5 Replies Latest reply on Jul 22, 2016 11:28 AM by pixxxel schubser
    Rotate a layer?
    RicSum Level 1
      Is it possible to rotate a regular layer?
      I have looked in the scripting guide, but cannot seem to find any reference to it.
      I simply need to rotate a regular layer (not a smart object) 90 degrees clockwise via a script.
      Any pointers would be greatly appreciated.
      Thank you all in advance.
        • 1. Re: Rotate a layer?
          pixxxel schubser MVP & Adobe Community Professional
          Hi RicSum,
          you can use ScriptListener Code or DOM.
          This is the easiest variant:
          activeDocument.activeLayer.rotate (90, AnchorPosition.TOPLEFT);
          But it gives an error if the active Layer is a background layer, or a shape layer or locked or not visible or, or, or…
          You have to check this cases before.
          Have fun
          • 2. Re: Rotate a layer?
            How many times do you want to rotate it. about what do you want to rotate it about. So many way to rotate.  I saw a scripting tutorial on the web. Its script example was layer rotation. I played around with it and had some fun.  Perhaps you can have some fun with what I turned the tutorial code example into.
            RotateLayerAbout.jsx
            // 2015  John J. McAssey (JJMack)
            // This script is supplied as is. It is provided as freeware.
            // The author accepts no liability for any problems arising from its use.
            // enable double-clicking from Mac Finder or Windows Explorer
            #target photoshop // this command only works in Photoshop CS2 and higher
            // bring application forward for double-click events
            app.bringToFront();
            // ensure at least one document open
            if (!documents.length) alert('There are no documents open.', 'No Document');
            else {
              //Set First Time Defaults here
              var dfltCpys = 12; // default number of copies including the original
              var dfltPos = 4; // default Middle Center
              //End Defaults
              var Prefs ={}; //Object to hold preferences.
              var prefsFile = File(Folder.temp + "/RotateLayerAboutPreferences.dat");
              //If preferences do not exit use Defaults from above
              if(!prefsFile.exists){
              Prefs.Cpys  = dfltCpys;
              Prefs.Pos  = dfltPos;
              prefsFile.open('w');
              prefsFile.write(Prefs.toSource());
              prefsFile.close();
              else{//Preferences exist so open them
              prefsFile.open('r');
              Prefs = eval(prefsFile.read());
              prefsFile.close();
              try {
              function createDialog(){
              // begin dialog layout
              var DupRotateDialog = new Window('dialog');
              DupRotateDialog.text = 'Duplicate and Rotate Layer';
              DupRotateDialog.frameLocation = [78, 100];
              DupRotateDialog.alignChildren = 'center';
              DupRotateDialog.NumLayerPnl = DupRotateDialog.add('panel', [2, 2, 300, 56], 'Number of Layers and Rotation Anchor Point');
              DupRotateDialog.NumLayerPnl.add('statictext', [10, 16, 50, 48], 'Copies ');
              DupRotateDialog.NumLayerPnl.imgCpysEdt = DupRotateDialog.NumLayerPnl.add('edittext', [50, 13, 90, 34], Prefs.Cpys, {name:'imgCpys'});
              DupRotateDialog.NumLayerPnl.imgCpysEdt.helpTip = 'Number of copies of selected Layer';
              DupRotateDialog.NumLayerPnl.add('statictext',[96, 16, 240, 48],'Location');
              var position =['Top Left','Top Center','Top Right','Center Left','Center','Center Right','Bottom Left','Bottom Center','Bottom Right','Doc Center','Samples'];
              DupRotateDialog.NumLayerPnl.dd1 = DupRotateDialog.NumLayerPnl.add('dropdownlist',[150, 13, 260, 34],position);
              DupRotateDialog.NumLayerPnl.dd1.selection=Prefs.Pos;
              var buttons = DupRotateDialog.add('group');
              buttons.orientation = 'row';
              var okBtn = buttons.add('button');
              okBtn.text = 'OK';
              okBtn.properties = {name: 'ok'};
              var cancelBtn = buttons.add('button');
              cancelBtn.text = 'Cancel';
              cancelBtn.properties = {name: 'cancel'};
              return DupRotateDialog;
              dispdlg(createDialog());
              function dispdlg(DupRotateDialog){
              // display dialog and only continues on OK button press (OK = 1, Cancel = 2)
              DupRotateDialog.onShow = function() {
              var ww = DupRotateDialog.bounds.width;
              var hh = DupRotateDialog.bounds.height;
              DupRotateDialog.bounds.x  = 78;
              DupRotateDialog.bounds.y  = 100;
              DupRotateDialog.bounds.width  = ww;
              DupRotateDialog.bounds.height  = hh;
              if (DupRotateDialog.show() == 1) {
              //variables passed from user interface
              var copies = String(DupRotateDialog.NumLayerPnl.imgCpys.text); if (copies=="") { copies = Prefs.Cpys;}
              if (isNaN(copies)) { alert("Non numeric value entered"); dispdlg(createDialog());}
              else {
              if (copies<2 || copies>360) { alert("Number of layer allow is 2 to 360"); dispdlg(createDialog());}  // Not in range
              else {
              var AnchorPoint = Number(DupRotateDialog.NumLayerPnl.dd1.selection.index) + 1;
              cTID = function(s) { return app.charIDToTypeID(s); };
              sTID = function(s) { return app.stringIDToTypeID(s); };
              // Save the current preferences
              Prefs.Cpys  = copies;
              Prefs.Pos  = Number(DupRotateDialog.NumLayerPnl.dd1.selection.index);
              prefsFile.close();
              var startRulerUnits = app.preferences.rulerUnits;
              var startTypeUnits = app.preferences.typeUnits;
              var startDisplayDialogs = app.displayDialogs;
              // Set Photoshop to use pixels and display no dialogs
              app.preferences.rulerUnits = Units.PIXELS;
              app.preferences.typeUnits = TypeUnits.PIXELS;
              app.displayDialogs = DialogModes.NO;
              app.togglePalettes();
              try { app.activeDocument.suspendHistory('RotateLayerAbout','main(copies, AnchorPoint)' );}
              catch(e) {alert(e + ': on line ' + e.line);}
              // Return the app preferences
              app.preferences.rulerUnits = startRulerUnits;
              app.preferences.typeUnits = startTypeUnits;
              app.displayDialogs = startDisplayDialogs;
              else {
              //alert('Operation Canceled.');
              catch(err){
              // Lot's of things can go wrong, Give a generic alert and see if they want the details
              if ( confirm("Sorry, something major happened and I can't continue! Would you like to see more info?" ) ) { alert(err + ': on line ' + err.line ); }
            function main(stemsAmount, Position) {
              if  (  Position == 11 && app.activeDocument.colorSamplers.length==0 ) {
              alert("No Color Sampler set");
              return;
              // Save selected layer to variable:
              var originalStem = app.activeDocument.activeLayer;
              // Run the copying process
              if(stemsAmount != null){
              // Calculate the rotation angle
              var angle = 360 / parseInt(stemsAmount);
              // Create a group for stems
              var stemsGroup = app.activeDocument.layerSets.add();
              stemsGroup.name = originalStem.name + " ("+stemsAmount+" stems)";
              // Place original layer in group
              originalStem.move(stemsGroup, ElementPlacement.INSIDE);
              // Duplicate and rotate layers:
              for(var i = 1; i < stemsAmount; i++){
              // Duplicate original layer and save it to the variable
              var newStem = originalStem.duplicate();
              // Rotate new layer
              switch (Position){
              case 1 : newStem.rotate(angle * i, AnchorPosition.TOPLEFT); break;
              case 2 : newStem.rotate(angle * i, AnchorPosition.TOPCENTER); break;
              case 3 : newStem.rotate(angle * i, AnchorPosition.TOPRIGHT); break;
              case 4 : newStem.rotate(angle * i, AnchorPosition.MIDDLELEFT); break;
              case 5 : newStem.rotate(angle * i, AnchorPosition.MIDDLECENTER); break;
              case 6 : newStem.rotate(angle * i, AnchorPosition.MIDDLERIGHT); break;
              case 7 : newStem.rotate(angle * i, AnchorPosition.BOTTOMLEFT); break;
              case 8 : newStem.rotate(angle * i, AnchorPosition.BOTTOMCENTER); break;
              case 9 : newStem.rotate(angle * i, AnchorPosition.BOTTOMRIGHT); break;
              case 10 : app.activeDocument.activeLayer = newStem; rotateAroundPosition(angle * i,activeDocument.width/2,activeDocument.height/2); break;
              case 11 : for (var s=0,len=app.activeDocument.colorSamplers.length;s<len;s++) {
              if (s!=0) {
              newStem.name = originalStem.name + " " + (i+1) + " p" + (s+1) ;
              var colorSamplerRef = app.activeDocument.colorSamplers[s];
              //alert("angle=" + (angle * i) +  " ,x=" + colorSamplerRef.position[0].value + " ,y=" + colorSamplerRef.position[1].value);
              rotateAroundPosition(angle * i,colorSamplerRef.position[0].value,colorSamplerRef.position[1].value);
              newStem.move(stemsGroup, ElementPlacement.PLACEATEND);
              break;
              default : break;
              // Add index to new layers
              if (Position!=11) {
              newStem.name = originalStem.name + " " + (i+1);
              // Place new layer inside stems group
              // Add index to the original layer
              if (Position!=11) originalStem.name += " 1";
              else originalStem.name += " 1 p1";
            function rotateAroundPosition(_angle,x,y) {
                var desc1 = new ActionDescriptor();
                var desc2 = new ActionDescriptor();
                var ref1 = new ActionReference();
                ref1.putEnumerated(charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt'));
                desc1.putReference(charIDToTypeID('null'), ref1);
                desc1.putEnumerated(charIDToTypeID('FTcs'), charIDToTypeID('QCSt'), stringIDToTypeID("QCSIndependent"));
                desc2.putUnitDouble(charIDToTypeID('Hrzn'), charIDToTypeID('#Pxl'), x);
                desc2.putUnitDouble(charIDToTypeID('Vrtc'), charIDToTypeID('#Pxl'), y);
                desc1.putObject(charIDToTypeID('Pstn'), charIDToTypeID('Pnt '), desc2);
                desc1.putUnitDouble(charIDToTypeID('Angl'), charIDToTypeID('#Ang'), _angle);
                desc1.putEnumerated(charIDToTypeID('Intr'), charIDToTypeID('Intp'), charIDToTypeID('Bcbc'));
                executeAction(charIDToTypeID('Trnf'), desc1, DialogModes.NO);
            • 3. Re: Rotate a layer?
              RicSum Level 1
              Wow - I will experiment with that also.
              Thank you.
              • 4. Re: Rotate a layer?
                • 5. Re: Rotate a layer?
                  RicSum
                  Perhaps some interesting stuff for you (helpful properties):
                  activeDocument.activeLayer.isBackgroundLayer
                  activeDocument.activeLayer.kind == LayerKind.NORMAL
                  activeDocument.activeLayer.allLocked
                  activeDocument.activeLayer.positionLocked
                  activeDocument.activeLayer.visible
                  You can find this and other properties e.g. in the Object Model Viewer in Adobe ExtendScript Toolkit.
                  Have fun
