -package:
        [echo] Library project: do not package apk...
      -post-package:
      -do-debug:
        [echo] Library project: do not create apk...
      [propertyfile] Creating new property file: /project/CordovaLib/bin/build.prop
      [propertyfile] Updating property file: /project/CordovaLib/bin/build.prop
      -post-build:
      debug:
      -code-gen:
        [echo] ----------
        [echo] ----------
        [echo] ----------
      -pre-compile:
      -compile:
        [javac] Compiling 12 source files to /project/bin/classes
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaClientCertRequest.java:22: error: package org.xwalk.core does not exist
        [javac] import org.xwalk.core.ClientCertRequest;
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaClientCertRequest.java:31: error: cannot find symbol
        [javac] private final ClientCertRequest request;
        [javac] ^
        [javac] symbol: class ClientCertRequest
        [javac] location: class XWalkCordovaClientCertRequest
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaClientCertRequest.java:33: error: cannot find symbol
        [javac] public XWalkCordovaClientCertRequest(ClientCertRequest request) {
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaCookieManager.java:22: error: package org.xwalk.core does not exist
        [javac] import org.xwalk.core.XWalkCookieManager;
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaCookieManager.java:26: error: cannot find symbol
        [javac] protected XWalkCookieManager cookieManager = null;
        [javac] ^
        [javac] symbol: class XWalkCookieManager
        [javac] location: class XWalkCordovaCookieManager
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaHttpAuthHandler.java:22: error: package org.xwalk.core does not exist
        [javac] import org.xwalk.core.XWalkHttpAuthHandler;
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaHttpAuthHandler.java:30: error: cannot find symbol
        [javac] private final XWalkHttpAuthHandler handler;
        [javac] ^
        [javac] symbol: class XWalkHttpAuthHandler
        [javac] location: class XWalkCordovaHttpAuthHandler
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaHttpAuthHandler.java:32: error: cannot find symbol
        [javac] public XWalkCordovaHttpAuthHandler(XWalkHttpAuthHandler handler) {
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:32: error: package org.xwalk.core does not exist
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:33: error: package org.xwalk.core does not exist
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:34: error: package org.xwalk.core does not exist
        [javac] import org.xwalk.core.XWalkResourceClient;
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:35: error: package org.xwalk.core does not exist
        [javac] import org.xwalk.core.XWalkView;
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:40: error: cannot find symbol
        [javac] public class XWalkCordovaResourceClient extends XWalkResourceClient {
        [javac] ^
        [javac] symbol: class XWalkResourceClient
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:47: error: package org.xwalk.core does not exist
        [javac] import org.xwalk.core.XWalkActivityDelegate;
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:48: error: package org.xwalk.core does not exist
        [javac] import org.xwalk.core.XWalkNavigationHistory;
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:49: error: package org.xwalk.core does not exist
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:50: error: package org.xwalk.core does not exist
        [javac] import org.xwalk.core.XWalkGetBitmapCallback;
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:60: error: cannot find symbol
        [javac] public void onReceivedLoadError(XWalkView view, int errorCode, String description,
        [javac] ^
        [javac] symbol: class XWalkView
        [javac] location: class XWalkCordovaResourceClient
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:68: error: cannot find symbol
        [javac] public WebResourceResponse shouldInterceptLoadRequest(XWalkView view, String url) {
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:98: error: cannot find symbol
        [javac] public boolean shouldOverrideUrlLoading(XWalkView view, String url) {
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:111: error: cannot find symbol
        [javac] public void onReceivedSslError(XWalkView view, ValueCallback<Boolean> callback, SslError error) {
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:132: error: cannot find symbol
        [javac] public void onReceivedHttpAuthRequest(XWalkView view, XWalkHttpAuthHandler handler,
        [javac] ^
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:148: error: cannot find symbol
        [javac] public void onReceivedClientCertRequest(XWalkView view, ClientCertRequest request) {
        [javac] ^
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:4: error: package org.xwalk.core does not exist
        [javac] import org.xwalk.core.XWalkPreferences;
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:5: error: package org.xwalk.core does not exist
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:6: error: package org.xwalk.core does not exist
        [javac] import org.xwalk.core.XWalkUIClient;
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:7: error: package org.xwalk.core does not exist
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:22: error: cannot find symbol
        [javac] public class XWalkCordovaView extends XWalkView implements CordovaWebViewEngine.EngineView {
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:72: error: cannot find symbol
        [javac] protected XWalkActivityDelegate activityDelegate;
        [javac] ^
        [javac] symbol: class XWalkActivityDelegate
        [javac] location: class XWalkWebViewEngine
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:212: error: cannot find symbol
        [javac] private static void exposeJsInterface(XWalkView webView, CordovaBridge bridge) {
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:31: error: package org.xwalk.core does not exist
        [javac] import org.xwalk.core.XWalkJavascriptResult;
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:32: error: package org.xwalk.core does not exist
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:33: error: package org.xwalk.core does not exist
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:35: error: cannot find symbol
        [javac] public class XWalkCordovaUiClient extends XWalkUIClient {
        [javac] ^
        [javac] symbol: class XWalkUIClient
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:73: error: cannot find symbol
        [javac] public void setResourceClient(XWalkResourceClient client) {
        [javac] ^
        [javac] location: class XWalkCordovaView
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:82: error: cannot find symbol
        [javac] public void setUIClient(XWalkUIClient client) {
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:49: error: cannot find symbol
        [javac] public boolean onJavascriptModalDialog(XWalkView view, JavascriptMessageType type, String url,
        [javac] ^
        [javac] location: class XWalkCordovaUiClient
        [javac] ^
        [javac] symbol: class JavascriptMessageType
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:50: error: cannot find symbol
        [javac] String message, String defaultValue, XWalkJavascriptResult result) {
        [javac] ^
        [javac] symbol: class XWalkJavascriptResult
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:71: error: cannot find symbol
        [javac] public boolean onJsAlert(XWalkView view, String url, String message,
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:72: error: cannot find symbol
        [javac] final XWalkJavascriptResult result) {
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:89: error: cannot find symbol
        [javac] public boolean onJsConfirm(XWalkView view, String url, String message,
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:90: error: cannot find symbol
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:112: error: cannot find symbol
        [javac] public boolean onJsPrompt(XWalkView view, String origin, String message, String defaultValue,
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:113: error: cannot find symbol
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:144: error: cannot find symbol
        [javac] public void onPageLoadStarted(XWalkView view, String url) {
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:162: error: cannot find symbol
        [javac] public void onPageLoadStopped(XWalkView view, String url, LoadStatus status) {
        [javac] ^
        [javac] ^
        [javac] symbol: class LoadStatus
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:174: error: cannot find symbol
        [javac] public void openFileChooser(XWalkView view, final ValueCallback<Uri> uploadFile, String acceptType, String capture) {
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkExposedJsApi.java:26: error: package org.xwalk.core does not exist
        [javac] import org.xwalk.core.JavascriptInterface;
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkExposedJsApi.java:35: error: cannot find symbol
        [javac] @JavascriptInterface
        [javac] ^
        [javac] symbol: class JavascriptInterface
        [javac] location: class XWalkExposedJsApi
        [javac] /project/src/org/crosswalk/engine/XWalkExposedJsApi.java:43: error: cannot find symbol
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkExposedJsApi.java:48: error: cannot find symbol
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaCookieManager.java:29: error: cannot find symbol
        [javac] cookieManager = new XWalkCookieManager();
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:59: error: method does not override or implement a method from a supertype
        [javac] @Override
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:67: error: method does not override or implement a method from a supertype
        [javac] @Override
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:97: error: method does not override or implement a method from a supertype
        [javac] @Override
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:110: error: method does not override or implement a method from a supertype
        [javac] @Override
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:144: error: cannot find symbol
        [javac] super.onReceivedHttpAuthRequest(view, handler, host, realm);
        [javac] ^
        [javac] symbol: variable super
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:131: error: method does not override or implement a method from a supertype
        [javac] @Override
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:157: error: cannot find symbol
        [javac] super.onReceivedClientCertRequest(view, request);
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:147: error: method does not override or implement a method from a supertype
        [javac] @Override
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:98: error: cannot find symbol
        [javac] XWalkWebViewEngine.this.webView.onNewIntent(intent);
        [javac] ^
        [javac] symbol: method onNewIntent(Intent)
        [javac] location: variable webView of type XWalkCordovaView
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:108: error: cannot find symbol
        [javac] new XWalkGetBitmapCallback() {
        [javac] ^
        [javac] symbol: class XWalkGetBitmapCallback
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:130: error: cannot find symbol
        [javac] webView.load(startUrl, null);
        [javac] ^
        [javac] symbol: method load(String,<null>)
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:134: error: cannot find symbol
        [javac] activityDelegate = new XWalkActivityDelegate((Activity) context, cancelCommand, completeCommand);
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:169: error: cannot find symbol
        [javac] webView.setNetworkAvailable(value);
        [javac] ^
        [javac] symbol: method setNetworkAvailable(boolean)
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:186: error: incompatible types
        [javac] return webView;
        [javac] ^
        [javac] required: View
        [javac] found: XWalkCordovaView
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:190: error: cannot find symbol
        [javac] webView.setVerticalScrollBarEnabled(false);
        [javac] ^
        [javac] symbol: method setVerticalScrollBarEnabled(boolean)
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:193: error: cannot find symbol
        [javac] webView.setZOrderOnTop(zOrderOnTop);
        [javac] ^
        [javac] symbol: method setZOrderOnTop(boolean)
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:198: error: cannot find symbol
        [javac] webView.setUserAgentString(xwalkUserAgent);
        [javac] ^
        [javac] symbol: method setUserAgentString(String)
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:203: error: cannot find symbol
        [javac] webView.setUserAgentString(webView.getUserAgentString() + " " + appendUserAgent);
        [javac] ^
        [javac] symbol: method getUserAgentString()
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:231: error: cannot find symbol
        [javac] webView.getExtensionManager().loadExtension(XWALK_EXTENSIONS_FOLDER + File.separator + path);
        [javac] ^
        [javac] symbol: method getExtensionManager()
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:238: error: cannot find symbol
        [javac] return this.webView.getNavigationHistory().canGoBack();
        [javac] ^
        [javac] symbol: method getNavigationHistory()
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:243: error: cannot find symbol
        [javac] if (this.webView.getNavigationHistory().canGoBack()) {
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:244: error: package XWalkNavigationHistory does not exist
        [javac] this.webView.getNavigationHistory().navigate(XWalkNavigationHistory.Direction.BACKWARD, 1);
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:244: error: cannot find symbol
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:257: error: cannot find symbol
        [javac] webView.resumeTimers();
        [javac] ^
        [javac] symbol: method resumeTimers()
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:264: error: cannot find symbol
        [javac] webView.onDestroy();
        [javac] ^
        [javac] symbol: method onDestroy()
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:270: error: cannot find symbol
        [javac] this.webView.getNavigationHistory().clear();
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:276: error: cannot find symbol
        [javac] this.webView.stopLoading();
        [javac] ^
        [javac] symbol: method stopLoading()
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:282: error: cannot find symbol
        [javac] webView.clearCache(true);
        [javac] ^
        [javac] symbol: method clearCache(boolean)
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:288: error: cannot find symbol
        [javac] return this.webView.getUrl();
        [javac] ^
        [javac] symbol: method getUrl()
        [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:302: error: cannot find symbol
        [javac] webView.load(url, null);
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:44: error: cannot find symbol
        [javac] XWalkPreferences.setValue(XWalkPreferences.ANIMATABLE_XWALK_VIEW, prefAnimatable || manifestAnimatable);
        [javac] ^
        [javac] symbol: variable XWalkPreferences
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:46: error: cannot find symbol
        [javac] XWalkPreferences.setValue(XWalkPreferences.REMOTE_DEBUGGING, true);
        [javac] ^
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:48: error: cannot find symbol
        [javac] XWalkPreferences.setValue(XWalkPreferences.JAVASCRIPT_CAN_OPEN_WINDOW, true);
        [javac] ^
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:49: error: cannot find symbol
        [javac] XWalkPreferences.setValue(XWalkPreferences.ALLOW_UNIVERSAL_ACCESS_FROM_FILE, true);
        [javac] ^
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:64: error: bad operand types for binary operator '=='
        [javac] if (resourceClient == null) {
        [javac] ^
        [javac] first type: XWalkCordovaResourceClient
        [javac] second type: <null>
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:67: error: bad operand types for binary operator '=='
        [javac] if (uiClient == null) {
        [javac] ^
        [javac] first type: XWalkCordovaUiClient
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:78: error: cannot find symbol
        [javac] super.setResourceClient(client);
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:72: error: method does not override or implement a method from a supertype
        [javac] @Override
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:87: error: cannot find symbol
        [javac] super.setUIClient(client);
        [javac] ^
        [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:81: error: method does not override or implement a method from a supertype
        [javac] @Override
        [javac] ^
        [javac] 100 errors
      BUILD FAILED
      /android-sdk/tools/ant/build.xml:716: The following error occurred while executing this line:
      /android-sdk/tools/ant/build.xml:730: Compile failed; see the compiler error output for details.
      Total time: 5 seconds
      /project/cordova/node_modules/q/q.js:126
        throw e;
      Error code 1 for command: ant with args: debug,-f,/project/build.xml
      Build Date: 2016-07-20 14:19:30 +0000 -------------------------------------------------------------------------------- PLUGIN OUTPUT -------------------------------------------------------------------------------- Fetching plugin "cordova-plugin-crosswalk-webview" via npm Installing "cordova-plugin-crosswalk-webview" at "1.8.0" for android Fetching plugin "cordova-plugin-whitelist" via npm Installing "cordova-plugin-whitelist" at "1.2.2" for android                 This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in. -------------------------------------------------------------------------------- COMPILE OUTPUT -------------------------------------------------------------------------------- Executing: ant debug -f /project/build.xml Buildfile: /project/build.xml Buildfile: /project/build.xml  -check-env:  [checkenv] Android SDK Tools Revision 25.1.7  -setup:      [echo] Project Name: .AsteroidsAhead   [gettype] Project Type: Application  -pre-clean:  clean: [getlibpath] Library dependencies: [getlibpath]  [getlibpath] ------------------ [getlibpath] Ordered libraries:  -set-mode-check:  -set-debug-files:  -check-env:  [checkenv] Android SDK Tools Revision 25.1.7  -setup:      [echo] Project Name: .AsteroidsAhead   [gettype] Project Type: Application  -set-debug-mode:  -debug-obfuscation-check:  -pre-build:  -build-setup:  nodeps:  -check-env:  [checkenv] Android SDK Tools Revision 25.1.7  -setup:      [echo] Project Name: .AsteroidsAhead   [gettype] Project Type: Android Library [getbuildtools] Using latest Build Tools: 23.0.1  -pre-clean:  clean:      [echo] Resolving Build Target for .AsteroidsAhead...  BUILD SUCCESSFUL Total time: 1 second [gettarget] Project Target:   Android 5.1.1 [gettarget] API level:        22      [echo] ----------      [echo] Creating output directories if needed...     [mkdir] Created dir: /project/bin     [mkdir] Created dir: /project/bin/res     [mkdir] Created dir: /project/bin/rsObj     [mkdir] Created dir: /project/bin/rsLibs     [mkdir] Created dir: /project/gen     [mkdir] Created dir: /project/bin/classes     [mkdir] Created dir: /project/bin/dexedLibs      [echo] ----------      [echo] Resolving Dependencies for .AsteroidsAhead... [dependency] Library dependencies: [dependency]  [dependency] ------------------ [dependency] Ordered libraries: [dependency]  [dependency] ------------------      [echo] ----------      [echo] Building Libraries with 'debug'...  nodeps:  -set-mode-check:  -set-debug-files:  -check-env:  [checkenv] Android SDK Tools Revision 25.1.7  -setup:      [echo] Project Name: .AsteroidsAhead   [gettype] Project Type: Android Library  -set-debug-mode:  -debug-obfuscation-check:  -pre-build:  -build-setup: [getbuildtools] Using latest Build Tools: 23.0.1      [echo] Resolving Build Target for .AsteroidsAhead... [gettarget] Project Target:   Android 5.1.1 [gettarget] API level:        22      [echo] ----------      [echo] Creating output directories if needed...     [mkdir] Created dir: /project/CordovaLib/res     [mkdir] Created dir: /project/CordovaLib/libs     [mkdir] Created dir: /project/CordovaLib/bin     [mkdir] Created dir: /project/CordovaLib/bin/res     [mkdir] Created dir: /project/CordovaLib/bin/rsObj     [mkdir] Created dir: /project/CordovaLib/bin/rsLibs     [mkdir] Created dir: /project/CordovaLib/gen     [mkdir] Created dir: /project/CordovaLib/bin/classes     [mkdir] Created dir: /project/CordovaLib/bin/dexedLibs      [echo] ----------      [echo] Resolving Dependencies for .AsteroidsAhead... [dependency] Library dependencies: [dependency] No Libraries [dependency]  [dependency] ------------------  -code-gen: [mergemanifest] Merging AndroidManifest files into one. [mergemanifest] Manifest merger disabled. Using project manifest only.      [echo] Handling aidl files...      [aidl] No AIDL files to compile.      [echo] ----------      [echo] Handling RenderScript files...      [echo] ----------      [echo] Handling Resources...      [aapt] Generating resource IDs...      [echo] ----------      [echo] Handling BuildConfig class... [buildconfig] Generating BuildConfig class.  -pre-compile:  -compile:     [javac] Compiling 36 source files to /project/CordovaLib/bin/classes     [javac] Note: Some input files use or override a deprecated API.     [javac] Note: Recompile with -Xlint:deprecation for details.      [echo] Creating library output jar file...       [jar] Building jar: /project/CordovaLib/bin/classes.jar  -post-compile:  -obfuscate:  -dex:      [echo] Library project: do not convert bytecode...  -crunch:    [crunch] Crunching PNG Files in source dir: /project/CordovaLib/res    [crunch] To destination dir: /project/CordovaLib/bin/res    [crunch] Crunched 0 PNG files to update cache  -package-resources:      [echo] Library project: do not package resources...  -package:      [echo] Library project: do not package apk...  -post-package:  -do-debug:      [echo] Library project: do not create apk... [propertyfile] Creating new property file: /project/CordovaLib/bin/build.prop [propertyfile] Updating property file: /project/CordovaLib/bin/build.prop [propertyfile] Updating property file: /project/CordovaLib/bin/build.prop [propertyfile] Updating property file: /project/CordovaLib/bin/build.prop  -post-build:  debug:  -code-gen: [mergemanifest] Merging AndroidManifest files into one. [mergemanifest] Manifest merger disabled. Using project manifest only.      [echo] Handling aidl files...      [aidl] No AIDL files to compile.      [echo] ----------      [echo] Handling RenderScript files...      [echo] ----------      [echo] Handling Resources...      [aapt] Generating resource IDs...      [echo] ----------      [echo] Handling BuildConfig class... [buildconfig] Generating BuildConfig class.  -pre-compile:  -compile:     [javac] Compiling 12 source files to /project/bin/classes     [javac] /project/src/org/crosswalk/engine/XWalkCordovaClientCertRequest.java:22: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.ClientCertRequest;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaClientCertRequest.java:31: error: cannot find symbol     [javac]     private final ClientCertRequest request;     [javac]                   ^     [javac]   symbol:   class ClientCertRequest     [javac]   location: class XWalkCordovaClientCertRequest     [javac] /project/src/org/crosswalk/engine/XWalkCordovaClientCertRequest.java:33: error: cannot find symbol     [javac]     public XWalkCordovaClientCertRequest(ClientCertRequest request) {     [javac]                                          ^     [javac]   symbol:   class ClientCertRequest     [javac]   location: class XWalkCordovaClientCertRequest     [javac] /project/src/org/crosswalk/engine/XWalkCordovaCookieManager.java:22: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkCookieManager;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaCookieManager.java:26: error: cannot find symbol     [javac]     protected XWalkCookieManager cookieManager = null;     [javac]               ^     [javac]   symbol:   class XWalkCookieManager     [javac]   location: class XWalkCordovaCookieManager     [javac] /project/src/org/crosswalk/engine/XWalkCordovaHttpAuthHandler.java:22: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkHttpAuthHandler;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaHttpAuthHandler.java:30: error: cannot find symbol     [javac]     private final XWalkHttpAuthHandler handler;     [javac]                   ^     [javac]   symbol:   class XWalkHttpAuthHandler     [javac]   location: class XWalkCordovaHttpAuthHandler     [javac] /project/src/org/crosswalk/engine/XWalkCordovaHttpAuthHandler.java:32: error: cannot find symbol     [javac]     public XWalkCordovaHttpAuthHandler(XWalkHttpAuthHandler handler) {     [javac]                                        ^     [javac]   symbol:   class XWalkHttpAuthHandler     [javac]   location: class XWalkCordovaHttpAuthHandler     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:32: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.ClientCertRequest;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:33: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkHttpAuthHandler;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:34: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkResourceClient;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:35: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkView;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:40: error: cannot find symbol     [javac] public class XWalkCordovaResourceClient extends XWalkResourceClient {     [javac]                                                 ^     [javac]   symbol: class XWalkResourceClient     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:47: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkActivityDelegate;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:48: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkNavigationHistory;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:49: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkView;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:50: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkGetBitmapCallback;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:60: error: cannot find symbol     [javac]     public void onReceivedLoadError(XWalkView view, int errorCode, String description,     [javac]                                     ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkCordovaResourceClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:68: error: cannot find symbol     [javac]     public WebResourceResponse shouldInterceptLoadRequest(XWalkView view, String url) {     [javac]                                                           ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkCordovaResourceClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:98: error: cannot find symbol     [javac]     public boolean shouldOverrideUrlLoading(XWalkView view, String url) {     [javac]                                             ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkCordovaResourceClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:111: error: cannot find symbol     [javac]     public void onReceivedSslError(XWalkView view, ValueCallback<Boolean> callback, SslError error) {     [javac]                                    ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkCordovaResourceClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:132: error: cannot find symbol     [javac]     public void onReceivedHttpAuthRequest(XWalkView view, XWalkHttpAuthHandler handler,     [javac]                                           ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkCordovaResourceClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:132: error: cannot find symbol     [javac]     public void onReceivedHttpAuthRequest(XWalkView view, XWalkHttpAuthHandler handler,     [javac]                                                           ^     [javac]   symbol:   class XWalkHttpAuthHandler     [javac]   location: class XWalkCordovaResourceClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:148: error: cannot find symbol     [javac]     public void onReceivedClientCertRequest(XWalkView view, ClientCertRequest request) {     [javac]                                             ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkCordovaResourceClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:148: error: cannot find symbol     [javac]     public void onReceivedClientCertRequest(XWalkView view, ClientCertRequest request) {     [javac]                                                             ^     [javac]   symbol:   class ClientCertRequest     [javac]   location: class XWalkCordovaResourceClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:4: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkPreferences;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:5: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkResourceClient;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:6: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkUIClient;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:7: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkView;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:22: error: cannot find symbol     [javac] public class XWalkCordovaView extends XWalkView implements CordovaWebViewEngine.EngineView {     [javac]                                       ^     [javac]   symbol: class XWalkView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:72: error: cannot find symbol     [javac]     protected XWalkActivityDelegate activityDelegate;     [javac]               ^     [javac]   symbol:   class XWalkActivityDelegate     [javac]   location: class XWalkWebViewEngine     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:212: error: cannot find symbol     [javac]     private static void exposeJsInterface(XWalkView webView, CordovaBridge bridge) {     [javac]                                           ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkWebViewEngine     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:31: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkJavascriptResult;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:32: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkUIClient;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:33: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.XWalkView;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:35: error: cannot find symbol     [javac] public class XWalkCordovaUiClient extends XWalkUIClient {     [javac]                                           ^     [javac]   symbol: class XWalkUIClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:73: error: cannot find symbol     [javac]     public void setResourceClient(XWalkResourceClient client) {     [javac]                                   ^     [javac]   symbol:   class XWalkResourceClient     [javac]   location: class XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:82: error: cannot find symbol     [javac]     public void setUIClient(XWalkUIClient client) {     [javac]                             ^     [javac]   symbol:   class XWalkUIClient     [javac]   location: class XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:49: error: cannot find symbol     [javac]     public boolean onJavascriptModalDialog(XWalkView view, JavascriptMessageType type, String url,     [javac]                                            ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkCordovaUiClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:49: error: cannot find symbol     [javac]     public boolean onJavascriptModalDialog(XWalkView view, JavascriptMessageType type, String url,     [javac]                                                            ^     [javac]   symbol:   class JavascriptMessageType     [javac]   location: class XWalkCordovaUiClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:50: error: cannot find symbol     [javac]                                            String message, String defaultValue, XWalkJavascriptResult result) {     [javac]        ^     [javac]   symbol:   class XWalkJavascriptResult     [javac]   location: class XWalkCordovaUiClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:71: error: cannot find symbol     [javac]     public boolean onJsAlert(XWalkView view, String url, String message,     [javac]                              ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkCordovaUiClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:72: error: cannot find symbol     [javac]                               final XWalkJavascriptResult result) {     [javac]                                     ^     [javac]   symbol:   class XWalkJavascriptResult     [javac]   location: class XWalkCordovaUiClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:89: error: cannot find symbol     [javac]     public boolean onJsConfirm(XWalkView view, String url, String message,     [javac]                                ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkCordovaUiClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:90: error: cannot find symbol     [javac]                                 final XWalkJavascriptResult result) {     [javac]                                       ^     [javac]   symbol:   class XWalkJavascriptResult     [javac]   location: class XWalkCordovaUiClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:112: error: cannot find symbol     [javac]     public boolean onJsPrompt(XWalkView view, String origin, String message, String defaultValue,     [javac]                               ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkCordovaUiClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:113: error: cannot find symbol     [javac]                                final XWalkJavascriptResult result) {     [javac]                                      ^     [javac]   symbol:   class XWalkJavascriptResult     [javac]   location: class XWalkCordovaUiClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:144: error: cannot find symbol     [javac]     public void onPageLoadStarted(XWalkView view, String url) {     [javac]                                   ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkCordovaUiClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:162: error: cannot find symbol     [javac]     public void onPageLoadStopped(XWalkView view, String url, LoadStatus status) {     [javac]                                   ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkCordovaUiClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:162: error: cannot find symbol     [javac]     public void onPageLoadStopped(XWalkView view, String url, LoadStatus status) {     [javac]                                                               ^     [javac]   symbol:   class LoadStatus     [javac]   location: class XWalkCordovaUiClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaUiClient.java:174: error: cannot find symbol     [javac]     public void openFileChooser(XWalkView view, final ValueCallback<Uri> uploadFile, String acceptType, String capture) {     [javac]                                 ^     [javac]   symbol:   class XWalkView     [javac]   location: class XWalkCordovaUiClient     [javac] /project/src/org/crosswalk/engine/XWalkExposedJsApi.java:26: error: package org.xwalk.core does not exist     [javac] import org.xwalk.core.JavascriptInterface;     [javac]                      ^     [javac] /project/src/org/crosswalk/engine/XWalkExposedJsApi.java:35: error: cannot find symbol     [javac]     @JavascriptInterface     [javac]      ^     [javac]   symbol:   class JavascriptInterface     [javac]   location: class XWalkExposedJsApi     [javac] /project/src/org/crosswalk/engine/XWalkExposedJsApi.java:43: error: cannot find symbol     [javac]     @JavascriptInterface     [javac]      ^     [javac]   symbol:   class JavascriptInterface     [javac]   location: class XWalkExposedJsApi     [javac] /project/src/org/crosswalk/engine/XWalkExposedJsApi.java:48: error: cannot find symbol     [javac]     @JavascriptInterface     [javac]      ^     [javac]   symbol:   class JavascriptInterface     [javac]   location: class XWalkExposedJsApi     [javac] /project/src/org/crosswalk/engine/XWalkCordovaCookieManager.java:29: error: cannot find symbol     [javac]         cookieManager = new XWalkCookieManager();     [javac]                             ^     [javac]   symbol:   class XWalkCookieManager     [javac]   location: class XWalkCordovaCookieManager     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:59: error: method does not override or implement a method from a supertype     [javac]     @Override     [javac]     ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:67: error: method does not override or implement a method from a supertype     [javac]     @Override     [javac]     ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:97: error: method does not override or implement a method from a supertype     [javac]     @Override     [javac]     ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:110: error: method does not override or implement a method from a supertype     [javac]     @Override     [javac]     ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:144: error: cannot find symbol     [javac]         super.onReceivedHttpAuthRequest(view, handler, host, realm);     [javac]         ^     [javac]   symbol:   variable super     [javac]   location: class XWalkCordovaResourceClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:131: error: method does not override or implement a method from a supertype     [javac]     @Override     [javac]     ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:157: error: cannot find symbol     [javac]         super.onReceivedClientCertRequest(view, request);     [javac]         ^     [javac]   symbol:   variable super     [javac]   location: class XWalkCordovaResourceClient     [javac] /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java:147: error: method does not override or implement a method from a supertype     [javac]     @Override     [javac]     ^     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:98: error: cannot find symbol     [javac]                         XWalkWebViewEngine.this.webView.onNewIntent(intent);     [javac]                                                        ^     [javac]   symbol:   method onNewIntent(Intent)     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:108: error: cannot find symbol     [javac]                                             new XWalkGetBitmapCallback() {     [javac]                                                 ^     [javac]   symbol: class XWalkGetBitmapCallback     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:130: error: cannot find symbol     [javac]                     webView.load(startUrl, null);     [javac]                            ^     [javac]   symbol:   method load(String,<null>)     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:134: error: cannot find symbol     [javac]         activityDelegate = new XWalkActivityDelegate((Activity) context, cancelCommand, completeCommand);     [javac]                                ^     [javac]   symbol:   class XWalkActivityDelegate     [javac]   location: class XWalkWebViewEngine     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:169: error: cannot find symbol     [javac]                 webView.setNetworkAvailable(value);     [javac]                        ^     [javac]   symbol:   method setNetworkAvailable(boolean)     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:186: error: incompatible types     [javac]         return webView;     [javac]                ^     [javac]   required: View     [javac]   found:    XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:190: error: cannot find symbol     [javac]         webView.setVerticalScrollBarEnabled(false);     [javac]                ^     [javac]   symbol:   method setVerticalScrollBarEnabled(boolean)     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:193: error: cannot find symbol     [javac]         webView.setZOrderOnTop(zOrderOnTop);     [javac]                ^     [javac]   symbol:   method setZOrderOnTop(boolean)     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:198: error: cannot find symbol     [javac]             webView.setUserAgentString(xwalkUserAgent);     [javac]                    ^     [javac]   symbol:   method setUserAgentString(String)     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:203: error: cannot find symbol     [javac]             webView.setUserAgentString(webView.getUserAgentString() + " " + appendUserAgent);     [javac]                                               ^     [javac]   symbol:   method getUserAgentString()     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:231: error: cannot find symbol     [javac]             webView.getExtensionManager().loadExtension(XWALK_EXTENSIONS_FOLDER + File.separator + path);     [javac]                    ^     [javac]   symbol:   method getExtensionManager()     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:238: error: cannot find symbol     [javac]         return this.webView.getNavigationHistory().canGoBack();     [javac]                            ^     [javac]   symbol:   method getNavigationHistory()     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:243: error: cannot find symbol     [javac]         if (this.webView.getNavigationHistory().canGoBack()) {     [javac]                         ^     [javac]   symbol:   method getNavigationHistory()     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:244: error: package XWalkNavigationHistory does not exist     [javac]             this.webView.getNavigationHistory().navigate(XWalkNavigationHistory.Direction.BACKWARD, 1);     [javac]        ^     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:244: error: cannot find symbol     [javac]             this.webView.getNavigationHistory().navigate(XWalkNavigationHistory.Direction.BACKWARD, 1);     [javac]                         ^     [javac]   symbol:   method getNavigationHistory()     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:257: error: cannot find symbol     [javac]             webView.resumeTimers();     [javac]                    ^     [javac]   symbol:   method resumeTimers()     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:264: error: cannot find symbol     [javac]         webView.onDestroy();     [javac]                ^     [javac]   symbol:   method onDestroy()     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:270: error: cannot find symbol     [javac]         this.webView.getNavigationHistory().clear();     [javac]                     ^     [javac]   symbol:   method getNavigationHistory()     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:276: error: cannot find symbol     [javac]         this.webView.stopLoading();     [javac]                     ^     [javac]   symbol:   method stopLoading()     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:282: error: cannot find symbol     [javac]         webView.clearCache(true);     [javac]                ^     [javac]   symbol:   method clearCache(boolean)     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:288: error: cannot find symbol     [javac]         return this.webView.getUrl();     [javac]                            ^     [javac]   symbol:   method getUrl()     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:302: error: cannot find symbol     [javac]         webView.load(url, null);     [javac]                ^     [javac]   symbol:   method load(String,<null>)     [javac]   location: variable webView of type XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:44: error: cannot find symbol     [javac]             XWalkPreferences.setValue(XWalkPreferences.ANIMATABLE_XWALK_VIEW, prefAnimatable || manifestAnimatable);     [javac]                                       ^     [javac]   symbol:   variable XWalkPreferences     [javac]   location: class XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:44: error: cannot find symbol     [javac]             XWalkPreferences.setValue(XWalkPreferences.ANIMATABLE_XWALK_VIEW, prefAnimatable || manifestAnimatable);     [javac]             ^     [javac]   symbol:   variable XWalkPreferences     [javac]   location: class XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:46: error: cannot find symbol     [javac]                 XWalkPreferences.setValue(XWalkPreferences.REMOTE_DEBUGGING, true);     [javac]                                           ^     [javac]   symbol:   variable XWalkPreferences     [javac]   location: class XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:46: error: cannot find symbol     [javac]                 XWalkPreferences.setValue(XWalkPreferences.REMOTE_DEBUGGING, true);     [javac]                 ^     [javac]   symbol:   variable XWalkPreferences     [javac]   location: class XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:48: error: cannot find symbol     [javac]             XWalkPreferences.setValue(XWalkPreferences.JAVASCRIPT_CAN_OPEN_WINDOW, true);     [javac]                                       ^     [javac]   symbol:   variable XWalkPreferences     [javac]   location: class XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:48: error: cannot find symbol     [javac]             XWalkPreferences.setValue(XWalkPreferences.JAVASCRIPT_CAN_OPEN_WINDOW, true);     [javac]             ^     [javac]   symbol:   variable XWalkPreferences     [javac]   location: class XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:49: error: cannot find symbol     [javac]             XWalkPreferences.setValue(XWalkPreferences.ALLOW_UNIVERSAL_ACCESS_FROM_FILE, true);     [javac]                                       ^     [javac]   symbol:   variable XWalkPreferences     [javac]   location: class XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:49: error: cannot find symbol     [javac]             XWalkPreferences.setValue(XWalkPreferences.ALLOW_UNIVERSAL_ACCESS_FROM_FILE, true);     [javac]             ^     [javac]   symbol:   variable XWalkPreferences     [javac]   location: class XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:64: error: bad operand types for binary operator '=='     [javac]         if (resourceClient == null) {     [javac]                            ^     [javac]   first type:  XWalkCordovaResourceClient     [javac]   second type: <null>     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:67: error: bad operand types for binary operator '=='     [javac]         if (uiClient == null) {     [javac]                      ^     [javac]   first type:  XWalkCordovaUiClient     [javac]   second type: <null>     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:78: error: cannot find symbol     [javac]         super.setResourceClient(client);     [javac]         ^     [javac]   symbol:   variable super     [javac]   location: class XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:72: error: method does not override or implement a method from a supertype     [javac]     @Override     [javac]     ^     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:87: error: cannot find symbol     [javac]         super.setUIClient(client);     [javac]         ^     [javac]   symbol:   variable super     [javac]   location: class XWalkCordovaView     [javac] /project/src/org/crosswalk/engine/XWalkCordovaView.java:81: error: method does not override or implement a method from a supertype     [javac]     @Override     [javac]     ^     [javac] 100 errors  BUILD FAILED /android-sdk/tools/ant/build.xml:716: The following error occurred while executing this line: /android-sdk/tools/ant/build.xml:730: Compile failed; see the compiler error output for details.  Total time: 5 seconds  /project/cordova/node_modules/q/q.js:126                     throw e;                     ^ Error code 1 for command: ant with args: debug,-f,/project/build.xml
