1 Reply Latest reply on May 15, 2006 10:03 PM by Craig Grummitt
    Space Invaders
    samdl1
      Hi all,
      I have had a little space invaders type game on the go for a while and had some free time so I thought I'd have a blast at finishing it. I have a function checking every frame whether the passed instance hits another movieclip (one of around twenty that it could hit) using onEnterFrame, a for loop to go through the different movieclips and hitTest().
      The problem is this function is itself being called several times at once (its a missile that launches on pressing the space bar) so I very quickly end up with the for loop running every frame on several different instances. (I think) this causes a huge slowdown where it pretty much grinds to a halt. There are many more complex games out than mine so I assume it must be my crappy coding :o - Does anyone have any suggestions?
      here is the code
      stop ();
      /* Control variables for use in functions */
      var missileDuplicate:MovieClip; //name of the most current missile (set dynamically)
      var bombDuplicate:MovieClip; // name of the most current bomb (set dynamically)
      var j:Number = 3; //used to increment missile name
      var k:Number = 1; //used to increment bomb name
      var intervalId:Number; //counter for setInterval
      var keyListener:Object = new Object ();
      /*Difficulty variables eventually set automatically */
      var distance:Number = 5; //speed of ship
      var missileNum:Number = 200; //maximum missiles
      var bombNum:Number; //number of bombs this level
      var bombFreq:Number; //frequency of bombs
      var bombSpeed:Number; //not used yet
      var bombDiff:Number; //not used yet
      bombNum = 10;
      bombFreq = 3000;
      bombDiff = 2;
      /* setting up thew stage */
      this.createEmptyMovieClip ("parent_mc", 0);
      parent_mc.attachMovie ("missile_mc", "missile_mc", 2, {_x:250, _y:392});
      parent_mc.missile_mc.stop ();
      parent_mc.missile_mc._visible = false;
      parent_mc.attachMovie ("bomb_mc", "bomb_mc", 1, {_x:250});
      parent_mc.bomb_mc.stop ();
      parent_mc.bomb_mc._visible = false;
      missiles_txt.text = missileNum; //counts down the number of missiles left
      /* Bomb control functions */
      function bombsAway ()
      var l:Number = missileNum + k;
      bombDuplicate = parent_mc.bomb_mc.duplicateMovieClip ("bomb" + k + "_mc", l, {_x:Math.floor (Math.random () * (445 - 0 + 1)) + 0});
      bombControl (bombDuplicate);
      if (k == bombNum)
      clearInterval (intervalId);
      return;
      k++;
      intervalId = setInterval (this, "bombsAway", bombFreq);
      function bombControl (missMov:MovieClip)
      missMov.onEnterFrame = function ()
      if (missMov.hitTest (base_mc))
      this.gotoAndStop (2);
      /*missile control*/
      function hitMe (missMov:MovieClip)
      if ((missMov.hitTest (blocks.blocks1)) || (missMov.hitTest (blocks.blocks2)) || (missMov.hitTest (blocks.blocks3)))
      removeMovieClip (missMov);
      for (var i=1; bombNum; i++){
      var mov:MovieClip = MovieClip("parent_mc.bomb"+i+"_mc");
      if (missMov.hitTest (mov)){
      removeMovieClip(mov);
      removeMovieClip(missMov);}}
      /*keypress control */
      keyListener.onKeyDown = function ()
      if (Key.isDown (Key.LEFT))
      ship_mc._x = Math.max (ship_mc._x - distance, 0);
      else if (Key.isDown (Key.RIGHT))
      ship_mc._x = Math.min (ship_mc._x + distance, Stage.width - 120 - ship_mc._width);
      else if (Key.isDown (Key.SPACE))
      if (j < missileNum + 3)
      missileDuplicate = parent_mc.missile_mc.duplicateMovieClip ("missile" + j + "_mc", j);
      missileDuplicate._x = ship_mc._x + (ship_mc._width / 2);
      missiles_txt.text = missileNum + 2 - j;
      j++;
      hitMe (missileDuplicate);
      Key.addListener (keyListener);
      hopefully you can see the bit I'm talking about is in the hitMe function
      Any help you could give would be greatly appreciated
      Sam
