21 Replies Latest reply on Jul 26, 2016 4:41 AM by cbishop01
    Adding Highlight to script Or Grep Style?
    cbishop01 Level 2
      Hi
      Is it possible to Add a hightlight to a script?  Basically what i want it to do is Highlight text and the tricky part is that the text changes sizes depending on the size of file we're working on.  Say i want to automatically highlight this "FOR PROFESSIONAL USE ONLY" the way we do it now is Make a underline the like this in the underline options menu: Say my font size is 8, Leading 9.6 (These will always change).
      Weight:  =   9.6
      Offset:  =   -8*.33
      Color = Yellow
      That is the way we do it now.  Can it be scripted or Grep style even that will automatically do this for certain Lines of text only?  And no matter the size of font calculate what it needs to so whether its 2pt, 10pt 100pt etc... it will Highlight the specified text correctly?
      hopefully this is possible..
      Thank you
        • 1. Re: Adding Highlight to script Or Grep Style?
          Trevorׅ Adobe Community Professional
          Hi Chris
          What about applying a conditional text? That would be easy. Then you could just do a manual or scripted find change text to apply the condition.
          Set the condition to print if desired.
          This solution is going to depend on your workflow.
          HTH
          Trevor
          • 2. Re: Adding Highlight to script Or Grep Style?
            cbishop01 Level 2
            I never even knew about Conditional Text.  I'm going to try that today.  Thanks for the Great tip
            • 3. Re: Adding Highlight to script Or Grep Style?
              cbishop01 Level 2
              This actually works just like i'm wanting.  I'm just going to need to try and put it in a script.  Can this be handled with GREP somehow?
              • 4. Re: Adding Highlight to script Or Grep Style?
                Hi
                You don't need to grep just use.
                var doc = app.activeDocument;
                app.findTextPreferences = app.changeTextPreferences = null;
                app.findTextPreferences.findWhat = 'FOR PROFESSIONAL USE ONLY';
                // note the necessary [] around the condition(s)
                app.changeTextPreferences.appliedConditions = [doc.conditions.itemByName('Highlight')]; // Change to correct name
                doc.changeText();
                • 5. Re: Adding Highlight to script Or Grep Style?
                  cbishop01 Level 2
                  This is perfect.  Thank you so so so much.
                  • 6. Re: Adding Highlight to script Or Grep Style?
                    cbishop01 Level 2
                    I'm actually running into a problem here.  It highlights a yellow Greenish color.  WHen i do separations preview it comes out As just yellow but when i export to PDF it comes out 84% yellow and 4% cyan.  Making of course a green color.  Any idea how to keep it Pure Yellow?
                    • 7. Re: Adding Highlight to script Or Grep Style?
                      That's one o the things I meant when I wrote "depends on your workflow"
                      The problem is that the conditional colors are rgb and not cmyk.
                      You need to set the conditions indicatorColor properties as best as you can.
                      • 8. Re: Adding Highlight to script Or Grep Style?
                        cbishop01 Level 2
                        is there anyway to convert them to CMYK that you know of? the code i'm using to indicate the color is
                        colorToHighlig = doc.conditions.add ({name:"Highlight",indicatorMethod:ConditionIndicatorMethod.USE_HIGHLIGHT, indicatorColor:UIColors.YELLOW});
                        When i tried Y=100 it of course does not work.
                        • 9. Re: Adding Highlight to script Or Grep Style?
                          Create a cmyk swatch then convert it to rgb to get the rgn values
                          I think the need to be in an array of 3 values up to 255
                          Another way to do it is do a scripted find text and apply a yellow strikethrough line to the finds of the leading thickness in points of the characters
                          I can't post any code for that now but it's dead easy stuff and that way you won't get any cmyk problems
                          You could try the same idea with underline
                          Best of luck
                          • 10. Re: Adding Highlight to script Or Grep Style?
                            cbishop01 Level 2
                            I've added a custom Yellow C=0 M=0 Y=100 K=0 to my Colors In the Conditional Text that is in CMYK.  Thought i was onto something but it showed up as more green .  Darn.  I'll try the scripting here soon.  Because this Would Be great if the Conditional Text would just work the way i want it to..
                            • 11. Re: Adding Highlight to script Or Grep Style?
                              Obi-wan Kenobi Level 5
                              Chris,
                              Imho, it's a simple question for PitStop!
                              Here, 2 samples of a "Yellow" condition converted to Cyan 50%!
                              As you can see, the "Yellow" color is:  C6  M0  Y87  N0
                              In fact, not true, the real values are given by the PitStop Inspector:  C5.8  M0  Y86.8  N0
                              Using PitStop, I just decide to convert the color:  C5.8  M0  Y86.8  N0  to the color:  C50  M0  Y0  N0  [for sample]
                              1 click!    [ I could save the action and play it for other pdf exported from ID using this "Yellow" condition! ]
                              • 12. Re: Adding Highlight to script Or Grep Style?
                                cbishop01 Level 2
                                The down side to this is that we would have to do this with all our PDF's which in our case is thousands a month.
                                • 13. Re: Adding Highlight to script Or Grep Style?
                                  Working on something now, will post it in a few minutes.
                                  • 14. Re: Adding Highlight to script Or Grep Style?
                                    Hi Chris
                                    Please mark this one as the 'Correct answer'
                                    Read the annotations
                                    I shall try do something with using strike through instead of underline so that one can have the text underlined also
                                    // Highlight function by Trevor
                                    // http://creative-scripts.com
                                    // Custom Scripts for Adobe InDesign, Illustrator and a lot more
                                    // Draft Version 1
                                    // https://forums.adobe.com/message/8898663#8898663
                                    function highlight(what, color) {
                                        var range, s, doc;
                                        doc = app.properties.activeDocument;
                                        if (!doc) {
                                            return 'No Active Document';
                                        s = app.selection && app.selection[0];
                                        range = (s && s.properties.underline !== undefined && s.characters.length) ? s : doc;
                                        app.doScript(f, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, 'Highlight Text');
                                        function f() {
                                            var doc, finds, find, l, leading, pointSize, currentChangeProps;
                                            color = color || app.colors.itemByName('Yellow');
                                            // Store current find change text settings
                                            currentFindTextWhat = app.findTextPreferences.findWhat;
                                            currentChangeProps = app.changeTextPreferences.properties;
                                            // if no what is provided then the current entry in the find text panel will be used
                                            if (what) { app.findTextPreferences.findWhat = what; }
                                            app.changeTextPreferences.changeTo = '';
                                            app.changeTextPreferences.underline = true;
                                            app.changeTextPreferences.underlineColor = color;
                                            finds = range.findText();
                                            range.changeText();
                                            l = finds.length;
                                            while (l--) {
                                                find = finds[l];
                                                leading = find.leading;
                                                pointSize = find.pointSize;
                                                leading = pointSize * find.autoLeading / 100;
                                                find.underlineWeight = leading + 'pt'; // This is presuming that font and leading size is set to points!
                                                find.underlineOffset = (pointSize - leading) * 1.5; // The 1.5 might need tweaking but seems to work well
                                            app.findTextPreferences.findWhat = currentFindTextWhat;
                                            app.changeTextPreferences.properties = currentChangeProps;
                                    ** If text is selected then the "highlighting" is only applied within the selected text                                            **
                                    ** Otherwise the "highlighting" is applied within the whole document                                                               **
                                    ** One could change this to apply to what ever is selected in the Find text document if one wanted to                              **
                                    ** To highlight the word(s) in the find text panel just use highlight(); or highlight(undefined, app.activeDocument.swatches[5]);  **
                                    ** One can use highlight('Foo'); to highlight "foo" and ignore what's in the find text panel                                       **
                                    ** The formating / styles etc. for the find are taken from the find panel                                                          **
                                    ** If one provides a swatch as the second argument highlight(undefined, app.activeDocument.swatches[5]); that swatch will be used  **
                                    ** otherwise yellow will be used        **
                                    highlight();
                                    • 15. Re: Adding Highlight to script Or Grep Style?
                                      Doesn't look like the strike though option is good but the above solution looks like it works well.
                                      Edit:
                                      Just to explain the colors
                                      Yellow is the highlighted color
                                      Blue is a conditional text highlight
                                      Black is selected text
                                      The half blue fred was added after the script was run.
                                      • 16. Re: Adding Highlight to script Or Grep Style?
                                        The below one is a better.
                                        I removes a bug and also if no "what" is provided to the highlight function and there's no entry in the find what of the find text panel and some text is selected then that text will be highlighted.
                                        An idea in the script is that a keyboard short cut can be applied for it and it will get it's info from the find text panel.
                                        So for the meantime change the correct answer to this one
                                        // Beta Version 1
                                            var range, s, doc;
                                            if (!doc) {
                                            function f() {
                                                var finds, find, l, leading, pointSize, currentChangeProps;
                                                color = color || app.activeDocument.colors.itemByName('Yellow');
                                                what = what || currentFindTextWhat;
                                                if (what !== '') {
                                                    range.changeText();
                                                    l = finds.length;
                                                    while (l--) {
                                                        find = finds[l];
                                                } else if (range !== app.activeDocument) {
                                                    leading = range.leading;
                                                    pointSize = range.pointSize;
                                                    leading = pointSize * range.autoLeading / 100;
                                                    range.underline = true;
                                                    range.underlineColor = color;
                                                    range.underlineWeight = leading + 'pt'; // This is presuming that font and leading size is set to points!
                                                    range.underlineOffset = (pointSize - leading) * 1.5; // The 1.5 might need tweaking but seems to work well
                                        ** If text is selected and what argument is given and the find what in the find panel is empty then the selected text is highlighted **
                                        highlight();
                                        • 17. Re: Adding Highlight to script Or Grep Style?
                                          Hi Trevor,
                                          Very smart and very cool!
                                          Would it not be more interesting to play it with find/change-Grep and grep styles to keep the para styles pure?
                                          It could be problematic if text already underlined!
                                          • 18. Re: Adding Highlight to script Or Grep Style?
                                            cbishop01 Level 2
                                            My Friend this is awesome.  Thank you so much.  I'm just going to play around and see if i can get this to automatically highlight my text (For Professional Use)(For Professional use Not to be sold seperatlely.) etc.  In my case as stated in the code i had to adjust the 1.5 a little but not too much.  Below is what i'm trying to get it to Automatically Highlight My text.
                                            currentFindTextWhat = app.findTextPreferences.findWhat = 'FOR PROFESSIONAL USE ONLY-NOT INTENDED FOR HOUSEHOLD USE.', 'POUR USAGE PROFESSIONNEL SEULEMENT - NON DESTINÉ À L’USAGE DOMESTIQUE.';
                                            will i need to have several different app.findTextPreferences.findWhat= statements?
                                            • 19. Re: Adding Highlight to script Or Grep Style?
                                              cbishop01 Level 2
                                              I've also tried this.  It only does the First findWhat.  So i think i might be on the right track since it kinda works?
                                               var finds, find, l, leading, pointSize, currentChangeProps, currentChangeProps1, currentChangeProps2;
                                                          app.findTextPreferences.findWhat = 'POUR USAGE PROFESSIONNEL SEULEMENT - NON DESTINÉ À L’USAGE DOMESTIQUE.';
                                                          app.findTextPreferences.findWhat = 'PARA USO PROFESIONAL SOLAMENTE: NO ESTÁ DISEÑADO PARA USO DOMÉSTICO.';
                                                          currentChangeProps1 = app.changeTextPreferences.properties;
                                                          app.findTextPreferences.findWhat = 'FOR PROFESSIONAL USE ONLY-NOT INTENDED FOR HOUSEHOLD USE.';
                                                          currentChangeProps2 = app.changeTextPreferences.properties;
                                              • 20. Re: Adding Highlight to script Or Grep Style?
                                                I'm confused, just include the function in your script and then do
                                                highlight('fred');
                                                highlight('Trevor');
                                                highlight('Chris');
                                                That will highlight whatever your want.
                                                Did you read the annotations?
                                                • 21. Re: Adding Highlight to script Or Grep Style?
                                                  cbishop01 Level 2
                                                  Sorry i miss read it.  I see it now.  Thank you.
