2 Replies Latest reply on Jul 21, 2016 1:09 PM by ManiacJoe
    Brush tool-new to Lightroom
    amandaj34311756
      Yes, I'm one of those annoying newbies. I'm trying to lighten the eyes. I use the brush tool. I see it in red that it's where I want it to be on the iris. Then when I try to make adjustments it excludes the brushed part and does it to the rest of the photo. This has to be an easy fix that I'm missing. What settings do I change? Thanks so much!
        • 1. Re: Brush tool-new to Lightroom
          WobertC Adobe Community Professional
          Your explanation "Does it to the rest of the photo.." would indicate that you may not be using the Brush tool. That would suggest you may have the Radial Filter tool active.
          The Brush Tool is toggled on/off with the keyboard 'K' key.
          The "red" you see is an overlay indicator that can be turned off by the 'O' key (or changed in colour by 'Shift+O' )
          If you do want to use the Radial Filter for a 'circle' over the eyes [Shift+M] , you would need to Invert the Radial Filter with a tick in the 'Invert Mask" box (or press the quote key [ ' ]. Then the filter is applied within the circle.
          • 2. Re: Brush tool-new to Lightroom
            ManiacJoe Adobe Community Professional
            Wobertc has you pointed in the right direction.
            The brush tool is the one on the far right, the circle with the handle on it.
