6 Replies Latest reply on Aug 5, 2016 5:05 PM by Zorro Gamarnik Branched from an earlier discussion.
    Crashes when rendering composition with Cinema 4D
    Zorro Gamarnik Level 1
      Hello, My platform is Mac Pro (late 2013)
      OS 10.11.6    Memory 16 GB
      Graphics/Display  AMD FirePro D300 x 2
      I can't render Cinema 4d without AE crashing.
      What Im trying to render is a tracked video 1920x1080 as a background plate + small objects created in cinema 4D.
      It takes about 15 min to render 1 frame and then I get crash report on my screen.
      It is hapenning only with the latest AE update 13.8.0.144
      I have deleted ...../PTX/metal
      Please help
        • 1. Re: Crashes when rendering composition with Cinema 4D
          What does that crash report say?
          Can you render that same file with CC 2015 okay? (Remember, CC 2015.3 and CC 2015 can be installed alongside each other.)
          • 2. Re: Crashes when rendering composition with Cinema 4D
            Hello Szalam, thanks for the reply.
            the generated report not a chance for me to understand.
            Its very long and can be red by the technician only.
            I have tried CC 2015 and ended up with the same result.
            Dont know what to do next.
            • 3. Re: Crashes when rendering composition with Cinema 4D
              Copy and paste the first several paragraphs of your crash report so we can see it. There are some very technical people here who might be able to tell what the problem is. Heck, you could post the whole thing somewhere like pastebin if you wanted to so we could see the whole thing.
              • 4. Re: Crashes when rendering composition with Cinema 4D
                Thanks for helping me Szalem.
                After rendering C4d sequence of 10 sec for 28 Hours AE Crashed again.
                Here is crash report.
                Process:               After Effects [1986]
                Path:                  /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/MacOS/After Effects
                Identifier:            com.adobe.AfterEffects
                Version:               13.8 (13.8)
                Code Type:             X86-64 (Native)
                Parent Process:        ??? [1]
                Responsible:           After Effects [1986]
                User ID:               501
                Date/Time:             2016-07-25 14:48:04.480 +1000
                OS Version:            Mac OS X 10.11.6 (15G31)
                Report Version:        11
                Anonymous UUID:        539F0B37-53DE-E140-A02E-A7296511D597
                Time Awake Since Boot: 170000 seconds
                System Integrity Protection: enabled
                Crashed Thread:        0  Dispatch queue: com.apple.main-thread
                Exception Type:        EXC_CRASH (SIGABRT)
                Exception Codes:       0x0000000000000000, 0x0000000000000000
                Exception Note:        EXC_CORPSE_NOTIFY
                Application Specific Information:
                abort() called
                *** error for object 0x7fd59c637c08: incorrect checksum for freed object - object was probably modified after being freed.
                Global Trace Buffer (reverse chronological seconds):
                108697.248460 CFNetwork                 0x00007fff87365c8f TCP Conn 0x7fd599e2b260 starting SSL negotiation
                108697.248608 CFNetwork                 0x00007fff87364659 TCP Conn 0x7fd599e2b260 complete. fd: 74, err: 0
                108697.248687 CFNetwork                 0x00007fff873f2f33 TCP Conn 0x7fd599e2b260 event 1. err: 0
                108697.379084 CFNetwork                 0x00007fff8736392b TCP Conn 0x7fd599e2b260 started
                108698.289332 CFNetwork                 0x00007fff87365db3 TCP Conn 0x7fd5a23e85d0 SSL Handshake DONE
                108698.328572 CFNetwork                 0x00007fff87365c8f TCP Conn 0x7fd5a23e85d0 starting SSL negotiation
                108698.328691 CFNetwork                 0x00007fff87364659 TCP Conn 0x7fd5a23e85d0 complete. fd: 68, err: 0
                108698.328736 CFNetwork                 0x00007fff873f2f33 TCP Conn 0x7fd5a23e85d0 event 1. err: 0
                108698.343734 CFNetwork                 0x00007fff8736392b TCP Conn 0x7fd5a23e85d0 started
                108704.571799 CFNetwork                 0x00007fff87365db3 TCP Conn 0x7fd59b91d930 SSL Handshake DONE
                108707.536705 libsystem_trace.dylib     0x00007fff8e1460fa dyld_image_header_containing_address(0x7fd599ecf980) failed
                108707.536745 libsystem_trace.dylib     0x00007fff8e1460fa dyld_image_header_containing_address(0x7fd599ecf980) failed
                108707.996779 CFNetwork                 0x00007fff87365c8f TCP Conn 0x7fd59b91d930 starting SSL negotiation
                108707.997183 CFNetwork                 0x00007fff87364659 TCP Conn 0x7fd59b91d930 complete. fd: 19, err: 0
                108707.997308 CFNetwork                 0x00007fff873f2f33 TCP Conn 0x7fd59b91d930 event 1. err: 0
                108708.217652 CFNetwork                 0x00007fff8736392b TCP Conn 0x7fd59b91d930 started
                Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                0   libsystem_kernel.dylib         0x00007fff891eaf06 __pthread_kill + 10
                1   libsystem_pthread.dylib       0x00007fff97a464ec pthread_kill + 90
                2   libsystem_c.dylib             0x00007fff8ba326df abort + 129
                3   libsystem_malloc.dylib         0x00007fff87637396 szone_error + 626
                4   libsystem_malloc.dylib         0x00007fff8762d373 small_free_list_remove_ptr + 152
                5   libsystem_malloc.dylib         0x00007fff8762ba7c szone_free_definite_size + 1790
                6   libobjc.A.dylib               0x00007fff840d5b11 (anonymous namespace)::AutoreleasePoolPage::kill() + 71
                7   libobjc.A.dylib               0x00007fff840d2b46 (anonymous namespace)::AutoreleasePoolPage::pop(void*) + 606
                8   com.apple.CoreFoundation       0x00007fff93b60c12 _CFAutoreleasePoolPop + 50
                9   com.apple.Foundation           0x00007fff8ca9caf5 -[NSAutoreleasePool release] + 146
                10  com.adobe.dvaui.framework     0x000000010a967b74 dvaui::ui::DVAMacViewHandleKeyEvent(NSEvent*, boost::intrusive_ptr<dvaui::ui::OS_View>) + 132
                11  com.adobe.dvaui.framework     0x000000010a977a3a boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<bool, bool (*)(NSEvent*, boost::intrusive_ptr<dvaui::ui::OS_View>), boost::_bi::list2<boost::_bi::value<NSEvent*>, boost::_bi::value<dvaui::ui::OS_View*> > >, bool>::invoke(boost::detail::function::function_buffer&) + 58
                12  FLT.dylib                     0x0000000107aecf99 int dvacore::config::ErrorManager::ExecuteFunction<bool>(boost::function0<bool>*, bool*) + 41
                13  com.adobe.AfterEffectsLib.framework 0x00000001056b5ab6 egg::dvainit::AE_DVA_ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::fun ction0<int>) + 806
                14  com.adobe.dvaui.framework     0x000000010a7a69d3 bool dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<bool>(boost::f unction0<bool>, bool*) + 99
                15  com.adobe.dvaui.framework     0x000000010a7a5862 bool dvacore::config::ExecuteTopLevelFunction<bool>(boost::function0<bool>, bool*) + 162
                16  com.adobe.dvaui.framework     0x000000010a971059 -[DVAMacContainerView keyUp:] + 105
                17  com.apple.AppKit               0x00007fff9706cb15 -[NSWindow _reallySendEvent:isDelayedEvent:] + 2108
                18  com.apple.AppKit               0x00007fff96aab539 -[NSWindow sendEvent:] + 517
                19  com.apple.AppKit               0x00007fff96a2c16a -[NSApplication sendEvent:] + 4382
                20  com.adobe.dvaui.framework     0x000000010a9683f8 -[DVAMacApplication sendEvent:] + 600
                21  com.adobe.AfterEffectsLib.framework 0x00000001053dfc3c GetAECocoaApplication() + 5596
                22  com.apple.AppKit               0x00007fff96892df2 -[NSApplication run] + 796
                23  com.adobe.AfterEffectsLib.framework 0x000000010567bd51 CApplication::Run() + 65
                24  com.adobe.AfterEffectsLib.framework 0x00000001055ea69f MainMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, void**, int, int, int) + 1583
                25  com.adobe.AfterEffectsLib.framework 0x00000001055ea03b EggMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, int) + 59
                26  com.adobe.AfterEffects         0x000000010531cf1c main + 2268
                27  com.adobe.AfterEffects         0x000000010531c634 start + 52
                Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                0   libsystem_kernel.dylib         0x00007fff891ebefa kevent_qos + 10
                1   libdispatch.dylib             0x00007fff84a29165 _dispatch_mgr_invoke + 216
                2   libdispatch.dylib             0x00007fff84a28dcd _dispatch_mgr_thread + 52
                Thread 2:
                0   libsystem_kernel.dylib         0x00007fff891eadb6 __psynch_cvwait + 10
                1   libsystem_pthread.dylib       0x00007fff97a44728 _pthread_cond_wait + 767
                2   com.adobe.headlights.LogSessionFramework 0x0000000107ed355c boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
                3   com.adobe.headlights.LogSessionFramework 0x0000000107ed1e7f boost::this_thread::hiden::sleep_for(timespec const&) + 191
                4   com.adobe.headlights.LogSessionFramework 0x0000000107e674ea void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
                5   com.adobe.headlights.LogSessionFramework 0x0000000107e62707 RealTimeProcessor::WorkerThread(int) + 3683
                6   com.adobe.headlights.LogSessionFramework 0x0000000107ed11f9 boost::(anonymous namespace)::thread_proxy(void*) + 185
                7   libsystem_pthread.dylib       0x00007fff97a4399d _pthread_body + 131
                8   libsystem_pthread.dylib       0x00007fff97a4391a _pthread_start + 168
                9   libsystem_pthread.dylib       0x00007fff97a41351 thread_start + 13
                Thread 3:: com.apple.NSURLConnectionLoader
                0   libsystem_kernel.dylib         0x00007fff891e4f72 mach_msg_trap + 10
                1   libsystem_kernel.dylib         0x00007fff891e43b3 mach_msg + 55
                2   com.apple.CoreFoundation       0x00007fff93ba21c4 __CFRunLoopServiceMachPort + 212
                3   com.apple.CoreFoundation       0x00007fff93ba168c __CFRunLoopRun + 1356
                4   com.apple.CoreFoundation       0x00007fff93ba0ed8 CFRunLoopRunSpecific + 296
                5   com.apple.CFNetwork           0x00007fff8732aa6d +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
                6   com.apple.Foundation           0x00007fff8caade64 __NSThread__start__ + 1351
                Thread 4:
                2   com.apple.CoreServices.CarbonCore 0x00007fff900348ac TSWaitOnCondition + 108
                3   com.apple.CoreServices.CarbonCore 0x00007fff90034aab TSWaitOnConditionTimedRelative + 171
                4   com.apple.CoreServices.CarbonCore 0x00007fff9000d012 MPWaitOnQueue + 192
                5   com.adobe.dvacore.framework   0x000000010a0cbe3b dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()> > >&, int) + 155
                6   com.adobe.dvacore.framework   0x000000010a0c9cb8 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 168
                7   com.adobe.dvacore.framework   0x000000010a0c68d6 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 358
                8   com.adobe.boost_threads.framework 0x000000010ca285cc boost::(anonymous namespace)::thread_proxy(void*) + 124
                9   libsystem_pthread.dylib       0x00007fff97a4399d _pthread_body + 131
                10  libsystem_pthread.dylib       0x00007fff97a4391a _pthread_start + 168
                11  libsystem_pthread.dylib       0x00007fff97a41351 thread_start + 13
                Thread 5:
                0   libsystem_kernel.dylib         0x00007fff891eafba __recvfrom + 10
                1   VulcanMessage5.dylib           0x000000012082a1d6 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
                2   VulcanMessage5.dylib           0x000000012082944d vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 21
                3   VulcanMessage5.dylib           0x0000000120828808 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 82
                4   VulcanMessage5.dylib           0x000000012082873e vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
                5   VulcanMessage5.dylib           0x00000001208232e8 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 46
                6   VulcanMessage5.dylib           0x0000000120823786 vcfoundation::io::Serializer::InternalDeserialize() + 30
                7   VulcanMessage5.dylib           0x000000012082372d vcfoundation::io::Serializer::Deserialize() + 9
                8   VulcanMessage5.dylib           0x00000001208275b2 vcfoundation::ncomm::Connection::ReadIn() + 22
                9   VulcanMessage5.dylib           0x00000001208272d9 vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 37
                10  VulcanMessage5.dylib           0x0000000120826f5a vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
                11  VulcanMessage5.dylib           0x0000000120826ead vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
                12  VulcanMessage5.dylib           0x0000000120819cb6 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
                13  VulcanMessage5.dylib           0x000000012081a76f adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 1005
                14  VulcanMessage5.dylib           0x00000001208280d8 vcfoundation::thread::AbstractThread::Run() + 50
                15  VulcanMessage5.dylib           0x0000000120829bf9 vcfoundation::thread::Thread::ThreadProc(void*) + 9
                16  libsystem_pthread.dylib       0x00007fff97a4399d _pthread_body + 131
                17  libsystem_pthread.dylib       0x00007fff97a4391a _pthread_start + 168
                18  libsystem_pthread.dylib       0x00007fff97a41351 thread_start + 13
                Thread 6:
                0   libsystem_kernel.dylib         0x00007fff891ebeca kevent + 10
                1   com.adobe.dvatransport.framework 0x000000010c8d7225 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 261
                2   com.adobe.dvatransport.framework 0x000000010c8d6ddc boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 284
                3   com.adobe.dvatransport.framework 0x000000010c8d6ac8 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 600
                4   com.adobe.dvatransport.framework 0x000000010c8cbd22 SkyConnectionEnv::MainLoop() + 162
                5   com.adobe.dvatransport.framework 0x000000010c8cb6d9 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
                6   com.adobe.boost_threads.framework 0x000000010ca285cc boost::(anonymous namespace)::thread_proxy(void*) + 124
                Thread 7:
                2   com.adobe.dvatransport.framework 0x000000010c8d6e7b boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 443
                4   com.adobe.dvatransport.framework 0x000000010c8e2c1a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 42
                5   com.adobe.dvatransport.framework 0x000000010c8e2b93 boost_asio_detail_posix_thread_function + 19
                Thread 8:
                Thread 9:: com.apple.CFSocket.private
                0   libsystem_kernel.dylib         0x00007fff891eb07a __select + 10
                1   com.apple.CoreFoundation       0x00007fff93bdf4fa __CFSocketManager + 762
                2   libsystem_pthread.dylib       0x00007fff97a4399d _pthread_body + 131
                3   libsystem_pthread.dylib       0x00007fff97a4391a _pthread_start + 168
                4   libsystem_pthread.dylib       0x00007fff97a41351 thread_start + 13
                Thread 10:
                Thread 11:
                Thread 12:
                5   com.apple.AVCVideoServices     0x000000013b1c6192 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 162
                Thread 13:
                Thread 14:
                Thread 15:
                Thread 16:
                Thread 17:: com.apple.audio.IOThread.client
                2   com.apple.audio.CoreAudio     0x00007fff8d1be35e HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98
                3   com.apple.audio.CoreAudio     0x00007fff8d1be2ec HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
                4   com.apple.audio.CoreAudio     0x00007fff8d1bc6a9 HALC_ProxyIOContext::IOWorkLoop() + 1149
                5   com.apple.audio.CoreAudio     0x00007fff8d1bc15e HALC_ProxyIOContext::IOThreadEntry(void*) + 88
                6   com.apple.audio.CoreAudio     0x00007fff8d1bc033 HALB_IOThread::Entry(void*) + 75
                Thread 18:
                2   com.apple.framework.IOKit     0x00007fff91239c21 io_connect_method + 384
                3   com.apple.framework.IOKit     0x00007fff911da130 IOConnectCallMethod + 342
                4   com.apple.framework.IOKit     0x00007fff911da300 IOConnectCallStructMethod + 56
                5   com.apple.IOAccelerator       0x00007fff912dd306 IOAccelContextSubmitDataBuffersExt + 262
                6   libGPUSupportMercury.dylib     0x00007fff88dd01e8 gpusSubmitDataBuffers + 134
                7   com.apple.AMDRadeonX4000GLDriver 0x0000000128f04803 0x128ea2000 + 403459
                8   GLEngine                       0x00007fff97d4d8a3 gleUnbindBufferObject + 59
                9   GLEngine                       0x00007fff97d62b4d gleUnbindDeleteHashNameAndObject + 63
                10  GLEngine                       0x00007fff97c88a7e glDeleteBuffers_Exec + 2230
                11  MEE.dylib                     0x0000000110b23d38 (anonymous namespace)::Quad<int>::RenderRect(dvacore::geom::RectT<int> const&) + 104
                12  MEE.dylib                     0x0000000110b24895 MEE_OpenGLBlitSimple::DrawTexture(unsigned int, dvacore::geom::RectT<int> const&, M_Matrix4 const&) + 805
                13  com.adobe.AfterEffectsLib.framework 0x00000001056f8364 ae::BlitPipeOpenGL::DrawUIOverlay(boost::shared_ptr<ae::BlitOpenGLOp> const&) + 436
                14  com.adobe.AfterEffectsLib.framework 0x00000001056f6e54 ae::BlitPipeOpenGL::BlitLatestOp() + 2964
                15  com.adobe.dvacore.framework   0x000000010a0c9cea dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 218
                16  com.adobe.dvacore.framework   0x000000010a0c68d6 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 358
                17  com.adobe.boost_threads.framework 0x000000010ca285cc boost::(anonymous namespace)::thread_proxy(void*) + 124
                18  libsystem_pthread.dylib       0x00007fff97a4399d _pthread_body + 131
                19  libsystem_pthread.dylib       0x00007fff97a4391a _pthread_start + 168
                20  libsystem_pthread.dylib       0x00007fff97a41351 thread_start + 13
                Thread 19:
                Thread 20:
                0   PF.dylib                       0x000000010808b447 int PF_BatchSample_BestCPlusPlus<PF_Pixel8, false>(PF_ProgressInfo*, PF_SampleQuality, PF_WorldX<PF_Pixel8> const*, int, PF_ScratchDataX<PF_Pixel8> const*, PF_FixedPoint*, PF_FixedPoint*, PF_SampPB const*, PF_Pixel8 const*, PF_BlendModeDescriptor<PF_Pixel8> const*, PF_Pixel8*) + 215
                1   PF.dylib                       0x00000001080c77f9 PF_TransformWorldPlus_S + 18521
                2   com.adobe.AfterEffects.MThread 0x0000000129f50706 std::vector<M_LRect, std::allocator<M_LRect> >::_M_insert_aux(__gnu_cxx::__normal_iterator<M_LRect*, std::vector<M_LRect, std::allocator<M_LRect> > >, M_LRect const&) + 710
                3   com.adobe.dvacore.framework   0x000000010a0c455f boost::detail::function::void_function_obj_invoker2<boost::_bi::bind_t<void, boost::function<void (int)>, boost::_bi::list1<boost::arg<1> > >, void, int, int>::invoke(boost::detail::function::function_buffer&, int, int) + 31
                4   com.adobe.dvacore.framework   0x000000010a0c3734 dvacore::threads::(anonymous namespace)::MultithreadedTask::Join() + 164
                5   com.adobe.dvacore.framework   0x000000010a0c1e3e dvacore::threads::ExecuteCPUBoundTaskOnAllProcessors(boost::function<void (int)> const&, int) + 126
                6   com.adobe.AfterEffects.MThread 0x0000000129f4bccc FilterMain + 5484
                7   PF.dylib                       0x00000001080c7b91 PF_TransformWorld + 529
                8   com.adobe.AfterEffectsLib.framework 0x00000001056a7634 BlitPipe::DoTransform(PF_World*, M_Matrix3 const&, int, bool, PF_World*) + 900
                9   com.adobe.AfterEffectsLib.framework 0x00000001056a798e BlitPipe::BlitGeneralCaseIntoViewCache(PF_World*, FEE_BlitPipeOptions const&) + 542
                10  com.adobe.AfterEffectsLib.framework 0x00000001056a89e2 BlitPipe::BlitBatch_PhaseOne(BlitPipe_Batch&, BEE_CheckoutReceiptPtr const&, boost::shared_ptr<PF_WorldX<PF_Pixel8> > const&) + 1906
                11  com.adobe.AfterEffectsLib.framework 0x00000001058361a4 CPano_AsyncPlayer::CheckAndFillBlittableFrameFromRecieptIndex(BEE_CheckoutReceiptPtr const&, boost::shared_ptr<BlitPipe> const&, boost::shared_ptr<BlitPipe_Batch> const&, boost::shared_ptr<std::vector<VideoBlitCacheItem, std::allocator<VideoBlitCacheItem> > > const&, long long, long long, PF_WorldX<PF_Pixel8>**, bool) + 6516
                12  com.adobe.AfterEffectsLib.framework 0x000000010585a514 CPano_AsyncPlayer::RenderVideo_Progress(ItemChangeType, boost::shared_ptr<BEE_WorkQueue_Item>) + 2132
                13  com.adobe.AfterEffectsLib.framework 0x0000000105855246 CPano_AsyncPlayer::StaticRenderVideo_Progress(boost::weak_ptr<CPano_AsyncPlayer>, ItemChangeType, boost::shared_ptr<BEE_WorkQueue_Item>) + 134
                14  com.adobe.AfterEffectsLib.framework 0x000000010587f0ef boost::_bi::bind_t<void, void (*)(boost::weak_ptr<CPano_AsyncPlayer>, boost::weak_ptr<BEE_CheckoutRangeReceipt> const&, unsigned long long), boost::_bi::list_av_3<boost::weak_ptr<CPano_AsyncPlayer>, boost::weak_ptr<BEE_CheckoutRangeReceipt>, long long>::type> boost::bind<void, boost::weak_ptr<CPano_AsyncPlayer>, boost::weak_ptr<BEE_CheckoutRangeReceipt> const&, unsigned long long, boost::weak_ptr<CPano_AsyncPlayer>, boost::weak_ptr<BEE_CheckoutRangeReceipt>, long long>(void (*)(boost::weak_ptr<CPano_AsyncPlayer>, boost::weak_ptr<BEE_CheckoutRangeReceipt> const&, unsigned long long), boost::weak_ptr<CPano_AsyncPlayer>, boost::weak_ptr<BEE_CheckoutRangeReceipt>, long long) + 38063
                15  com.adobe.AfterEffectsLib.framework 0x000000010587efcc boost::_bi::bind_t<void, void (*)(boost::weak_ptr<CPano_AsyncPlayer>, boost::weak_ptr<BEE_CheckoutRangeReceipt> const&, unsigned long long), boost::_bi::list_av_3<boost::weak_ptr<CPano_AsyncPlayer>, boost::weak_ptr<BEE_CheckoutRangeReceipt>, long long>::type> boost::bind<void, boost::weak_ptr<CPano_AsyncPlayer>, boost::weak_ptr<BEE_CheckoutRangeReceipt> const&, unsigned long long, boost::weak_ptr<CPano_AsyncPlayer>, boost::weak_ptr<BEE_CheckoutRangeReceipt>, long long>(void (*)(boost::weak_ptr<CPano_AsyncPlayer>, boost::weak_ptr<BEE_CheckoutRangeReceipt> const&, unsigned long long), boost::weak_ptr<CPano_AsyncPlayer>, boost::weak_ptr<BEE_CheckoutRangeReceipt>, long long) + 37772
                16  BEE.dylib                     0x0000000106ba54b6 boost::function2<int, ItemChangeType, boost::shared_ptr<BEE_WorkQueue_Item> >::operator()(ItemChangeType, boost::shared_ptr<BEE_WorkQueue_Item>) const + 70
                17  BEE.dylib                     0x0000000106b9daef bee::BEEp_WorkQueue_ItemNotify(ItemChangeType, boost::shared_ptr<bee::WorkQueue_Item> const&, bool) + 399
                18  BEE.dylib                     0x0000000106b655aa BEE_WorkQueue_Range_Callback(boost::shared_ptr<bee::Range_WorkQueue_Item> const&, boost::shared_ptr<BEE_CheckoutRangeReceipt> const&, BEE_RenderOptions const*, unsigned long long, bool, unsigned long long, unsigned long long) + 410
                19  BEE.dylib                     0x0000000106798841 BEEp_CheckoutItemFrameRange(BEE_Item*, BEE_ItemRenderOptions const&, boost::shared_ptr<BEE_CheckoutRangeReceipt> const&, unsigned long long, long long, bool, boost::function<int (boost::shared_ptr<BEE_CheckoutRangeReceipt> const&, BEE_RenderOptions const*, unsigned long long, bool, unsigned long long, unsigned long long)> const&) + 3089
                20  BEE.dylib                     0x0000000106b45b86 WorkThread_CheckoutItemFrameRange(boost::shared_ptr<bee::WorkQueue_Item> const&, BEE_ItemRenderOptions const&, bool, std::string const&, boost::function<void (unsigned long long, int, boost::shared_ptr<BEE_CheckoutRangeReceipt>&)> const&) + 1382
                21  BEE.dylib                     0x0000000106b76444 boost::function1<void, boost::shared_ptr<bee::WorkQueue_Item> >::operator()(boost::shared_ptr<bee::WorkQueue_Item>) const + 68
                22  BEE.dylib                     0x0000000106b3a06d BEEp_WorkQueue_Scheduler_PerformWork(boost::weak_ptr<dvacore::threads::AsyncThreadedExecu tor> const&) + 3245
                23  com.adobe.dvacore.framework   0x000000010a0c9cea dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 218
                24  com.adobe.dvacore.framework   0x000000010a0c68d6 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 358
                25  com.adobe.boost_threads.framework 0x000000010ca285cc boost::(anonymous namespace)::thread_proxy(void*) + 124
                26  libsystem_pthread.dylib       0x00007fff97a4399d _pthread_body + 131
                27  libsystem_pthread.dylib       0x00007fff97a4391a _pthread_start + 168
                28  libsystem_pthread.dylib       0x00007fff97a41351 thread_start + 13
                Thread 21:
                1   libsystem_pthread.dylib       0x00007fff97a4475e _pthread_cond_wait + 821
                2   com.apple.CoreServices.CarbonCore 0x00007fff90034a93 TSWaitOnConditionTimedRelative + 147
                3   com.apple.CoreServices.CarbonCore 0x00007fff9000d012 MPWaitOnQueue + 192
                4   com.adobe.dvacore.framework   0x000000010a0cbe3b dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()> > >&, int) + 155
                5   com.adobe.dvacore.framework   0x000000010a0c9cb8 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 168
                10  libsystem_pthread.dylib       0x00007fff97a41351 thread_start + 13
                Thread 22:: cr_scratch
                2   com.adobe.CameraRaw           0x000000013c31955b 0x13ba04000 + 9524571
                3   com.adobe.CameraRaw           0x000000013c29714b 0x13ba04000 + 8991051
                4   com.adobe.CameraRaw           0x000000013bfcbd41 0x13ba04000 + 6061377
                5   libsystem_pthread.dylib       0x00007fff97a4399d _pthread_body + 131
                6   libsystem_pthread.dylib       0x00007fff97a4391a _pthread_start + 168
                7   libsystem_pthread.dylib       0x00007fff97a41351 thread_start + 13
                Thread 23:
                0   libsystem_kernel.dylib         0x00007fff891eb10a __semwait_signal + 10
                1   libsystem_c.dylib             0x00007fff8ba53d0f nanosleep + 199
                2   com.adobe.AfterEffects.Scripting 0x0000000142b43958 png_write_find_filter + 191560
                3   com.adobe.AfterEffects.Scripting 0x0000000142b2942c png_write_find_filter + 83740
                4   com.adobe.AfterEffects.Scripting 0x0000000142b43435 png_write_find_filter + 190245
                Thread 24:: Dispatch queue: com.apple.notify.background.local.notification
                2   libsystem_notify.dylib         0x00007fff8ff8bdca __notify_register_mach_port_block_invoke_3 + 89
                3   libdispatch.dylib             0x00007fff84a2e93d _dispatch_call_block_and_release + 12
                4   libdispatch.dylib             0x00007fff84a2340b _dispatch_client_callout + 8
                5   libdispatch.dylib             0x00007fff84a2803b _dispatch_queue_drain + 754
                6   libdispatch.dylib             0x00007fff84a2e707 _dispatch_queue_invoke + 549
                7   libdispatch.dylib             0x00007fff84a2340b _dispatch_client_callout + 8
                8   libdispatch.dylib             0x00007fff84a2729b _dispatch_root_queue_drain + 1890
                9   libdispatch.dylib             0x00007fff84a26b00 _dispatch_worker_thread3 + 91
                10  libsystem_pthread.dylib       0x00007fff97a434de _pthread_wqthread + 1129
                11  libsystem_pthread.dylib       0x00007fff97a41341 start_wqthread + 13
                Thread 25:
                2   libsystem_c.dylib             0x00007fff8ba53c02 usleep + 54
                3   CinewareAESceneLayer           0x0000000143b2c20a melange::IpKillThread::Main() + 58
                4   CinewareAESceneLayer           0x0000000143b1d378 melange::BaseThread::Action() + 88
                5   CinewareAESceneLayer           0x0000000143b1d259 0x143a86000 + 619097
                Thread 26:
                Thread 27:
                5   com.apple.Foundation           0x00007fff8cbb5075 -[NSConnection run] + 149
                Thread 28:
                5   com.apple.Foundation           0x00007fff8cb46d99 -[NSConcreteTask waitUntilExit] + 205
                6   com.adobe.PlugPlug             0x0000000120162276 -[HtmlEngineMonitor monitorThreadProc] + 115
                7   com.apple.Foundation           0x00007fff8caade64 __NSThread__start__ + 1351
                Thread 29:: com.apple.NSEventThread
                5   com.apple.AppKit               0x00007fff969f4d95 _NSEventThread + 149
                Thread 30:
                Thread 31:
                2   com.mainconcept.mc.bc.dec.avc 0x0000000122a14ebb 0x122921000 + 999099
                3   com.mainconcept.mc.bc.dec.avc 0x000000012298bca8 0x122921000 + 437416
                4   libsystem_pthread.dylib       0x00007fff97a4399d _pthread_body + 131
                5   libsystem_pthread.dylib       0x00007fff97a4391a _pthread_start + 168
                6   libsystem_pthread.dylib       0x00007fff97a41351 thread_start + 13
                Thread 32:
                Thread 33:
                Thread 34:
                Thread 35:
                Thread 36:
                Thread 37:
                Thread 38:
                Thread 39:: Dispatch queue: com.apple.root.default-qos
                0   PF.dylib                       0x000000010807bc97 _p_PF_AreaSample_Straight_StaticSSE2 + 551
                1   PF.dylib                       0x000000010808b453 int PF_BatchSample_BestCPlusPlus<PF_Pixel8, false>(PF_ProgressInfo*, PF_SampleQuality, PF_WorldX<PF_Pixel8> const*, int, PF_ScratchDataX<PF_Pixel8> const*, PF_FixedPoint*, PF_FixedPoint*, PF_SampPB const*, PF_Pixel8 const*, PF_BlendModeDescriptor<PF_Pixel8> const*, PF_Pixel8*) + 227
                2   PF.dylib                       0x00000001080c77f9 PF_TransformWorldPlus_S + 18521
                3   com.adobe.AfterEffects.MThread 0x0000000129f50706 std::vector<M_LRect, std::allocator<M_LRect> >::_M_insert_aux(__gnu_cxx::__normal_iterator<M_LRect*, std::vector<M_LRect, std::allocator<M_LRect> > >, M_LRect const&) + 710
                4   com.adobe.dvacore.framework   0x000000010a0c455f boost::detail::function::void_function_obj_invoker2<boost::_bi::bind_t<void, boost::function<void (int)>, boost::_bi::list1<boost::arg<1> > >, void, int, int>::invoke(boost::detail::function::function_buffer&, int, int) + 31
                5   com.adobe.dvacore.framework   0x000000010a0c2b71 dvacore::threads::(anonymous namespace)::MultithreadedTask::Execute() + 161
                6   com.adobe.dvacore.framework   0x000000010a0cdb84 dvacore::threads::WrapExecuteTopLevelFunction(void*) + 36
                Thread 40:: Dispatch queue: com.apple.root.default-qos
                0   PF.dylib                       0x000000010807c541 _p_PF_AreaSample_Straight_StaticSSE2 + 2769
                Thread 41:
                0   libsystem_kernel.dylib         0x00007fff891eb5e2 __workq_kernreturn + 10
                1   libsystem_pthread.dylib       0x00007fff97a43578 _pthread_wqthread + 1283
                2   libsystem_pthread.dylib       0x00007fff97a41341 start_wqthread + 13
                Thread 42:: Dispatch queue: com.apple.root.default-qos
                0   PF.dylib                       0x000000010807bce3 _p_PF_AreaSample_Straight_StaticSSE2 + 627
                Thread 43:: Dispatch queue: NSCGSDisableUpdates
                2   com.apple.CoreGraphics         0x00007fff8e594d96 _CGSReenableUpdateForConnection + 92
                3   com.apple.CoreGraphics         0x00007fff8e594a69 CGSReenableUpdateToken + 469
                4   libdispatch.dylib             0x00007fff84a2e93d _dispatch_call_block_and_release + 12
                5   libdispatch.dylib             0x00007fff84a2340b _dispatch_client_callout + 8
                6   libdispatch.dylib             0x00007fff84a2803b _dispatch_queue_drain + 754
                7   libdispatch.dylib             0x00007fff84a2e707 _dispatch_queue_invoke + 549
                8   libdispatch.dylib             0x00007fff84a2340b _dispatch_client_callout + 8
                9   libdispatch.dylib             0x00007fff84a2729b _dispatch_root_queue_drain + 1890
                10  libdispatch.dylib             0x00007fff84a26b00 _dispatch_worker_thread3 + 91
                11  libsystem_pthread.dylib       0x00007fff97a434de _pthread_wqthread + 1129
                12  libsystem_pthread.dylib       0x00007fff97a41341 start_wqthread + 13
                Thread 44:: Dispatch queue: com.apple.root.default-qos
                0   PF.dylib                       0x000000010807c134 _p_PF_AreaSample_Straight_StaticSSE2 + 1732
                Thread 45:: Dispatch queue: com.apple.root.default-qos
                0   PF.dylib                       0x000000010807bc8f _p_PF_AreaSample_Straight_StaticSSE2 + 543
                Thread 46:: Dispatch queue: com.apple.root.default-qos
                0   PF.dylib                       0x000000010807c568 _p_PF_AreaSample_Straight_StaticSSE2 + 2808
                Thread 47:: Dispatch queue: com.apple.root.default-qos
                0   PF.dylib                       0x000000010807c2d0 _p_PF_AreaSample_Straight_StaticSSE2 + 2144
                Thread 48:
                Thread 0 crashed with X86 Thread State (64-bit):
                  rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x00007fff5a8e3fc8  rdx: 0x0000000000000000
                  rdi: 0x000000000000160b  rsi: 0x0000000000000006  rbp: 0x00007fff5a8e3ff0  rsp: 0x00007fff5a8e3fc8
                   r8: 0x00000000fffffff0   r9: 0x0000000000000010  r10: 0x0000000008000000  r11: 0x0000000000000206
                  r12: 0x0000000000000001  r13: 0x000000011b4ca000  r14: 0x00007fff769ce000  r15: 0x000000010532d000
                  rip: 0x00007fff891eaf06  rfl: 0x0000000000000206  cr2: 0x00007fff73f2b008
                Logical CPU:     0
                Error Code:      0x02000148
                Trap Number:     133
                Binary Images:
                       0x10531a000 -        0x105320ff7 +com.adobe.AfterEffects (13.8 - 13.8) <5AB79FD5-DC68-3ACA-8A2D-0FCDF320C507> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/MacOS/After Effects
                       0x105331000 -        0x10533ffff +com.adobe.boost_filesystem.framework (13.8.0 - 13.8.0.144) <99A26244-8B00-38AD-A86A-DECE0CC7DB55> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                       0x105354000 -        0x105361fff +com.adobe.boost_signals.framework (13.8.0 - 13.8.0.144) <510F6AE1-3A85-32ED-B71B-753CCE49F64E> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                       0x105380000 -        0x105381ff7 +com.adobe.boost_system.framework (13.8.0 - 13.8.0.144) <5849CDBF-8617-3910-A91F-C50D1C2DA964> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                       0x10538a000 -        0x10538ffff +com.adobe.boost_date_time.framework (13.8.0 - 13.8.0.144) <5A818DEC-318C-3214-801C-9DDD96C2A208> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                       0x1053a4000 -        0x1053a5ff7 +ALOG.dylib (1) <C0B6A51A-B495-3FBF-A9FC-65D4CC46B880> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/ALOG.dylib
                       0x1053b2000 -        0x1061e8ff7 +com.adobe.AfterEffectsLib.framework (AfterFXLib 1.0 - 1.0) <40C0EC47-A20B-3159-AB5C-BFBD3E667841> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLib
                       0x10670c000 -        0x106e5eff7 +BEE.dylib (1) <1C180853-9E24-3AFE-8F8A-DA23E75917BB> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/BEE.dylib
                       0x107871000 -        0x107880ff7 +BEZ.dylib (1) <B261B595-3F2B-3743-B859-5068864236BB> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/BEZ.dylib
                       0x10788e000 -        0x107893fff +BM.dylib (1) <88F83CB0-2BFE-3B7D-A2DD-B6B176A96DE9> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/BM.dylib
                       0x10789e000 -        0x10791afff +COR.dylib (1) <6A9685F5-59B6-3D64-B1DA-D1B52FE39020> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/COR.dylib
                       0x10799a000 -        0x1079c6ff7 +FILE.dylib (1) <0EED430E-85B5-329B-B0F5-71DCF3D77510> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/FILE.dylib
                       0x1079fe000 -        0x107a57ff7 +FLO.dylib (1) <F9D99594-F952-3CE9-88E7-595E4D3003EF> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/FLO.dylib
                       0x107a89000 -        0x107b2aff7 +FLT.dylib (1) <DA3780B5-6567-34E8-9A5F-F0E7C5A48491> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/FLT.dylib
                       0x107c35000 -        0x107c3eff7 +LIST.dylib (1) <09E2724A-9FDC-399F-8F00-8E3F644BBE8D> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/LIST.dylib
                       0x107c51000 -        0x107c6bfff +M.dylib (1) <F0C851BB-B704-30DE-A3E3-F212865EAD3D> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/M.dylib
                       0x107c7f000 -        0x107cb1ff7 +MC.dylib (1) <F2657008-01E7-3E01-B232-8E68F341ACD0> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/MC.dylib
                       0x107cf6000 -        0x107d6cfff +MSK.dylib (1) <97CB1914-97FA-32D0-8F2B-B73CD82E92E9> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/MSK.dylib
                       0x107dd1000 -        0x107f0ffff +com.adobe.headlights.LogSessionFramework (7.4.1.12.44773) <E5A0F6AE-9B68-3EF9-8562-7203A31318F9> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                       0x107fb0000 -        0x107ff1fff +OM.dylib (1) <B262C15A-116F-3A44-9255-6FDDC7579871> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/OM.dylib
                       0x10802a000 -        0x108051ff7 +P.dylib (1) <5691D97F-DE0D-383D-9A81-5DC0BAE56A6B> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/P.dylib
                       0x10806d000 -        0x108391fff +PF.dylib (1) <4A7B6541-DFF7-3517-9CE4-03A37BB0A3D0> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/PF.dylib
                       0x108551000 -        0x1087ecff7 +PIN.dylib (1) <B6DE8800-5F3A-3054-B47C-465D07DFEE7A> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/PIN.dylib
                       0x108a85000 -        0x108aa6fff +PLUG.dylib (1) <EAB8A477-52E7-3F11-8403-211A92A4EBF9> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/PLUG.dylib
                       0x108acf000 -        0x108af0ff7 +PR.dylib (1) <BFE1A9AD-51ED-33A3-9152-1AC3991712D5> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/PR.dylib
                       0x108b2c000 -        0x108b46fff +PREF.dylib (1) <880E974F-F9F3-3351-BEE2-072D56A903AB> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/PREF.dylib
                       0x108b65000 -        0x108b85ff7 +RG.dylib (1) <49C2B9D0-A073-3FCE-86B9-D15E04F8AF2B> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/RG.dylib
                       0x108bb0000 -        0x108bb1fff +RND.dylib (1) <B5C908AB-D381-3C1D-B750-DF2C652F1BDF> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/RND.dylib
                       0x108bc1000 -        0x108c27fff +SLU.dylib (1) <F3F5F7D2-4C37-3B7A-AD98-6A12AF63F8E1> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/SLU.dylib
                       0x108cc2000 -        0x108d16fff +SND.dylib (1) <02A09BA6-C3A0-354D-8B12-A7414D0B954A> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/SND.dylib
                       0x108d8b000 -        0x108d8cff7 +STR.dylib (1) <D3A92BEE-0D32-3A19-8958-93C8D07D8FB1> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/STR.dylib
                       0x108d96000 -        0x108d99ff7 +T.dylib (1) <ADFDBB39-C310-3AD1-A614-62B2E8AB3687> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/T.dylib
                       0x108da4000 -        0x108df8ff7 +TDB.dylib (1) <9D4D22E7-A934-34D2-9CB9-8E2FEBB6CD8C> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/TDB.dylib
                       0x108e53000 -        0x10947dff7 +TXT.dylib (1) <992CD7CF-8811-3055-A38A-241DB281DB16> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/TXT.dylib
                       0x109aa3000 -        0x109b31ff7 +U.dylib (1) <AD732C1D-1CCF-3CF1-861F-26D4AAC94540> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/U.dylib
                       0x109bd8000 -        0x109bdcff7 +VAL.dylib (1) <ED6326D8-FE02-3FBA-98E6-F5D8D53B0FC3> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/VAL.dylib
                       0x109be5000 -        0x109be6fff  ATSHI.dylib (394.4) <1BA81388-183E-3437-8E3E-D4A18CF83B54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
                       0x109bec000 -        0x109cd6fff +com.adobe.exo.framework (13.8.0 - 13.8.0.144) <F07EFC74-989B-3CBD-9E43-09DB858555DC> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/exo.framework/Versions/A/exo
                       0x109e72000 -        0x109ea6fff +PREM.dylib (1) <1B325F7E-3971-392E-82B1-203DB5F3E7C5> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/PREM.dylib
                       0x109ef3000 -        0x109f52fff +FRP.dylib (1) <EB8F1AE9-DDA3-33B5-8E93-5271937EE56F> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/FRP.dylib
                       0x109fa0000 -        0x10a299fff +com.adobe.dvacore.framework (13.8.0 - 13.8.0.144) <BBCCF3E6-B285-3768-8B38-C13B27E46AF4> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                       0x10a528000 -        0x10abceff7 +com.adobe.dvaui.framework (13.8.0 - 13.8.0.144) <E173835A-84C1-376F-87EE-76B5109DFC02> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                       0x10b565000 -        0x10b6fdfff +com.adobe.dvaworkspace.framework (13.8.0 - 13.8.0.144) <35E76E3A-47AA-38E8-B904-0857BBD9E473> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                       0x10b99f000 -        0x10b9a0fff +libtlshook.dylib (5) <976ED4F8-3F0D-2EFE-F97A-71AD6357D5E7> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libtlshook.dylib
                       0x10b9a5000 -        0x10b9c3fff +com.adobe.dvaunittesting.framework (13.8.0 - 13.8.0.144) <C92484B0-494B-3307-8017-5CE541730AE2> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                       0x10b9fb000 -        0x10ba50ff7 +com.adobe.dynamiclinkui.framework (13.8.0 - 13.8.0.144) <607BECED-0984-3DA2-B2FC-CE404DED2A76> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
                       0x10bad9000 -        0x10bd61fff +com.adobe.dynamiclink.framework (13.8.0 - 13.8.0.144) <DF713049-74C8-3782-B703-49375DBA5DB5> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                       0x10bffb000 -        0x10c0e8ff7 +com.adobe.dvaeve.framework (13.8.0 - 13.8.0.144) <07F51956-B903-3437-8265-3AA309956406> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                       0x10c228000 -        0x10c229fff  libCyrillicConverter.dylib (68) <79F5CFEF-92E4-30FE-A650-41F07B6D31B9> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
                       0x10c22e000 -        0x10c2d7ff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
                       0x10c307000 -        0x10c374fff +com.adobe.ICUData (4.0 - 3.61) <1770B361-1521-3A4F-A2D5-FE17EC641669> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
                       0x10c378000 -        0x10c44bff7 +com.adobe.dvametadata.framework (13.8.0 - 13.8.0.144) <8A694BE4-A985-3C55-8B37-1C8BBBCCDEC5> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
                       0x10c527000 -        0x10c647fff +com.adobe.dvametadataUI.framework (13.8.0 - 13.8.0.144) <354EC8EC-A537-3F7B-AF28-7554131DE552> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvametadataui.framework/Versions/A/dvametadataUI
                       0x10c79d000 -        0x10c7fffff +com.adobe.dvatemporalxmp.framework (13.8.0 - 13.8.0.144) <725762E0-ADCC-3AE7-B842-742C32DD67BD> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
                       0x10c83f000 -        0x10c87aff7 +com.adobe.dvamediatypes.framework (13.8.0 - 13.8.0.144) <1040ABD9-EAB1-30B1-8552-9DE34225D0E7> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                       0x10c8b2000 -        0x10c91cfff +com.adobe.dvatransport.framework (13.8.0 - 13.8.0.144) <F992766A-89E4-3631-ADCE-32CB607ED976> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                       0x10c9b0000 -        0x10c9d9fff +com.adobe.dvamarshal.framework (13.8.0 - 13.8.0.144) <AF84FADB-DAC3-317F-8F47-2B4F7EA7D0BE> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                       0x10ca18000 -        0x10ca1bfff +com.adobe.AdobeCrashReporter (7.2 - 7.2.3) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                       0x10ca27000 -        0x10ca35fff +com.adobe.boost_threads.framework (13.8.0 - 13.8.0.144) <C3A1596A-3300-31EB-A39A-75361A8E8FEF> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                       0x10ca55000 -        0x10cb03ff7 +com.adobe.boost_regex.framework (13.8.0 - 13.8.0.144) <0357CBED-2865-39B6-BFAF-55D27F0289A9> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
                       0x10cb87000 -        0x10cc3cff7 +com.adobe.dvascripting.framework (13.8.0 - 13.8.0.144) <C8E28013-C670-37F5-ACD2-71DA847C8640> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvascripting.framework/Versions/A/dvascripting
                       0x10cd4d000 -        0x10d567fff +libmkl_intel_lp64.dylib (0) <5788E2BB-1AE0-36E2-B511-016F9F045647> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libmkl_intel_lp64.dylib
                       0x10d631000 -        0x10e4b5fff +libmkl_intel_thread.dylib (0) <F1F7D1CC-9AB9-32F1-8A4C-49B32AE1C5C1> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libmkl_intel_thread.dylib
                       0x10e8c5000 -        0x10fc1ffe7 +libmkl_core.dylib (0) <DDDCB14C-5D3E-304F-8FFB-B2CF61331563> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libmkl_core.dylib
                       0x10fe16000 -        0x10fee8fcf +libiomp5.dylib (5) <0F6E6453-A6B5-378F-B6DE-3F73ECCE2437> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libiomp5.dylib
                       0x10ff3c000 -        0x10ffd0fff +libopencv_calib3d.2.4.8.dylib (0) <B2FB4E9B-507D-32DF-A021-E4A2A2D141FF> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_calib3d.2.4.8.dylib
                       0x10ffec000 -        0x1101fdff7 +libopencv_core.2.4.8.dylib (0) <CF98F320-D586-3F25-9F12-6ECFEADB4014> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_core.2.4.8.dylib
                       0x110260000 -        0x1102f4ff7 +libopencv_features2d.2.4.8.dylib (0) <6176DA7A-A9EC-3405-AD67-F3D683AAF652> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_features2d.2.4.8.dylib
                       0x110322000 -        0x110374fff +libopencv_flann.2.4.8.dylib (0) <F37D436E-D5B4-3230-B6E5-652888B52AA2> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_flann.2.4.8.dylib
                       0x1103ae000 -        0x11057efff +libopencv_highgui.2.4.8.dylib (0) <77F8A9EF-F112-3656-8BA4-AA4ADE799CAD> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_highgui.2.4.8.dylib
                       0x1105f3000 -        0x1107b7ff7 +libopencv_imgproc.2.4.8.dylib (0) <0253A41D-5C67-3757-A733-80D14E3AB9CC> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_imgproc.2.4.8.dylib
                       0x1108c2000 -        0x11092fff7 +libopencv_objdetect.2.4.8.dylib (0) <2FB35359-29F0-3793-A876-ACBB73B4DFA7> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_objdetect.2.4.8.dylib
                       0x11094d000 -        0x110996fff +libopencv_video.2.4.8.dylib (0) <D624B586-618E-31B4-94A5-FE6BD2A864D0> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_video.2.4.8.dylib
                       0x1109a5000 -        0x1109cdff7 +SegMatServices.dylib (1) <59E711ED-089B-3538-BC3D-EBBC0C0B70DE> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/SegMatServices.dylib
                       0x110a14000 -        0x110a1bff7 +SAM.dylib (1) <4D4A6D2A-C701-30AC-853E-FE732D52BE09> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/SAM.dylib
                       0x110a22000 -        0x110aa4fff +TDL.dylib (1) <A2D6A3D4-70E1-3D03-A704-C6613985CE71> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/TDL.dylib
                       0x110afe000 -        0x110c11ff7 +MEE.dylib (1) <942A0D76-8592-382F-9FEB-B05EB271E403> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/MEE.dylib
                       0x110ce0000 -        0x110d10fef +libtbb.dylib (0) <D41FA1F0-4921-308A-93DF-4D16F8913472> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libtbb.dylib
                       0x110d2d000 -        0x110d52fff +libtbbmalloc.dylib (0) <60EF4F46-298B-38B6-A6CD-9B168072EAB7> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libtbbmalloc.dylib
                       0x110d80000 -        0x110d84fff  com.apple.agl (3.3.1 - AGL-3.3.1) <4E401980-0F4F-33E2-A0CF-8C7CCF375F24> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                       0x110d92000 -        0x110e8cfff +com.adobe.adobe_caps (adobe_caps 10.0.0.5 - 10.0.0.5) <E029224F-4AD9-3054-87A7-AB5FAAD7CD1F> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                       0x110ea2000 -        0x110fa4fff +com.adobe.amtlib (9.0.0.89 - 9.0.0.89) <EBF9B7FD-5C40-31E1-976E-D5B5608080B9> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                       0x110fbb000 -        0x111024ff7 +com.adobe.aif_core.framework (13.8.0 - 13.8.0.144) <6DA67009-209C-3694-AC3C-F36A44F4C3B2> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
                       0x111067000 -        0x11110aff7 +com.adobe.aif_ogl.framework (13.8.0 - 13.8.0.144) <16348B74-F0CF-3C4F-99F6-1D07698BF2AA> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
                       0x11118c000 -        0x1111b2fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.35686 - 3.8.0.35686) <2FB8F7AD-F434-30D7-9E01-2075B4E1E460> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExp at
                       0x1111da000 -        0x111351fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 132 - 79.159330) <D77569CC-4240-3F0D-923B-E81E831CFE03> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                       0x1114aa000 -        0x1115feff7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.7 -f 15 - 79.159330) <22C1875D-16B3-39D1-A893-F467D7F5CE1D> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                       0x111725000 -        0x111829fff +com.adobe.dvaaudiodevice.framework (13.8.0 - 13.8.0.144) <8B9FE82C-C69C-35AB-A5A0-309AA0101E77> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
                       0x1119bb000 -        0x111a81fff +com.adobe.dvaplayer.framework (13.8.0 - 13.8.0.144) <A8433685-D493-3102-9A89-4DDC8C70D981> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
                       0x111bdb000 -        0x111c92ff7 +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.1) <9274F8EE-BE07-3C74-9A2A-DC338B894443> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                       0x111cd8000 -        0x111d9afff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.1) <BA3DD538-DDFC-3F17-BD0C-ED236538B40F> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                       0x111def000 -        0x111e0cff7 +com.adobe.ahclientframework (2.1.0.1 - 2.1.0.1) <88C960B2-045B-3571-B54C-7FB1D8A814CC> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                       0x111e20000 -        0x111e41fff +com.adobe.BIB (AdobeBIB 1.2.03.35973 - 1.2.03.35973) <11EBACBD-C7F8-3E80-A2BF-E87543B5CE11> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                       0x111e50000 -        0x111f42fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.35686 - 3.8.0.35686) <7A973722-4CFA-3A4B-8044-A91649EF140D> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                       0x111fe8000 -        0x11234dfff +com.adobe.CoolType (AdobeCoolType 5.15.00.35973 - 5.15.00.35973) <972563FE-CD16-35EF-BB06-AF3B629ECBF4> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                       0x112397000 -        0x1126c2ff7 +com.adobe.AGM (AdobeAGM 4.30.60.35973 - 4.30.60.35973) <954DAD10-5A1B-38B3-A54C-087ADE20CBB5> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                       0x112731000 -        0x112891ff7 +com.adobe.ACE (AdobeACE 2.20.02.35973 - 2.20.02.35973) <3E107802-4FD9-3AFC-9A03-314C3E1B49BE> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                       0x1128a8000 -        0x1128ceff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <6536192E-56D1-3EF0-97A9-04630B74CE0C> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                       0x1128da000 -        0x1129a4ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.35705) <98313A71-63B6-3D76-81A9-F99602F36756> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                       0x1129ec000 -        0x112a27fff +com.adobe.ARE (AdobeARE 1.5.02.35973 - 1.5.02.35973) <EF615DAC-FA1F-3206-B398-2157434D6604> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                       0x112a34000 -        0x112e06ff7 +com.adobe.MPS (AdobeMPS 5.8.1.35730 - 5.8.1.35730) <1BFDF4C4-BDC6-387E-9F65-797561B18086> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                       0x112e7b000 -        0x112ea1ff7 +com.adobe.AXE16SharedExpat (AdobeAXE16SharedExpat 3.8.0.35686 - 3.8.0.35686) <BD8A9BAA-87F5-3DBB-A182-E2FAE740A25C> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedE xpat
                       0x112ec7000 -        0x1150f3f47 +com.adobe.psl (AdobePSL 15.1.0.34015 - 15.1.0.34015) <7B2AA133-FD2F-3DF4-9737-994B710AB33F> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                       0x115582000 -        0x1156b0fff +com.winsoft.wrservices (WRServices 7.0.0 - 7.0.0) <0853A41B-A14A-37B7-B27F-457F87865EAD> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                       0x115713000 -        0x115747fff +com.adobe.dvaaudiodeviceui.framework (13.8.0 - 13.8.0.144) <79B4E30A-E8F6-3D7B-9B3B-BCD8E5DFD673> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaaudiodeviceui.framework/Versions/A/dvaaudiodeviceui
                       0x115793000 -        0x115874ff7 +com.adobe.dvanet.framework (13.8.0 - 13.8.0.144) <74EE5A75-B7B2-33DE-90C5-97697DC560C4> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
                       0x115972000 -        0x115973ff7 +com.adobe.AfterEffects.Paint (???) <C76B1BDA-9FE6-37A5-A2C9-F6D343F086A9> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Paint.plugin/Contents/MacOS/Paint
                       0x115978000 -        0x115fa9fff +com.adobe.EAClient.framework (13.8.0 - 13.8.0.144) <BD212A19-8DA7-3875-AF45-125C41968C97> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/EAClient.framework/Versions/A/EAClient
                       0x116673000 -        0x11686bfef +com.adobe.EACodec.framework (13.8.0 - 13.8.0.144) <4F55E5CE-BFE6-352E-BB4C-AC69CA82D63A> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/EACodec.framework/Versions/A/EACodec
                       0x11692a000 -        0x116c60ff7 +com.adobe.EAMedia.framework (13.8.0 - 13.8.0.144) <3D113B01-DEDC-3598-909C-858F6ABD9A03> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/EAMedia.framework/Versions/A/EAMedia
                       0x116f6c000 -        0x116f6cfe7 +cl_kernels (???) <0BB501B6-47E2-425B-8A12-57C6B20179A4> cl_kernels
                       0x116f73000 -        0x117457ff7 +com.adobe.EAProjectBridge.framework (13.8.0 - 13.8.0.144) <C5080C96-5ED2-3A7E-958C-5A2F8F2F96E1> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/EAProjectBridge.framework/Versions/A/EAProjectBridge
                       0x11794e000 -        0x117976fff +com.adobe.eaurl.framework (13.8.0 - 13.8.0.144) <8DADB197-8B16-3FCA-8B33-B1F9E99AAEBA> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/eaurl.framework/Versions/A/eaurl
                       0x1179b4000 -        0x1179f8fff +com.adobe.boost_program_options.framework (13.8.0 - 13.8.0.144) <8F98D9AF-939D-3B60-AC38-3589D0918192> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_program_options.framework/Versions/A/boost_program_opt ions
                       0x117a50000 -        0x117b72ff7 +com.adobe.dvanetsync.framework (13.8.0 - 13.8.0.144) <D8FAA626-02AD-331E-8ECE-2E685BEED67D> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvanetsync.framework/Versions/A/dvanetsync
                       0x117cd1000 -        0x117e34fff +com.adobe.dvascriptui.framework (13.8.0 - 13.8.0.144) <2D2725FA-4060-3903-9807-26AF1087A440> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvascriptui.framework/Versions/A/dvascriptui
                       0x11808a000 -        0x118348fcf +com.adobe.dvaaudiodsp.framework (13.8.0 - 13.8.0.144) <09961712-EA9F-3768-B1B0-1F4F43554336> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaaudiodsp.framework/Versions/A/dvaaudiodsp
                       0x1183c8000 -        0x1183cbfff +com.adobe.PRM.framework (13.8.0 - 13.8.0.144) <D12D2178-6D89-3D2C-8314-C5E0CF2C610D> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
                       0x1183db000 -        0x118427ff7 +com.adobe.ASLFoundation.framework (13.8.0 - 13.8.0.144) <630E4182-DC16-3B58-B899-C61C23324C97> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
                       0x118492000 -        0x1184a4fff +com.adobe.ASLMessaging.framework (13.8.0 - 13.8.0.144) <56FCB4D2-A4E2-3C1D-8477-35042AE987B6> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
                       0x1184c1000 -        0x1184c2ff7 +com.adobe.Memory.framework (13.8.0 - 13.8.0.144) <D69F0A4F-590F-3533-B9DA-3868F5BF6834> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
                       0x1184cc000 -        0x118581ff7 +com.adobe.MediaFoundation.framework (13.8.0 - 13.8.0.144) <0A988314-D4E9-3E78-99EE-C8EEC5E0BBC8> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
                       0x118658000 -        0x118701fff +com.adobe.AudioRenderer.framework (13.8.0 - 13.8.0.144) <863272B0-3C0E-3D51-9747-7CC83BCD99DC> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
                       0x1187d7000 -        0x1188dafff +com.adobe.dvacaptioning.framework (13.8.0 - 13.8.0.144) <9495C3D0-76E2-3A78-AFFA-A44758723094> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
                       0x1189b5000 -        0x119916ff7 +com.adobe.Backend.framework (13.8.0 - 13.8.0.144) <BEF4EF70-3FE5-3790-A571-BB845B7BCE2E> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
                       0x11a770000 -        0x11a7a8fff +com.adobe.MLFoundation.framework (13.8.0 - 13.8.0.144) <986A1908-8AA6-3C9D-8E82-00F5F03FEE06> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
                       0x11a7fe000 -        0x11a95afef +com.adobe.ImageRenderer.framework (13.8.0 - 13.8.0.144) <F3F195ED-2231-3636-881B-E6796E3B6031> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
                       0x11aa5b000 -        0x11aaedfff +com.adobe.VideoFrame.framework (13.8.0 - 13.8.0.144) <32620411-2B2D-39F1-8B6B-AC93B6D68DF4> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
                       0x11ab68000 -        0x11abafff7 +com.adobe.PluginSupport.framework (13.8.0 - 13.8.0.144) <33CA6025-99AB-3503-AF70-CFD86029FBD0> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
                       0x11ac09000 -        0x11ac36fff +com.adobe.SweetPeaSupport.framework (13.8.0 - 13.8.0.144) <6A9FDDF1-A9B0-3C36-BA8A-FA9B656987E8> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
                       0x11ac7f000 -        0x11acebff7 +com.adobe.AudioSupport.framework (13.8.0 - 13.8.0.144) <CF859490-613B-36B2-ADFE-C13CC4B7C4AC> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
                       0x11ad73000 -        0x11ad76ff7 +com.adobe.MediaUtils.framework (13.8.0 - 13.8.0.144) <71037B94-6E8E-36DB-9404-7F7AEBCC8C4D> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
                       0x11ad7f000 -        0x11af58fff +com.adobe.ImporterHost.framework (13.8.0 - 13.8.0.144) <CBE79007-C88B-3541-ACF9-52786041CD79> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
                       0x11b163000 -        0x11b1a9ff7 +com.adobe.AudioFilterHost.framework (13.8.0 - 13.8.0.144) <3708C859-0150-314F-AE1D-346D2494EC73> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
                       0x11b217000 -        0x11b368fff +com.adobe.VideoRenderer.framework (13.8.0 - 13.8.0.144) <F68628B7-CF3B-37A4-8BE0-0F8967985865> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
                       0x11b4cb000 -        0x11b5e2ff7 +com.adobe.VideoFilterHost.framework (13.8.0 - 13.8.0.144) <C5FC216E-12B4-3D4C-AFA4-028D3CB7FB32> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
                       0x11b6f1000 -        0x11b708fff +com.adobe.ProjectSupport.framework (13.8.0 - 13.8.0.144) <2968238E-C32E-399C-8D2C-C07910042D1C> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
                       0x11b733000 -        0x11b91dfe7 +com.adobe.GPUFoundation.framework (13.8.0 - 13.8.0.144) <020D7396-8719-3C1B-A358-66A683400372> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
                       0x11ba25000 -        0x11c251ff7 +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.35981) <A269B1B2-4CDE-36AF-AFB4-7FB661FBC020> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
                       0x11c30f000 -        0x11d710f2f +liboptix.1.dylib (3.0.1) <F73808E6-D80C-065F-00F6-FF446FB5CD29> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/liboptix.1.dylib
                       0x11de53000 -        0x11debdfef +liboptixcudart.dylib (4.2) <6FD33B3C-5941-CE4A-41B5-F80250A591E1> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/liboptixcudart.dylib
                       0x11dec7000 -        0x11dec8fff +liboptixtlshook.dylib (4) <1D1C35CB-E17F-79E0-7DAE-988625AB57F9> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/liboptixtlshook.dylib
                       0x11ded4000 -        0x11e01cff7 +com.adobe.AIDE (1.5.0 - 1.5.0.35921) <452817DA-9C9F-3579-A2D2-F1166387B510> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
                       0x11e03f000 -        0x11e151ff7 +com.adobe.ExporterHost.framework (13.8.0 - 13.8.0.144) <406A89E6-6E9D-3223-BBA8-420926DC3E33> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
                       0x11e263000 -        0x11e4acff7 +com.adobe.SettingsUI.framework (10.3.0 - 10.3.0.185) <DD85A36E-C18B-3626-92A8-BAABBB5D4B49> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
                       0x11e81b000 -        0x11e863ff7 +com.adobe.AudioFilters.framework (13.8.0 - 13.8.0.144) <DE91F6B3-3595-385E-B1CA-A82052A2FC21> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
                       0x11e8de000 -        0x11e95ffff +com.adobe.PlayerHost.framework (13.8.0 - 13.8.0.144) <97758915-C8FA-3F1E-81F5-4C0D1F5BA58E> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
                       0x11ea20000 -        0x11ea33fff +com.adobe.ProjectConverterHost.framework (13.8.0 - 13.8.0.144) <6A8D632A-E0B3-3EA0-85F0-55EDB4B70D7C> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHo st
                       0x11ea5b000 -        0x11eac4ff7 +com.adobe.DynamicLinkMedia.framework (13.8.0 - 13.8.0.144) <5012CA5C-3E78-3B3A-AFD6-28D2BDEA6E84> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
                       0x11eb87000 -        0x11ed4bff7 +com.adobe.EncoderHost.framework (13.8.0 - 13.8.0.144) <9C220EE7-039C-3EB0-8AD9-A3ADE5C5E963> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
                       0x11ef01000 -        0x11ef64ff7 +com.adobe.QT32Client.framework (13.8.0 - 13.8.0.144) <0CE2D1D1-6274-31D5-BD7E-1582985F6DEA> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
                       0x11efe7000 -        0x11f0d9ff7 +com.adobe.MBCProvider.framework (13.8.0 - 13.8.0.144) <385A931C-4CAC-3887-8AB9-BD5C08A6E8DC> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
                       0x11f1bc000 -        0x11f211fff +com.adobe.TransmitHost.framework (13.8.0 - 13.8.0.144) <F06471A0-BB1E-3044-B96C-481AC50CC727> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/TransmitHost.framework/Versions/A/TransmitHost
                       0x11f272000 -        0x11f2daff7 +com.adobe.DisplaySurface.framework (13.8.0 - 13.8.0.144) <01465A81-C593-371F-9FE9-07F24351B2C1> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
                       0x11f349000 -        0x11f402ff7 +com.adobe.dvascriptingES.framework (13.8.0 - 13.8.0.144) <D2469707-064D-36EA-9FED-A64AF463888F> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvascriptingES.framework/Versions/A/dvascriptingES
                       0x11f4d7000 -        0x11f4f6ff7 +com.adobe.dvamediaui.framework (13.8.0 - 13.8.0.144) <C77D497A-4F30-36C2-8DE5-DE0DDFE7585B> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvamediaui.framework/Versions/A/dvamediaui
                       0x11f543000 -        0x11f6b4ff7 +com.adobe.dvamediabrowser.framework (13.8.0 - 13.8.0.144) <F968B761-6DD4-3EDB-BE6D-CDD8C501F9FE> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvamediabrowser.framework/Versions/A/dvamediabrowser
                       0x11f8ec000 -        0x11f949fff +com.adobe.MediaCoreUI.framework (13.8.0 - 13.8.0.144) <44CDCE91-25E1-3457-8C3D-F1EFFBBD05F4> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
                       0x11f9bd000 -        0x11f9e4ff7 +com.adobe.AMEAppFoundation.framework (10.3.0 - 10.3.0.185) <DFA04E54-54AA-3F36-BE08-74E731B445B7> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
                       0x11fa2c000 -        0x11fa45fff +com.adobe.postprocess.framework (10.3.0 - 10.3.0.185) <4081DFF9-5758-36B8-A84E-0E4789245FE9> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/postprocess.framework/Versions/A/postprocess
                       0x11fa72000 -        0x11fa7fff7 +com.adobe.RuntimeInstaller.framework (13.8.0 - 13.8.0.144) <4AB06AEE-0601-3280-9620-A1F1FEBDC03D> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/RuntimeInstaller.framework/Versions/A/RuntimeInstaller
                       0x11fa9d000 -        0x11fd75fe6 +libxerces-c-3.0.dylib (0) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libxerces-c-3.0.dylib
                       0x11fef7000 -        0x11ff18ff7 +com.adobe.dvavulcansupport.framework (13.8.0 - 13.8.0.144) <BC2A0140-6FA3-33E5-82F1-8C4312E3CC36> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvavulcansupport.framework/Versions/A/dvavulcansupport
                       0x11ff48000 -        0x11ff6efff +com.mainconcept.mc.enc.dv (9.11 - 9.11.15.2139) <625CDA13-BC3A-33FC-ADA4-5E8C2742DC4B> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_enc_dv.framework/Versions/9/mc_enc_dv
                       0x11ff88000 -        0x120033fff +com.adobe.AdobeXMPCompareAndMerge (Adobe XMP Compare And Merge 1.0 -c 34 - 79.159330) <063BC276-A52A-3F31-82F1-7B174C658282> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeXMPCompareAndMerge.framework/Versions/A/AdobeXMPCompare AndMerge
                       0x12015f000 -        0x12047efcf +com.adobe.PlugPlug (6.1.0.182 - 6.1.0.182) <8B64105F-9B0F-30C5-A087-972D15A9BBA7> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                       0x1207ac000 -        0x1207b0ff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                       0x1207bb000 -        0x1207dcff7 +VulcanControl.dylib (5.2.0.50 - 5.2.0.50 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <00913D4C-517C-33E8-895A-6F6509111B19> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/VulcanControl.dylib
                       0x12080c000 -        0x120844fff +VulcanMessage5.dylib (5.2.0.49 - 5.2.0.49 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <1D3CED35-E99B-3AAB-9C60-C6F853ED3BFB> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/VulcanMessage5.dylib
                       0x12088b000 -        0x120968ff7 +com.mainconcept.mc.mfimport (9.11 - 9.11.15.2139) <AC08E2A6-5471-3711-8B46-7748C4CA928F> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_mfimport.framework/Versions/9/mc_mfimport
                       0x120976000 -        0x120999ff7 +com.adobe.TimeCarving.framework (13.8.0 - 13.8.0.144) <BE85997E-EFBC-378D-A79D-85A361ADCD1F> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/TimeCarving.framework/Versions/A/TimeCarving
                       0x1209cc000 -        0x120aa5fff +com.adobe.dvaaudiofilterhost.framework (13.8.0 - 13.8.0.144) <4A2EA90C-6F30-3074-B45C-8891CF805D87> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
                       0x120ba0000 -        0x120be7ff7  com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <725265D0-1869-30A1-B27A-55CFA8FBF5A4> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
                       0x120c25000 -        0x120d7efe7  com.apple.mobiledevice (823.40.7 - 823.40.7) <39118395-1892-3CFC-9E9B-420BE768B648> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
                       0x120e0a000 -        0x120e41fff  com.apple.audio.midi.CoreMIDI (1.10 - 88) <51E79766-51D8-3A95-A7FD-18E7E11528F3> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
                       0x120e70000 -        0x120f7ffff  com.apple.AudioVideoBridging (403.4 - 403.4) <647EC44F-BC92-367C-AA25-E52085CC3EC6> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
                       0x121030000 -        0x121049fff  libexpat.1.dylib (12.60.1) <6BF318AC-F90F-3F16-99C2-6ADDE404E280> /usr/lib/libexpat.1.dylib
                       0x121055000 -        0x12105bfff  com.apple.TimeSync (1.0 - 403.4) <4E3FCB52-7F47-39A2-9C29-11CFE4823CC4> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
                       0x12106c000 -        0x12137ffff +com.mainconcept.mc.enc.avc (9.11 - 9.11.15.2139) <C3509A66-EE1D-3DE2-8E93-522998241663> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_enc_avc.framework/Versions/9/mc_enc_avc
                       0x1213e6000 -        0x1215ebfc7 +com.mainconcept.mc.dec.avc (9.11 - 9.11.15.2139) <24370293-7719-31FB-926C-4C18D2108904> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_dec_avc.framework/Versions/9/mc_dec_avc
                       0x1215f7000 -        0x1219d5fef +com.mainconcept.mc.mux.mp4 (9.11 - 9.11.15.2139) <8814047C-09F5-3D77-955E-EF3AE02C1BFA> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_mux_mp4.framework/Versions/9/mc_mux_mp4
                       0x121a01000 -        0x121bf9fff +com.adobe.CodecSupport.framework (13.8.0 - 13.8.0.144) <8EA7C167-3815-337C-9528-9FF492FFA40A> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/CodecSupport.framework/Versions/A/CodecSupport
                       0x121d34000 -        0x122215fc7 +libDNxHR.dylib (0) <16E89552-7DB0-3ABA-87A1-C9111E71CE84> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libDNxHR.dylib
                       0x1222f9000 -        0x1223d5fe7 +libmp4decMT.dylib (1.1.3) <A663DA9C-874F-742A-58B2-B5665D99CA03> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libmp4decMT.dylib
                       0x122431000 -        0x12253bfff +libCFHDDecoder.dylib (1) <0C9B6356-F555-39E0-9054-81E3FAC4DE55> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libCFHDDecoder.dylib
                       0x1225da000 -        0x1226dcfff +libCFHDEncoder.dylib (1) <A3B4AE2B-D61C-339A-8DD1-B2E523640425> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libCFHDEncoder.dylib
                       0x122788000 -        0x122916ff7 +com.mainconcept.mc.dec.mp2v (9.11 - 9.11.15.2139) <EA115FA0-B6DB-3E13-AEE4-E90373343BCC> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/9/mc_dec_mp2v
                       0x122921000 -        0x122ba4fcf +com.mainconcept.mc.bc.dec.avc (9.11 - 9.11.15.2139) <F4F2B962-59A1-3524-BC85-CB7B29238F86> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_bc_dec_avc.framework/Versions/9/mc_bc_dec_avc
                       0x122bb6000 -        0x122d86fff +com.mainconcept.mc.dec.mp4v (9.11 - 9.11.15.2139) <CE8BACDF-00FF-3773-A890-A698B23D40BB> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_dec_mp4v.framework/Versions/9/mc_dec_mp4v
                       0x122d95000 -        0x122e87fff +com.adobe.QT64Utils.framework (13.8.0 - 13.8.0.144) <D7184D87-B399-36F7-8B20-D7E7C8F7D2DE> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/QT64Utils.framework/Versions/A/QT64Utils
                       0x122ed8000 -        0x122f21fe7 +com.adobe.ProResOpt.framework (13.8.0 - 13.8.0.144) <EB9046D8-CEE7-3231-89C4-0079BE2649D6> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/ProResOpt.framework/Versions/A/ProResOpt
                       0x122f58000 -        0x1230b7ff7 +com.adobe.dvametadataDB.framework (13.8.0 - 13.8.0.144) <C0A7A150-BAAF-3F19-8D8D-B11DE4456E36> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
                       0x123101000 -        0x12315cff7 +com.adobe.boost_serialization.framework (13.8.0 - 13.8.0.144) <F6277BAC-4A73-3829-92FE-8B11C46A926D> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_serialization.framework/Versions/A/boost_serialization
                       0x12324a000 -        0x1233effff +com.adobe.RendererGPU.framework (13.8.0 - 13.8.0.144) <856F5747-6E68-3175-98C2-57977DBBA92A> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/RendererGPU.framework/Versions/A/RendererGPU
                       0x1234d4000 -        0x1234fbfff +com.adobe.dvaflashview.framework (13.8.0 - 13.8.0.144) <493D5DDB-A291-3E51-8D93-F19E8028DE51> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
                       0x123869000 -        0x12386bff7  com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                       0x12689e000 -        0x1268baff7  libJapaneseConverter.dylib (68) <D80D1583-1F6F-32A5-A683-F504A0DF973A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                       0x1268c0000 -        0x1268e2ff7  libKoreanConverter.dylib (68) <F29010B7-FABC-3CDA-95F5-85DC12B6C91B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                       0x1268e7000 -        0x1268f6ff7  libSimplifiedChineseConverter.dylib (68) <DCFEA0D3-593E-3E5C-B311-53B8ACF8A318> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                       0x1268fb000 -        0x12690dfff  libTraditionalChineseConverter.dylib (68) <62CEE84C-366B-3E43-821B-EE072DBF33D7> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                       0x126912000 -        0x126916fff  libFontRegistryUI.dylib (155.2) <8346E80E-5832-3944-A750-FBB9D328C2FE> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
                       0x12846e000 -        0x1284aeff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 9.0.0.15 - 9.0.0.15) <777D69DE-E701-3DAE-AF9C-7B7B48C0189C> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotificatio ns
                       0x128a43000 -        0x128a75ff7 +com.adobe.pip (7.4.1.12.44773) <85E2E357-3355-3A74-8F4E-2892E96CD632> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                       0x128a81000 -        0x128aaafff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
                       0x128ad4000 -        0x128ad8fff  com.apple.audio.AppleHDAHALPlugIn (274.12 - 274.12) <F5E4849C-6A2D-3D2C-AB3F-F608C0E49FD5> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                       0x128ea2000 -        0x128f56ff7  com.apple.AMDRadeonX4000GLDriver (1.42.15 - 1.4.2) <FD1F9EB4-0E1B-3B3D-A081-3B9EF8377E3F> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLD river
                       0x128f6e000 -        0x129449fff  ATIRadeonX4000SCLib.dylib (1.42.15) <FA3E48B8-DB4C-3335-A0EF-08882E3068BE> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCL ib.dylib
                       0x129f3b000 -        0x129f52fff +com.adobe.AfterEffects.MThread (???) <A50C0F1D-17CD-3ED5-BD7E-02A2428B5645> /Applications/Adobe After Effects CC 2015.3/*/Mthread.plugin/Contents/MacOS/MThread
                       0x12a0ba000 -        0x12a0bdfff +com.adobe.AfterEffects.EasyEase (???) <3631C26B-0017-3E5B-86D4-F82CF6AD100A> /Applications/Adobe After Effects CC 2015.3/*/EasyEase.plugin/Contents/MacOS/EasyEase
                       0x12a0ea000 -        0x12a0eeff7 +com.adobe.AfterEffects.ExpScale (???) <73AB0A40-931F-3D56-A656-0D9C99D984BF> /Applications/Adobe After Effects CC 2015.3/*/ExpScale.plugin/Contents/MacOS/ExpScale
                       0x12a0f4000 -        0x12a0fdff7 +com.adobe.AfterEffects.Sequence (???) <C213F986-71CB-3257-B7CA-3FAC784F3303> /Applications/Adobe After Effects CC 2015.3/*/Sequence.plugin/Contents/MacOS/Sequence
                       0x12a19e000 -        0x12a1a1fff +com.adobe.AfterEffects.TRKeys (???) <037A6C2C-FE7C-31F7-B6EC-D6897E993D9A> /Applications/Adobe After Effects CC 2015.3/*/TRKeys.plugin/Contents/MacOS/TRKeys
                       0x12a1a7000 -        0x12a1aafff +com.adobe.AfterEffects.Durer (???) <4949F12A-6F59-3FFE-8214-487D0F78BD03> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Standard3D.plugin/Contents/MacOS/Durer
                       0x12a1af000 -        0x12a1bbfff +com.adobe.AfterEffects.LocalizePresets (???) <6932AAFA-A82C-3A4F-BB4B-C8D0CEEB21CA> /Applications/Adobe After Effects CC 2015.3/*/LocalizePresets.plugin/Contents/MacOS/LocalizePresets
                       0x12a1c7000 -        0x12a1d8fff +com.adobe.AfterEffects.MayaImport (???) <8F3FFBBA-CD26-3978-9451-D65E39A13F86> /Applications/Adobe After Effects CC 2015.3/*/MayaImport.plugin/Contents/MacOS/MayaImport
                       0x12db01000 -        0x12dc4dfff +REDR3D.dylib (0) <AD8F1F3F-5071-4DD7-E3DC-897BF9C01951> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/REDR3D.dylib
                       0x12e700000 -        0x12e78cfff +REDCuda.dylib (0) <850185E9-FBF8-36CE-B1A1-6DCA75E23338> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/REDCuda.dylib
                       0x12e884000 -        0x12e8f2fff +libcudart.dylib (5) <3606C4C7-BA5A-5780-3DD6-0D01A11BD515> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/libcudart.dylib
                       0x12e8fd000 -        0x12ea8dff7 +REDOpenCL.dylib (0) <AAD3BAD6-2570-3735-9F06-F31025EB2084> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/REDOpenCL.dylib
                       0x12eaa0000 -        0x12eaa8fff +com.adobe.ExporterCoreAudio.framework (13.8.0 - 13.8.0.144) <6F8E00A4-2C9B-32F9-82A1-705870E96110> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCo reAudio
                       0x12eab4000 -        0x12eac3ff7 +com.adobe.AudioConverter.framework (13.8.0 - 13.8.0.144) <8D2F65F2-509C-340C-83AE-022ECEA27BA9> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
                       0x12ead5000 -        0x12ec05ffb  com.apple.audio.units.Components (1.13 - 1.13) <69FC51F9-E779-3940-AA27-8F97A9849D51> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
                       0x12ecc1000 -        0x12efbaff7  com.apple.audio.codecs.Components (6.0 - 6.0) <BF8186C2-6A22-33D0-9DD0-2E1FD25D175D> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
                       0x12f06f000 -        0x12f0c3fff +com.adobe.ExporterQuickTimeHost.framework (13.8.0 - 13.8.0.144) <49779073-3581-3012-8BDD-BC0C71D053E4> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/ExporterQuickTimeHost.bundle/Contents/MacOS/Export erQuickTimeHost
                       0x12f104000 -        0x12f121fff +com.adobe.QTWriter.framework (13.8.0 - 13.8.0.144) <A828ED4C-B363-3855-8EE9-2CA61CABD3F0> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/QTWriter.framework/Versions/A/QTWriter
                       0x12f14b000 -        0x12f17dfff +com.adobe.QTParser.framework (13.8.0 - 13.8.0.144) <F057A504-C5D7-3F75-9C56-BEE16EF41EEC> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
                       0x12f19d000 -        0x12f19fff7 +ImporterIllustratorAE (???) <B5B77401-5F64-3F1C-88FE-FBF63C83824B> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/ImporterIllustratorAE.bundle/Contents/MacOS/Import erIllustratorAE
                       0x12f1a5000 -        0x12f1aafff +ImporterPhotoshopAE (???) <C27767D3-6CE5-3F15-B6DF-4959B7C54580> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/ImporterPhotoshopAE.bundle/Contents/MacOS/Importer PhotoshopAE
                       0x13a47d000 -        0x13a84afe7 +com.adobe.ImporterQuickTime.framework (13.8.0 - 13.8.0.144) <81F55802-A759-3227-9CC2-5B031F0CE108> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/ImporterQuickTime.bundle/Contents/MacOS/ImporterQu ickTime
                       0x13aca7000 -        0x13aca9fff +com.adobe.TransmitDesktopAudio.framework (13.8.0 - 13.8.0.144) <C85660EA-2A0A-3410-9372-FF90FCB4CB29> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/TransmitDesktopAudio.bundle/Contents/MacOS/Transmi tDesktopAudio
                       0x13b062000 -        0x13b0c3fff +com.adobe.PlayerMediaCore.framework (13.8.0 - 13.8.0.144) <29770661-8662-37C2-BC38-4DBD07CF9A8E> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaC ore
                       0x13b11f000 -        0x13b152fff +com.adobe.RendererCPU.framework (13.8.0 - 13.8.0.144) <3A3AD132-0A81-32A2-AC17-C68C477C6064> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/RendererCPU.framework/Versions/A/RendererCPU
                       0x13b189000 -        0x13b19cff7 +com.adobe.TransmitDV.framework (13.8.0 - 13.8.0.144) <8D72E51A-41B9-3DB1-9EBB-09841094E36B> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/TransmitDV.bundle/Contents/MacOS/TransmitDV
                       0x13b1b5000 -        0x13b1ecff7  com.apple.AVCVideoServices (1.0 - 42) <89DBDE99-9EF0-304C-8836-09F3E78096AA> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
                       0x13b237000 -        0x13b23cfff +com.adobe.TransmitFullScreen.framework (13.8.0 - 13.8.0.144) <F4A9CAFB-6F4E-3887-9D6C-C84FD4267CA5> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/TransmitFullScreen.bundle/Contents/MacOS/TransmitF ullScreen
                       0x13b781000 -        0x13b7fbff7  com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
                       0x13ba04000 -        0x13e826fef +com.adobe.CameraRaw (9.6 [625] - 9.6f625) <B6A62987-00F1-32C6-8346-F535B2A1622F> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/MacOS/Camera Raw
                       0x13ef83000 -        0x13f02dfff +com.adobe.AfterEffects.AEGPDriver (???) <4574A348-0823-3BFA-A903-B7498670C7BE> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/AEGPDriver.plugin/Contents/MacOS/AEGPDriver
                       0x13f071000 -        0x13f0bcfff +com.adobe.AfterEffects.PS3Export (???) <F8703A5C-71C6-3F16-B162-5C2DF31119F1> /Applications/Adobe After Effects CC 2015.3/*/PS Layer Export.plugin/Contents/MacOS/PS3Export
                       0x13f0e1000 -        0x13f134fff +com.adobe.AfterEffects.PS3Import (???) <3046E12A-17C8-321B-9DAC-6C7FD12EEAEB> /Applications/Adobe After Effects CC 2015.3/*/PS Layer Import.plugin/Contents/MacOS/PS3Import
                       0x13f15a000 -        0x13f28cfff +CinewareAELiveLink (0) <B132725D-1CD9-35AA-9A88-510150BD82EE> /Applications/Adobe After Effects CC 2015.3/*/Cineware_AE_LiveLink.plugin/Contents/MacOS/Cineware_AE_LiveLink
                       0x13f336000 -        0x13f39eff7 +com.adobe.AfterEffects.Escher (???) <BFC1A493-86F0-3409-8454-B0B65EBEE934> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Advanced3D.plugin/Contents/MacOS/Escher
                       0x13f3bd000 -        0x13f4c8fff +com.adobe.AfterEffects.AEDynamicLinkServer (???) <2F1376AB-3F3F-3B0E-8C02-239ED59E9687> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/AEDynamicLinkServer.plugin/Contents/MacOS/AEDynamicLinkServer
                       0x13f543000 -        0x13f561fff +com.adobe.AfterEffects.AudioPal (???) <7BB0ECA4-740A-35F3-9CD4-9291EE5066B4> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Audio Palette.plugin/Contents/MacOS/AudioPal
                       0x13f58c000 -        0x13f5bfff7 +com.adobe.AfterEffects.BrushPal (???) <C4C92351-1C4B-32AC-9963-8A52838F1545> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Brush Palette.plugin/Contents/MacOS/BrushPal
                       0x13f5f0000 -        0x13f633fff +com.adobe.AfterEffects.CharPal (???) <0764039B-BBA1-36C5-9371-5E3DAAF5A0F3> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Character Palette.plugin/Contents/MacOS/CharPal
                       0x13f66f000 -        0x13f6b8fff +com.adobe.AfterEffects.InfoPal (???) <00191FC5-1F3B-39B3-9330-C2822D9FB4F6> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Info Palette.plugin/Contents/MacOS/InfoPal
                       0x13f6e3000 -        0x13f710ff7 +com.adobe.AfterEffects.PaintPal (???) <953A0DB1-20AD-3447-ADD1-26A280D6A5DC> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Paint Palette.plugin/Contents/MacOS/PaintPal
                       0x13f741000 -        0x13f765ff7 +com.adobe.AfterEffects.ParaPal (???) <873BCE79-7E3D-3181-AA4F-81C48C16924E> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Paragraph Palette.plugin/Contents/MacOS/ParaPal
                       0x13f78f000 -        0x13f7a7fff +com.adobe.AfterEffects.ProgressPal (???) <9A74C53E-DBDF-332B-BA68-3FB22BC95665> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Progress Palette.plugin/Contents/MacOS/ProgressPal
                       0x13f7cf000 -        0x13f7f6fff +com.adobe.AfterEffects.TrackerPal (???) <937A342B-7525-3001-A98E-1A198F6C51FF> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Tracker Palette.plugin/Contents/MacOS/TrackerPal
                       0x13f81d000 -        0x13f822ff7 +com.adobe.AfterEffects.RPFImport (???) <2F122B64-C181-3FAB-9D8A-338033EEA51E> /Applications/Adobe After Effects CC 2015.3/*/RPFImport.plugin/Contents/MacOS/RPFImport
                       0x13f87f000 -        0x13f908fff +com.adobe.AfterEffects.Picasso (???) <5E142028-9C20-3A7B-AD2D-2ED06CA7E95F> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Picasso.plugin/Contents/MacOS/Picasso
                       0x13f92d000 -        0x13fc3aff7 +com.adobe.AfterEffects.SnapCut (???) <0416D21D-FF86-396D-BC34-9D977178ACC1> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Roto Brush.plugin/Contents/MacOS/SnapCut
                       0x13fcf9000 -        0x13fd29ff7 +com.adobe.AfterEffects.TimePal (???) <E065FA10-AB2B-3147-A233-3434F49D8D29> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Time Palette.plugin/Contents/MacOS/TimePal
                       0x13fd5c000 -        0x13fdb2ff7 +com.adobe.AfterEffects.ToolPal (???) <8110F260-3C10-37A8-ABC5-AF0C93AFF01F> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Tool Palette.plugin/Contents/MacOS/ToolPal
                       0x13fdfd000 -        0x13fe1afff +com.adobe.AfterEffects.WorkQueuePal (???) <524D9627-8845-349F-863D-3DA01004CD88> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/WorkQueue Palette.plugin/Contents/MacOS/WorkQueuePal
                       0x13fe43000 -        0x141280ff7 +com.imagineersystems.mochashapeconverter4ae (4.0.2 - 4.0.2f10148) <777F7A9B-78A7-3238-9D4E-474F191E7973> /Applications/Adobe After Effects CC 2015.3/*/mocha shape converter for AE.plugin/Contents/MacOS/mochashapeconverter4ae
                       0x141497000 -        0x14157cfff +com.adobe.AfterEffects.Anywhere2 (???) <13A8B337-CD66-3967-A605-08C9DEDD92A5> /Applications/Adobe After Effects CC 2015.3/*/Anywhere2.plugin/Contents/MacOS/Anywhere2
                       0x1415e8000 -        0x14168efff +com.adobe.AfterEffects.CEPManager (???) <053D39C5-217C-356B-875C-04AEE1DD1503> /Applications/Adobe After Effects CC 2015.3/*/CEPManager.plugin/Contents/MacOS/CEPManager
                       0x1416e4000 -        0x14182ffff +IMSLib.dylib (10.0.0.7 - 10.0.0.7) <1DD294BF-3FEB-3BBF-A27C-94D2445CB4B4> /Library/Application Support/Adobe/*/IMSLib.dylib
                       0x1418c6000 -        0x141932fff +com.adobe.AfterEffects.Renoir (???) <23971CC9-5AF8-3F5E-BF47-CFD14B5C1994> /Applications/Adobe After Effects CC 2015.3/*/Renoir.plugin/Contents/MacOS/Renoir
                       0x1419b5000 -        0x141bd2fef +com.adobe.AfterEffects.OpenEXR (???) <415CEBC3-0C65-C2B9-DA34-EF176DF31828> /Applications/Adobe After Effects CC 2015.3/*/OpenEXR.plugin/Contents/MacOS/OpenEXR
                       0x141dc1000 -        0x141dfcfff +com.adobe.AfterEffects.PNGIO (???) <2D1E91AE-970F-30F4-BC48-D117449B1902> /Applications/Adobe After Effects CC 2015.3/*/PNGIO.plugin/Contents/MacOS/PNGIO
                       0x141e0c000 -        0x141eddfff +com.adobe.AfterEffects.PremiereProImport (???) <E0AF50D8-23D9-38F9-B232-76332B239546> /Applications/Adobe After Effects CC 2015.3/*/PremiereProImport.plugin/Contents/MacOS/PremiereProImport
                       0x141f1f000 -        0x142381fed +com.adobe.ProImportAE (Pro Import AE version 8.00 - 8.00) <AC4080BD-55B3-9433-7BE1-371B4F0A5629> /Applications/Adobe After Effects CC 2015.3/*/Pro Import AE.plugin/Contents/MacOS/Pro Import AE
                       0x142531000 -        0x14259dfff +com.adobe.AfterEffects.TIFFIO (???) <05DF7708-EDBB-3C39-9DE8-3C4F7F22891A> /Applications/Adobe After Effects CC 2015.3/*/TIFF.plugin/Contents/MacOS/TIFFIO
                       0x1425bb000 -        0x1425dafff +com.adobe.AfterEffects.Align (???) <AAA02A5E-8A6D-39C1-B300-359AE339CE8D> /Applications/Adobe After Effects CC 2015.3/*/Align.plugin/Contents/MacOS/Align
                       0x1425fe000 -        0x142613ff7 +com.adobe.AfterEffects.Analyzer (???) <15A94A6C-8B35-3A31-930A-B1090A68C61E> /Applications/Adobe After Effects CC 2015.3/*/Analyzer.plugin/Contents/MacOS/Analyzer
                       0x142630000 -        0x14264eff7 +com.adobe.AfterEffects.MediaBrowser (???) <0A6DCE38-D0EE-3B74-B3DD-828AD83F28D1> /Applications/Adobe After Effects CC 2015.3/*/MediaBrowser.plugin/Contents/MacOS/MediaBrowser
                       0x142679000 -        0x142693ff7 +com.adobe.AfterEffects.MetaPal (???) <2A3C1B5B-AEB0-3D23-BD20-B86418E830DB> /Applications/Adobe After Effects CC 2015.3/*/MetaPal.plugin/Contents/MacOS/MetaPal
                       0x1426be000 -        0x1426f1fff +com.adobe.AfterEffects.Moka (???) <72135253-8760-35C3-8E58-19B88A3FA681> /Applications/Adobe After Effects CC 2015.3/*/Moka.plugin/Contents/MacOS/Moka
                       0x142719000 -        0x142730ff7 +com.adobe.AfterEffects.MotionSketch (???) <EBF2726B-0242-3E5C-A1FA-66EAF8CB8E6A> /Applications/Adobe After Effects CC 2015.3/*/MotionSketch.plugin/Contents/MacOS/MotionSketch
                       0x142752000 -        0x14276dfff +com.adobe.AfterEffects.RQMonitor (???) <4254F509-E401-3B72-8FD9-13E4ED23CDF3> /Applications/Adobe After Effects CC 2015.3/*/RQMonitor.plugin/Contents/MacOS/RQMonitor
                       0x14277a000 -        0x142d44fff +com.adobe.AfterEffects.Scripting (???) <D35BBB19-5367-3BDF-ADE1-6845C34CDB61> /Applications/Adobe After Effects CC 2015.3/*/Scripting.plugin/Contents/MacOS/Scripting
                       0x1430eb000 -        0x143111ff7 +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <40A59819-7A57-0E9F-658D-1803B2A461AE> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
                       0x1435de000 -        0x1436e0ff7  com.apple.AMDMTLBronzeDriver (1.42.15 - 1.4.2) <203DB752-C67A-3BD2-87DC-700B14CA24F2> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
                       0x1437e7000 -        0x1437fffff +com.adobe.AfterEffects.Smoother (???) <28086A52-4332-3669-9702-617C4EAE0C57> /Applications/Adobe After Effects CC 2015.3/*/Smoother.plugin/Contents/MacOS/Smoother
                       0x143822000 -        0x14383cff7 +com.adobe.AfterEffects.Wiggler (???) <BA3F90FC-8DBE-3F3E-A82C-972424173CE7> /Applications/Adobe After Effects CC 2015.3/*/Wiggler.plugin/Contents/MacOS/Wiggler
                       0x143860000 -        0x1439caff7 +CinewareAEExporter (0) <7C2E5629-DAB6-379C-8F9B-44A4628E4E73> /Applications/Adobe After Effects CC 2015.3/*/Cineware_AE_Exporter.plugin/Contents/MacOS/Cineware_AE_Exporter
                       0x143a86000 -        0x143beafff +CinewareAESceneLayer (0) <55C0DDC4-5862-3D9F-9BD0-CA61F689B065> /Applications/Adobe After Effects CC 2015.3/*/Cineware_AE_SceneLayer.plugin/Contents/MacOS/Cineware_AE_SceneLayer
                       0x143ca0000 -        0x143d60fef +com.digitalanarchy.BoxCreator (1.4.5 - 1.4.5) <60F65408-5A26-343B-AEC2-D3B4ED1B78CA> /Library/Application Support/Adobe/*/BoxCreator.plugin/Contents/MacOS/BoxCreator
                       0x143dfb000 -        0x143ebbfef +com.digitalanarchy.BoxCreator_Lite (1.4.5 - 1.4.5) <4AAD2802-0E47-3D88-A465-2617FDCBAE11> /Library/Application Support/Adobe/*/BoxCreator_Lite.plugin/Contents/MacOS/BoxCreator_Lite
                       0x143f56000 -        0x144014fe7 +com.digitalanarchy.CubicDistribution (1.4.5 - 1.4.5) <C3FC0B8A-D61A-30A0-8327-CBE2C12BD67F> /Library/Application Support/Adobe/*/CubicDistribution.plugin/Contents/MacOS/CubicDistribution
                       0x1440af000 -        0x14416efe7 +com.digitalanarchy.CubicDistribution_Lite (1.4.5 - 1.4.5) <AC78328C-282F-3E5F-9A08-2E1F8C422E5D> /Library/Application Support/Adobe/*/CubicDistribution_Lite.plugin/Contents/MacOS/CubicDistribution_Lite
                       0x144209000 -        0x1442caff7 +com.digitalanarchy.CylinderCreator (1.4.5 - 1.4.5) <68BACD9E-9AAB-33B9-BC85-6B184F74ABC4> /Library/Application Support/Adobe/*/CylinderCreator.plugin/Contents/MacOS/CylinderCreator
                       0x144365000 -        0x144426ff7 +com.digitalanarchy.CylinderCreator_Lite (1.4.5 - 1.4.5) <CE206CE1-5A5F-3649-A9F6-DF065F5C432D> /Library/Application Support/Adobe/*/CylinderCreator_Lite.plugin/Contents/MacOS/CylinderCreator_Lite
                       0x1444c1000 -        0x144580fff +com.digitalanarchy.CylinderDistribution (1.4.5 - 1.4.5) <45EE336B-8F42-31D7-B0F6-A4814FF01046> /Library/Application Support/Adobe/*/CylinderDistribution.plugin/Contents/MacOS/CylinderDistribution
                       0x14461b000 -        0x1446dbfef +com.digitalanarchy.LinearAssistant (1.4.5 - 1.4.5) <A3C580A8-D8BD-30AB-A103-EC81EE6F62DF> /Library/Application Support/Adobe/*/LinearAssistant.plugin/Contents/MacOS/LinearAssistant
                       0x144776000 -        0x144836fef +com.digitalanarchy.LinearAssistant_Lite (1.4.5 - 1.4.5) <DED72748-8DC2-345D-B068-42F780CB18C4> /Library/Application Support/Adobe/*/LinearAssistant_Lite.plugin/Contents/MacOS/LinearAssistant_Lite
                       0x1448d1000 -        0x14498fff7 +com.digitalanarchy.MatrixCreator (1.4.5 - 1.4.5) <0B635EB5-9316-336C-9A79-96AE38A42CC0> /Library/Application Support/Adobe/*/MatrixCreator.plugin/Contents/MacOS/MatrixCreator
                       0x144a2a000 -        0x144ae8fe7 +com.digitalanarchy.MatrixCreator_Lite (1.4.5 - 1.4.5) <27915AA7-F38F-39E6-B6EF-6392A468408B> /Library/Application Support/Adobe/*/MatrixCreator_Lite.plugin/Contents/MacOS/MatrixCreator_Lite
                       0x144b83000 -        0x144c41fef +com.digitalanarchy.PlanarAssistant (1.4.5 - 1.4.5) <98842301-3110-3545-B680-F19B1C23A60D> /Library/Application Support/Adobe/*/PlanarAssistant.plugin/Contents/MacOS/PlanarAssistant
                       0x144cdc000 -        0x144d9cfe7 +com.digitalanarchy.PyramidDistribution (1.4.5 - 1.4.5) <235A48F4-E2D4-3AAF-9ECB-A1621653506B> /Library/Application Support/Adobe/*/PyramidDistribution.plugin/Contents/MacOS/PyramidDistribution
                       0x144e37000 -        0x144efcfff +com.digitalanarchy.SpheroidCreator (1.4.5 - 1.4.5) <8EC4576D-9AD8-3D3D-B385-99AA404F94E4> /Library/Application Support/Adobe/*/SpheroidCreator.plugin/Contents/MacOS/SpheroidCreator
                       0x144f98000 -        0x14505dfff +com.digitalanarchy.SpheroidCreator_Lite (1.4.5 - 1.4.5) <06A4BF08-4E48-3A5D-8F70-0148164A95E4> /Library/Application Support/Adobe/*/SpheroidCreator_Lite.plugin/Contents/MacOS/SpheroidCreator_Lite
                       0x1450f9000 -        0x1451baff7 +com.digitalanarchy.SpheroidDistribution (1.4.5 - 1.4.5) <32667EF7-A936-387F-8F3C-DD0FD3117664> /Library/Application Support/Adobe/*/SpheroidDistribution.plugin/Contents/MacOS/SpheroidDistribution
                       0x145b93000 -        0x145bc6ff7 +com.adobe.ImporterMPEG.framework (13.8.0 - 13.8.0.144) <39C00D8A-4AA4-3293-80C3-CC9770A026B3> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/ImporterMPEG.bundle/Contents/MacOS/ImporterMPEG
                       0x146a28000 -        0x146a64fff +com.mainconcept.mc.dec.aac (9.11 - 9.11.15.2139) <B846E97C-0C2E-35A9-B617-E632106C8521> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_dec_aac.framework/mc_dec_aac
                       0x147df4000 -        0x147fc7fe7 +com.adobe.AfterEffects.Tracker3d (???) <ABA0BE2E-84E5-304E-A50E-2B3A32205B0E> /Applications/Adobe After Effects CC 2015.3/*/3D Camera Tracker.plugin/Contents/MacOS/Tracker3d
                       0x14f099000 -        0x14f0f0ff7 +com.adobe.AfterEffects.FreePin (???) <531CB14E-1487-3065-986C-696A9EAFF2D8> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/Puppet.plugin/Contents/MacOS/FreePin
                       0x14f105000 -        0x14f2d8ff7 +com.adobe.AfterEffects.RefineMatte (???) <2EE3995E-4AA3-3F7D-9213-7459B3DABBCE> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/RefineMatte.plugin/Contents/MacOS/RefineMatte
                       0x14f330000 -        0x14f602fff +com.adobe.AfterEffects.RefineMatte2 (???) <A952A48F-661B-3912-AF2F-384EC004141F> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Required/RefineMatte2.plugin/Contents/MacOS/RefineMatte2
                       0x14f6b3000 -        0x14f827ff7 +CinewareAEEffect (0) <979FDF8F-AB34-35FC-9201-311CC2137FCD> /Applications/Adobe After Effects CC 2015.3/*/Cineware_AE_Effect.plugin/Contents/MacOS/Cineware_AE_Effect
                       0x176cb9000 -        0x176f5dfe7 +com.mainconcept.mc.demux.mp4 (9.11 - 9.11.15.2139) <CEC5EFE9-C090-30D3-B8E2-3C71B15A82BA> /Applications/Adobe After Effects CC 2015.3/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_demux_mp4.framework/Versions/9/mc_demux_mp4
                    0x7fff61ef1000 -     0x7fff61f28a47  dyld (360.22) <DC81CC9D-651A-3A45-8809-928282052BD3> /usr/lib/dyld
                    0x7fff82715000 -     0x7fff8273eff7  libxpc.dylib (765.50.8) <54D1328E-054E-3DAA-89E2-375722F9D18F> /usr/lib/system/libxpc.dylib
                    0x7fff8273f000 -     0x7fff8274bfff  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                    0x7fff8274c000 -     0x7fff82c0afcf  com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                    0x7fff82c36000 -     0x7fff82c5dfff  com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                    0x7fff83619000 -     0x7fff8361bff7  com.apple.xpc.ServiceManagement (1.0 - 1) <D96D7A6D-EDEB-35EE-B5D9-E33A3BF011B5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                    0x7fff8361c000 -     0x7fff83627fff  libcsfde.dylib (517.50.1) <52F0DB6A-13B8-355E-ADFD-72834D3CA183> /usr/lib/libcsfde.dylib
                    0x7fff83628000 -     0x7fff838c2ff3  com.apple.security (7.0 - 57337.60.2) <E2E553E7-28C4-3296-B3B6-BB1B3CA73943> /System/Library/Frameworks/Security.framework/Versions/A/Security
                    0x7fff83942000 -     0x7fff839f2fff  com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                    0x7fff83b23000 -     0x7fff83b72ff7  com.apple.opencl (2.7.0 - 2.7.0) <39581F1A-04FE-3CCA-9118-E9BB9053F7A1> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                    0x7fff83b73000 -     0x7fff83be7ff3  com.apple.securityfoundation (6.0 - 55126) <DAA4FDD0-7F84-30AA-BE6F-96BB9F871F07> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                    0x7fff83be8000 -     0x7fff83be9fff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                    0x7fff83c2e000 -     0x7fff83dbaff7  libGLProgrammability.dylib (12.1) <BCFFBF6B-9717-3456-B6F9-6AE46644B076> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                    0x7fff83e99000 -     0x7fff83ec2fff  libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
                    0x7fff840cb000 -     0x7fff84436657  libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
                    0x7fff84437000 -     0x7fff8443affb  libdyld.dylib (360.22) <1F9FCF2C-5E94-3F2D-B4A5-1238587AA5C6> /usr/lib/system/libdyld.dylib
                    0x7fff84442000 -     0x7fff84494fff  com.apple.AppleVAFramework (5.0.32 - 5.0.32) <271ED7A9-73E5-3595-A8D6-28594C9F3C9D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                    0x7fff844ba000 -     0x7fff844c5fff  libkxld.dylib (3248.60.10) <991CDFE9-AB87-321B-A4B2-5EFE64DDCF74> /usr/lib/system/libkxld.dylib
                    0x7fff846d2000 -     0x7fff848dffff  libicucore.A.dylib (551.51.4) <3899B146-3840-3D4A-8C4A-FE391D5D25C7> /usr/lib/libicucore.A.dylib
                    0x7fff84970000 -     0x7fff84978fff  com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                    0x7fff84979000 -     0x7fff8497bff7  libRadiance.dylib (1459) <1FE4F408-D135-3CA5-A06B-B0FCE974997C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                    0x7fff849b3000 -     0x7fff849befff  libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                    0x7fff849c2000 -     0x7fff84a17fff  com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                    0x7fff84a18000 -     0x7fff84a20fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                    0x7fff84a21000 -     0x7fff84a4efff  libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
                    0x7fff84a76000 -     0x7fff84a90fff  com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                    0x7fff84a91000 -     0x7fff84ebffff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                    0x7fff84ec2000 -     0x7fff851b7fff  com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                    0x7fff856ef000 -     0x7fff85af1fff  libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                    0x7fff85b1f000 -     0x7fff85bd8ff7  com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
                    0x7fff86390000 -     0x7fff863a1fff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
                    0x7fff863a2000 -     0x7fff863a4fff  com.apple.CoreDuetDebugLogging (1.0 - 1) <7C932160-AC9C-3173-900F-98138E829CB3> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebug Logging
                    0x7fff863cb000 -     0x7fff86411ff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
                    0x7fff86c58000 -     0x7fff86ca3ff7  com.apple.CoreMediaIO (703.0 - 4791) <D8BC511D-0C1E-3686-9829-C874FDBE94CB> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                    0x7fff86d39000 -     0x7fff86e83ff7  com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                    0x7fff86e84000 -     0x7fff86f3cff7  com.apple.CoreDuet (1.0 - 1) <FC1EAEE1-73A4-3B13-A634-1D2A94D0C0B7> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
                    0x7fff86f52000 -     0x7fff86f6eff7  libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
                    0x7fff86f7a000 -     0x7fff86faeff7  com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                    0x7fff87206000 -     0x7fff8722ffff  com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                    0x7fff87234000 -     0x7fff8725dff7  libxslt.1.dylib (14.4) <72CD1CA4-1FBD-3672-ADCE-A89AB741689A> /usr/lib/libxslt.1.dylib
                    0x7fff8725e000 -     0x7fff87263ff7  com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
                    0x7fff87265000 -     0x7fff872f2dd7  com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                    0x7fff87323000 -     0x7fff875aafff  com.apple.CFNetwork (760.6.3 - 760.6.3) <8CB9CB2E-D0FB-31D4-A1AE-2A5FE028AD6B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                    0x7fff87627000 -     0x7fff87643ff7  libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
                    0x7fff87644000 -     0x7fff876e8fff  com.apple.Bluetooth (4.4.6 - 4.4.6f1) <F8E54D34-DAAB-319F-8AE7-F3C55CA0CC68> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                    0x7fff876f5000 -     0x7fff87748ff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
                    0x7fff8789f000 -     0x7fff878a7fff  libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
                    0x7fff87940000 -     0x7fff87bd1ff7  com.apple.RawCamera.bundle (6.20 - 856) <C66E7CF9-0352-3A5A-AD2B-DE16136EA6B1> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                    0x7fff87bd2000 -     0x7fff87bf7ff7  libPng.dylib (1459) <F98F6D50-BC82-3ED7-885F-FEE708E401CC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                    0x7fff87c10000 -     0x7fff87c10fff  com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                    0x7fff87c11000 -     0x7fff87c19fff  libGFXShared.dylib (12.1) <5A0C2493-200C-30BE-97D5-8E8C0B8E604D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                    0x7fff87c1a000 -     0x7fff87c26fff  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                    0x7fff87d87000 -     0x7fff87d87fff  com.apple.CoreServices (728.13 - 728.13) <E3DFECD2-ECEA-3242-972D-95B9646B57B8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                    0x7fff87d88000 -     0x7fff87db7ff7  com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                    0x7fff88090000 -     0x7fff8809bfff  com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                    0x7fff884c9000 -     0x7fff88517fff  libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
                    0x7fff88525000 -     0x7fff885dffff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                    0x7fff885e0000 -     0x7fff885e1fff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
                    0x7fff885e2000 -     0x7fff886deff7  libFontParser.dylib (158.6) <267A9AE4-4138-3112-8D73-BDFDC96568FF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                    0x7fff886e3000 -     0x7fff88778fff  com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                    0x7fff88908000 -     0x7fff88b29ff7  com.apple.CoreImage (11.4.0 - 366.4.19) <F5B7B115-E43A-3C61-A6AD-EFCDE7FC43A1> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                    0x7fff88b40000 -     0x7fff88b69ffb  libRIP.A.dylib (960.3) <702967FB-D16C-38C7-A3CC-0EC336740A69> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                    0x7fff88b6a000 -     0x7fff88c4aff7  unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba .dylib
                    0x7fff88c4b000 -     0x7fff88c5bfff  libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                    0x7fff88c82000 -     0x7fff88cc7ff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                    0x7fff88d3b000 -     0x7fff88d40fff  com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                    0x7fff88d41000 -     0x7fff88dacff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                    0x7fff88dad000 -     0x7fff88dccff7  com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                    0x7fff88dcd000 -     0x7fff88dd8fff  libGPUSupportMercury.dylib (12.1) <9D35C668-4F21-31C8-890C-CC1F45905194> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                    0x7fff89081000 -     0x7fff89097fff  com.apple.CoreMediaAuthoring (2.2 - 953) <5103EF2E-BB0A-302B-B8BB-CED301BC746B> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                    0x7fff89098000 -     0x7fff8909bffb  libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
                    0x7fff891d4000 -     0x7fff891f2ff7  libsystem_kernel.dylib (3248.60.10) <C1A6A0B9-1869-36AB-B4A2-D862EB09A4BE> /usr/lib/system/libsystem_kernel.dylib
                    0x7fff891f3000 -     0x7fff8920dff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
                    0x7fff8920e000 -     0x7fff8923dffb  libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
                    0x7fff8923e000 -     0x7fff89407ff7  com.apple.ImageIO.framework (3.3.0 - 1459) <72B4D556-2600-3CA0-89F1-6BA24A4274B3> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                    0x7fff89408000 -     0x7fff8946eff7  libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
                    0x7fff8946f000 -     0x7fff894d2fff  libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
                    0x7fff89897000 -     0x7fff89986ff7  libxml2.2.dylib (29.10) <B3B03292-7E1A-34AB-888C-3D49D63D60C6> /usr/lib/libxml2.2.dylib
                    0x7fff89996000 -     0x7fff8999dff7  libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
                    0x7fff89a2f000 -     0x7fff89a3aff7  libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
                    0x7fff89a5a000 -     0x7fff89aa6ffb  com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                    0x7fff89aa7000 -     0x7fff89c67ffb  libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                    0x7fff89c68000 -     0x7fff89d8ffff  com.apple.LaunchServices (728.13 - 728.13) <DF9A69C3-06AD-3062-A40A-50ED12CA18CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                    0x7fff89d90000 -     0x7fff89dadff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <41378C0B-B56A-3A73-9BD0-E06FA1F87B8C> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
                    0x7fff89dae000 -     0x7fff89db0ff7  libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
                    0x7fff89dc2000 -     0x7fff89dc2ff7  libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
                    0x7fff89dc3000 -     0x7fff89dc3fff  libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
                    0x7fff89dc4000 -     0x7fff89dc7fff  com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                    0x7fff89dc8000 -     0x7fff89df6ff7  libsandbox.1.dylib (460.60.2) <DAB5D6F4-CDA9-3AEB-83FF-88F003D5B5E5> /usr/lib/libsandbox.1.dylib
                    0x7fff89df7000 -     0x7fff89e03ff7  com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                    0x7fff89e04000 -     0x7fff89e41ff3  com.apple.bom (14.0 - 193.7) <9B8AE30B-24A3-37AB-B04E-4CE67AED4775> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                    0x7fff89e67000 -     0x7fff89f84fff  libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
                    0x7fff89fd2000 -     0x7fff8a049ff7  com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
                    0x7fff8a123000 -     0x7fff8a135fff  libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
                    0x7fff8a136000 -     0x7fff8a14afff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <1D60D60C-914A-3BAB-8607-79F68F4C712E> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDae monProtocol
                    0x7fff8a14b000 -     0x7fff8a14eff7  libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                    0x7fff8a14f000 -     0x7fff8a15ffff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
                    0x7fff8a160000 -     0x7fff8a16fffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                    0x7fff8a170000 -     0x7fff8a1cbff7  libTIFF.dylib (1459) <CA5015CC-A770-3A62-BABD-B5A88AD390E6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                    0x7fff8a1cc000 -     0x7fff8a1ccfff  com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                    0x7fff8a5b9000 -     0x7fff8a5bbfff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                    0x7fff8a5bf000 -     0x7fff8a5cdfff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
                    0x7fff8a5ce000 -     0x7fff8aa69ffb  com.apple.GeoServices (1.0 - 1151.49.1) <2D887517-B73D-30FF-91DC-AF6AD91F96B9> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                    0x7fff8aabb000 -     0x7fff8aad0ff3  libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                    0x7fff8aad1000 -     0x7fff8aaf3fff  com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                    0x7fff8aaf4000 -     0x7fff8aaf9ff7  libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
                    0x7fff8aafa000 -     0x7fff8ac78fff  com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                    0x7fff8ac96000 -     0x7fff8ac9bff7  libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
                    0x7fff8ad13000 -     0x7fff8ad63ff7  com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                    0x7fff8ad8e000 -     0x7fff8add0ff7  com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                    0x7fff8add1000 -     0x7fff8ae04ff7  com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                    0x7fff8ae27000 -     0x7fff8ae30ff7  com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                    0x7fff8b58d000 -     0x7fff8b58dff7  liblaunch.dylib (765.50.8) <834ED605-5114-3641-AA4D-ECF31B801C50> /usr/lib/system/liblaunch.dylib
                    0x7fff8b58e000 -     0x7fff8b591fff  libspindump.dylib (197.1) <48F4C673-9F0C-38BE-B550-88241E812518> /usr/lib/libspindump.dylib
                    0x7fff8b5f4000 -     0x7fff8b5f4fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                    0x7fff8b6ed000 -     0x7fff8b6f6fff  com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
                    0x7fff8b6f7000 -     0x7fff8b710fe7  libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
                    0x7fff8b711000 -     0x7fff8b778fff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                    0x7fff8b779000 -     0x7fff8b781fff  libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
                    0x7fff8b87b000 -     0x7fff8b8ccff7  libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
                    0x7fff8b8cd000 -     0x7fff8b8ceffb  libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
                    0x7fff8b8d5000 -     0x7fff8b921ff7  com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
                    0x7fff8b9b8000 -     0x7fff8b9bafff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
                    0x7fff8b9cb000 -     0x7fff8b9d3fff  libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
                    0x7fff8b9d4000 -     0x7fff8ba61fef  libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
                    0x7fff8ba92000 -     0x7fff8bb39fff  com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                    0x7fff8bfbc000 -     0x7fff8bfbefff  libCVMSPluginSupport.dylib (12.1) <D81B3D8D-B83F-3918-BD4B-6C794A30AF9F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                    0x7fff8c84f000 -     0x7fff8ca5afff  libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
                    0x7fff8ca77000 -     0x7fff8ca77fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                    0x7fff8ca78000 -     0x7fff8cdccfff  com.apple.Foundation (6.9 - 1259) <71A9D3A0-0B1F-3E3A-86F3-1486365A6EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                    0x7fff8d0e0000 -     0x7fff8d0eeff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
                    0x7fff8d0ef000 -     0x7fff8d0f2fff  com.apple.IOSurface (108.2.3 - 108.2.3) <52E51D16-42E9-3DDB-A16C-48225EF262C4> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                    0x7fff8d0f8000 -     0x7fff8d0fafff  libCGXType.A.dylib (960.3) <70FA6D91-53BC-3DA6-92F3-7FEB33C73948> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
                    0x7fff8d0fb000 -     0x7fff8d15bfff  com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                    0x7fff8d194000 -     0x7fff8d1e5fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                    0x7fff8d1e9000 -     0x7fff8d2dbff7  libJP2.dylib (1459) <90B4DD14-4D0B-3373-B1B6-DC8F53D78565> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                    0x7fff8d2dc000 -     0x7fff8d2f3ff7  libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
                    0x7fff8d3b5000 -     0x7fff8d4a7ff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
                    0x7fff8d4a8000 -     0x7fff8d4a8fff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                    0x7fff8d7df000 -     0x7fff8d7e0ffb  libSystem.B.dylib (1226.10.1) <ECAA07BE-A114-3461-AA13-C57838775FC2> /usr/lib/libSystem.B.dylib
                    0x7fff8d7e1000 -     0x7fff8d7e6fff  com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                    0x7fff8d8d3000 -     0x7fff8db69fff  libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
                    0x7fff8dc1d000 -     0x7fff8dc6bff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
                    0x7fff8dd0a000 -     0x7fff8dd2efff  com.apple.MultitouchSupport.framework (304.12 - 304.12) <65CB7653-EACD-3ADB-ABB6-2E0671708301> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                    0x7fff8ddab000 -     0x7fff8ddacfff  libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
                    0x7fff8ddad000 -     0x7fff8de4dfff  com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                    0x7fff8e057000 -     0x7fff8e067ff3  com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                    0x7fff8e068000 -     0x7fff8e07eff7  libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                    0x7fff8e07f000 -     0x7fff8e108ff7  com.apple.PerformanceAnalysis (1.0 - 1) <1BC106BB-3C7F-37C9-8496-43F584A6F304> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                    0x7fff8e109000 -     0x7fff8e114fff  com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                    0x7fff8e134000 -     0x7fff8e138fff  libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
                    0x7fff8e139000 -     0x7fff8e14aff7  libsystem_trace.dylib (201.10.3) <1DD0C1FD-74E2-3949-9C2C-B81D19C2CA5E> /usr/lib/system/libsystem_trace.dylib
                    0x7fff8e151000 -     0x7fff8e152fff  libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
                    0x7fff8e181000 -     0x7fff8e1b1ff3  com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                    0x7fff8e25e000 -     0x7fff8e40aff7  com.apple.avfoundation (2.0 - 1046.9.12) <2D241BC4-A619-3382-BABD-C4E4490BD638> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                    0x7fff8e40b000 -     0x7fff8e479ff7  com.apple.ApplicationServices.ATS (377 - 394.4) <9779E916-0788-3CAC-B1EC-F68BCB12A2B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                    0x7fff8e48e000 -     0x7fff8e52efff  com.apple.Metadata (10.7.0 - 972.34) <A58195C5-5D5C-32D5-8BBB-F4D32201E5AA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                    0x7fff8e533000 -     0x7fff8f799ff3  com.apple.CoreGraphics (1.600.0 - 960.3) <A2DA51BA-7A97-33B9-97A1-979F6401989C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                    0x7fff8f7c7000 -     0x7fff8f7feff7  com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                    0x7fff8f955000 -     0x7fff8fa9afff  com.apple.QTKit (7.7.3 - 2943.12) <79EA2D04-09EC-3266-A5F7-A4AACA97FE1E> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                    0x7fff8faf2000 -     0x7fff8fb0efff  com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                    0x7fff8fc2d000 -     0x7fff8fce6ff7  libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                    0x7fff8fce7000 -     0x7fff8fcecfff  com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                    0x7fff8fced000 -     0x7fff8fcf8ff7  libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
                    0x7fff8fd07000 -     0x7fff8fd10fff  com.apple.IOAccelMemoryInfo (1.0 - 1) <5938394C-EAF4-37C7-A335-62D9A5DEC196> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInf o
                    0x7fff8fd11000 -     0x7fff8fd11fff  libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
                    0x7fff8fd12000 -     0x7fff8fe3fff3  com.apple.CoreText (352.0 - 494.12) <ADBE8355-D4F5-3316-A6C4-D641D615CEC4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                    0x7fff8fe40000 -     0x7fff8fe41fff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
                    0x7fff8ff4d000 -     0x7fff8ff5bfff  com.apple.opengl (12.1.0 - 12.1.0) <0718DB60-BA4F-3CF7-A117-10A2515D931F> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                    0x7fff8ff5c000 -     0x7fff8ff5eff7  libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
                    0x7fff8ff5f000 -     0x7fff8ff67fff  com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                    0x7fff8ff85000 -     0x7fff8ff8eff3  libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
                    0x7fff8ff8f000 -     0x7fff90274ffb  com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                    0x7fff90275000 -     0x7fff9027dffb  libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
                    0x7fff9027e000 -     0x7fff902a9ffb  libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
                    0x7fff90348000 -     0x7fff9034dff3  libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
                    0x7fff905ea000 -     0x7fff90679ff7  libCoreStorage.dylib (517.50.1) <E6283FE9-B5AC-3110-8D4C-8E2BF185983E> /usr/lib/libCoreStorage.dylib
                    0x7fff9067a000 -     0x7fff9069eff7  libJPEG.dylib (1459) <30F85216-E836-37B3-874E-62F1D040B098> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                    0x7fff908bf000 -     0x7fff908fdff7  libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                    0x7fff9090b000 -     0x7fff9097afff  com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                    0x7fff9097b000 -     0x7fff909a9ff7  com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                    0x7fff909cb000 -     0x7fff90d46ffb  com.apple.VideoToolbox (1.0 - 1731.15.206) <19DD020F-128A-32B0-96A4-A51F111B549F> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                    0x7fff9108a000 -     0x7fff9108efff  libGIF.dylib (1459) <58F85C45-96D2-3713-A8C0-B2579B419A80> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                    0x7fff9116f000 -     0x7fff91177fef  libcldcpuengine.dylib (2.7.3) <385BE8CE-16D8-3FCB-8558-8EB744D3DFE6> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                    0x7fff911cb000 -     0x7fff911d3fef  libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
                    0x7fff911d4000 -     0x7fff91249fff  com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                    0x7fff912db000 -     0x7fff912e1fff  com.apple.IOAccelerator (205.11 - 205.11) <C51BF724-F8E8-3B9F-806E-A00C65056445> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                    0x7fff92cee000 -     0x7fff92cf0fff  com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                    0x7fff92cf6000 -     0x7fff92d0bfff  com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                    0x7fff92d0c000 -     0x7fff92de5fff  com.apple.CoreMedia (1.0 - 1731.15.206) <DE407384-39D5-3727-A78D-D22849D816C7> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                    0x7fff92e53000 -     0x7fff92e8bff7  com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                    0x7fff92f25000 -     0x7fff92f71fff  com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                    0x7fff92f83000 -     0x7fff92f9cfff  com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                    0x7fff9305b000 -     0x7fff93599ff7  com.apple.MediaToolbox (1.0 - 1731.15.206) <119FFD0E-947D-3103-9221-458439F5764D> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                    0x7fff935d1000 -     0x7fff935e0fe7  com.apple.AppleFSCompression (81.20.2 - 1.0) <2FE122A9-5265-320A-9600-FFC5CE4DE197> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                    0x7fff935e1000 -     0x7fff93669fff  com.apple.CoreSymbolication (3.1 - 58048.1) <4730422E-4178-34F9-8550-BB92F2A4F44B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                    0x7fff9366a000 -     0x7fff9366ffff  com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                    0x7fff936be000 -     0x7fff936c6fff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                    0x7fff93779000 -     0x7fff93779ff7  libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
                    0x7fff939df000 -     0x7fff939e3fff  com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                    0x7fff939e4000 -     0x7fff93a1efff  com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                    0x7fff93a31000 -     0x7fff93b17ff7  libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
                    0x7fff93b18000 -     0x7fff93f8efff  com.apple.CoreFoundation (6.9 - 1258.1) <943A1383-DA6A-3DC0-ABCD-D9AEB3D0D34D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                    0x7fff9400a000 -     0x7fff94079fff  com.apple.datadetectorscore (7.0 - 460) <E8616F01-90AC-3863-B18C-426E6DD1ACDE> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                    0x7fff9407a000 -     0x7fff9407cff7  com.apple.securityhi (9.0 - 55006) <1E7BE52B-97EA-371A-AECA-1EE2AD246D8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                    0x7fff94085000 -     0x7fff9445dfef  com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                    0x7fff944b3000 -     0x7fff944f8ff3  libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                    0x7fff94812000 -     0x7fff94870fff  com.apple.CoreServices.OSServices (728.13 - 728.13) <27C12B92-7845-38DD-B82D-DC5B678352D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                    0x7fff948a9000 -     0x7fff948aafff  libffi.dylib (18.1) <5BA9612C-747E-33CE-9DB1-3C01ECF3041D> /usr/lib/libffi.dylib
                    0x7fff948ab000 -     0x7fff948b1fff  com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                    0x7fff948b2000 -     0x7fff948e8fff  libssl.0.9.8.dylib (59.60.1) <C047F10D-A929-36C8-83DE-E8BB7183A158> /usr/lib/libssl.0.9.8.dylib
                    0x7fff948e9000 -     0x7fff94900fff  com.apple.ScriptingBridge (1.3.3 - 68) <13D01EBC-D01E-3054-8C3C-3989BCF6370A> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
                    0x7fff94927000 -     0x7fff94958fff  com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                    0x7fff95862000 -     0x7fff95875fff  com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                    0x7fff960b3000 -     0x7fff960caff7  libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
                    0x7fff96102000 -     0x7fff96103ff3  com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                    0x7fff96104000 -     0x7fff963aaff7  com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                    0x7fff963b2000 -     0x7fff963b5fff  libsystem_sandbox.dylib (460.60.2) <2A68B39C-B786-3A05-87A2-56E688469FB8> /usr/lib/system/libsystem_sandbox.dylib
                    0x7fff964dd000 -     0x7fff9652ffff  com.apple.CloudDocs (1.0 - 383.13) <5FD9138D-09D9-3B97-BBAD-5692E1687F30> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                    0x7fff96530000 -     0x7fff9655aff7  libc++abi.dylib (307.2) <922EFB36-0E9E-315B-8270-E81AC43472C0> /usr/lib/libc++abi.dylib
                    0x7fff9655b000 -     0x7fff9659cff7  libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                    0x7fff96708000 -     0x7fff9670eff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                    0x7fff9670f000 -     0x7fff967a5fff  com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                    0x7fff96821000 -     0x7fff96838fff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
                    0x7fff96856000 -     0x7fff9747fff7  com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                    0x7fff97480000 -     0x7fff97480fff  com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                    0x7fff97481000 -     0x7fff97483ffb  libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
                    0x7fff97491000 -     0x7fff97567ffb  com.apple.DiskImagesFramework (10.11.4 - 417.4) <B9525D22-6F0D-39C5-BA9B-9DF195FE1968> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                    0x7fff97568000 -     0x7fff975dffeb  libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
                    0x7fff975e0000 -     0x7fff976f2fef  libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                    0x7fff97726000 -     0x7fff97729fff  libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                    0x7fff97a40000 -     0x7fff97a49ff7  libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
                    0x7fff97a4a000 -     0x7fff97a4afff  libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
                    0x7fff97bab000 -     0x7fff97be5ff7  com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                    0x7fff97be6000 -     0x7fff97be8fff  com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
                    0x7fff97c45000 -     0x7fff97df0ffb  GLEngine (12.1) <299D9296-2984-3967-9049-A842B99E5D43> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
                    0x7fff97df1000 -     0x7fff97e0dff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
                    0x7fff97e3c000 -     0x7fff97fe2ff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                    0x7fff97fe3000 -     0x7fff97ffeff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
                    0x7fff98030000 -     0x7fff98049fff  com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                    0x7fff980b6000 -     0x7fff9819cfef  unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
                    0x7fff981a3000 -     0x7fff981adfff  com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                    0x7fff981ae000 -     0x7fff982bcff3  com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                    0x7fff982d7000 -     0x7fff982f9ff7  com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                    0x7fff982fa000 -     0x7fff98324ff7  GLRendererFloat (12.1) <BE957AC5-82C2-3620-A625-56C9BE7B853F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
                    0x7fff98325000 -     0x7fff98383fff  com.apple.SystemConfiguration (1.14 - 1.14) <D801FAD7-5A2D-3E5E-9F44-B6C9B8BEA747> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                    0x7fff98384000 -     0x7fff98552ff3  com.apple.QuartzCore (1.11 - 410.14) <076BDE58-8AED-3D47-84FD-548CF8E8EDB9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                    0x7fff98e77000 -     0x7fff98e88ff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
                    0x7fff98e89000 -     0x7fff98efdff7  com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                    0x7fff98f95000 -     0x7fff98f99fff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
                    0x7fff98fab000 -     0x7fff98faeff7  com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                External Modification Summary:
                  Calls made by other processes targeting this process:
                    task_for_pid: 184
                    thread_create: 0
                    thread_set_state: 0
                  Calls made by this process:
                    task_for_pid: 0
                    thread_create: 0
                    thread_set_state: 0
                  Calls made by all processes on this machine:
                    task_for_pid: 91476
                    thread_create: 0
                    thread_set_state: 0
                VM Region Summary:
                ReadOnly portion of Libraries: Total=866.2M resident=0K(0%) swapped_out_or_unallocated=866.2M(100%)
                Writable regions: Total=9.6G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=9.6G(100%)
                                                VIRTUAL   REGION
                REGION TYPE                        SIZE    COUNT (non-coalesced)
                ATS (font support)                32.1M        8
                ATS (font support) (reserved)        4K        2         reserved VM address space (unallocated)
                Accelerate.framework               128K        2
                Activity Tracing                  2048K        2
                CG backing stores                 9140K        5
                CG image                           224K       20
                CG raster data                     700K        4
                CG shared images                   272K        8
                CoreAnimation                      132K       20
                CoreUI image data                 1048K        9
                CoreUI image file                  192K        4
                Dispatch continuations            16.0M        2
                Foundation                          20K        2
                Image IO                          2160K       57
                Kernel Alloc Once                    8K        3
                MALLOC                           459.5M      138
                MALLOC guard page                   32K        7
                Memory Tag 242                      12K        2
                Memory Tag 249                     192K        3
                OpenCL                               8K        2
                OpenGL GLSL                        512K        7
                Process Corpse Info               2048K        2
                STACK GUARD                       56.2M       50
                Stack                             54.5M       55
                VM_ALLOCATE                        9.1G      324
                VM_ALLOCATE (reserved)             164K        3         reserved VM address space (unallocated)
                __DATA                            64.8M      699
                __GLSLBUILTINS                    2588K        2
                __IMAGE                            528K        2
                __LINKEDIT                       255.6M      309
                __NV_CUDA                         6144K        3
                __TEXT                           610.6M      557
                __UNICODE                          552K        2
                mapped file                       95.8M       38
                shared memory                     16.4M       12
                TOTAL                             10.7G     2330
                TOTAL, minus reserved VM space    10.7G     2330
                Model: MacPro6,1, BootROM MP61.0116.B17, 4 processors, Quad-Core Intel Xeon E5, 3.7 GHz, 16 GB, SMC 2.20f18
                Graphics: AMD FirePro D300, AMD FirePro D300, PCIe, 2048 MB
                Memory Module: DIMM1, 4 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343531553741465238432D52442020
                Memory Module: DIMM2, 4 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343531553741465238432D52442020
                Memory Module: DIMM3, 4 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343531553741465238432D52442020
                Memory Module: DIMM4, 4 GB, DDR3 ECC, 1866 MHz, 0x802C, 0x394A53463531323732415A2D314739453220
                AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x135), Broadcom BCM43xx 1.0 (7.21.95.175.1a6)
                Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
                Network Service: Wi-Fi, AirPort, en2
                PCI Card: AMD FirePro D300, Display Controller, Slot-2
                PCI Card: AMD FirePro D300, Display Controller, Slot-1
                PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@158,0,0
                Serial ATA Device: APPLE SSD SM0256F, 251 GB
                Serial ATA Device: ST3000DM001-1ER166, 3 TB
                USB Device: USB 2.0 Bus
                USB Device: Hub
                USB Device: BRCM20702 Hub
                USB Device: Bluetooth USB Host Controller
                USB Device: USB 3.0 Bus
                USB Device: Keyboard Hub
                USB Device: Apple Keyboard
                USB Device: Hub
                USB Device: Apple Optical USB Mouse
                USB Device: Hub
                USB Device: Apple LED Cinema Display
                USB Device: Display iSight
                USB Device: Apple USB audio device
                Thunderbolt Bus: Mac Pro, Apple Inc., 19.2
                Thunderbolt Device: d2 TBT2 USB3, LaCie, 3, 24.3
                • 5. Re: Crashes when rendering composition with Cinema 4D
                  Try updating AE. Yesterday's 13.8.1 update fixed a lot of issues.
                  • 6. Re: Crashes when rendering composition with Cinema 4D
                    Zorro Gamarnik Level 1
                    Thanks Szalem.
                    it was cinema 4d's motion blur....
