3 Replies Latest reply on Jul 26, 2016 2:25 PM by - JM -
    Does CC need Akamai to be active?
    - JM - Level 3
      It appears that the only application using Akamai Net Session is Adobe. Is this needed for CC to work?
      thank you,
        • 2. Re: Does CC need Akamai to be active?
          - JM - Level 3
          Thank you Rajashree for the response -
          I had read the Adobe Akamai FAQ but there is a discrepancy in the information in the article and the list of software that the FAQ applies to. So I'm back to the same question. As a result of the error in the Adobe document I don't know what applications are effected.
          Does CC or CS6 require Akamai Net Session?
          The information in the Adobe/Akamai FAQ:
          Some Adobe trial products use Akamai Download Manager, also called the Akamai NetSession Interface. Trial products that use Akamai include Acrobat X Pro, Adobe Captivate, and the Technical Communications Suite.
          The following list are the applications that the document applies to, but it does not mention Acrobat X Pro or Adobe Captivate. So I assume that the list below is not a comprehensive/complete.
          Acrobat
          Adobe Audition
          Adobe OnLocation CS
          Adobe Premiere Elements
          Adobe Premiere Pro CS5.5
          After Effects CS5.5
          Authorware
          Bridge CS5.5
          ColdFusion Builder
          ColdFusion
          Creative Suite CS5.5
          Device Central
          Dreamweaver CS5.5
          Flash Catalyst CS5.5
          Flash Professional CS5.5
          FrameMaker
          FreeHand
          InCopy CS5.5
          InDesign CS5.5
          Jrun
          LiveCycle
          Ovation
          Photoshop Elements
          Photoshop Extended
          Presenter
          RoboHelp
          Soundbooth
          Technical Communication Suite
          Visual Communicator
          eLearning Suite
          • 3. Re: Does CC need Akamai to be active?
            - JM - Level 3
            the answer is no.
