25 Replies Latest reply on Jun 5, 2017 10:14 AM by MaineMan
    Why doesn't Lightroom see all the photos in my folder?
    jewboy54
      I am operating a Macbook running El Capitan and Lightroom 6.1.1
      All the photos I want are in the folder yet Lightroom steadfastly refuses to recognize them no matter what I do.
      I've synchronize the folder.
      I've tried importing them but, again, Lightroom grays them out so it can't import them.
      WHAT am I doing wrong?
        • 1. Re: Why doesn't Lightroom see all the photos in my folder?
          Although this isn't the Lightroom product forum, it's the Lounge, I found these help articles that may be of interest to you.
          Nancy O.
          • 2. Re: Why doesn't Lightroom see all the photos in my folder?
            Per Berntsen Adobe Community Professional
            The photos are greyed out because they are already imported.
            This is Lightroom's way of preventing you importing duplicates, which is a good thing, because it will lead to confusion and problems.
            Click on All Photographs in the Catalog panel, and disable any filters. (Ctrl/Cmd+L)
            You will now see thumbnails of all the photos in the catalog.
            Alternatively, use the filter bar to search for the file names.
            It could also be that the photos are in the folder where you think they are, but are not displayed because of an active filter.
            Press Ctrl/Cmd+L to disable any filters.
            • 4. Re: Why doesn't Lightroom see all the photos in my folder?
              Is it possible that you are looking at the "previous import" rather than displaying the entire folder? After images are imported Lightroom first displays just those images that were imported at that time. If you right-click on one of those images and choose to go to the folder in library, perhaps that will display the rest of your images.
              • 5. Re: Why doesn't Lightroom see all the photos in my folder?
                dj_paige Level 10
                Most likely you (accidentally?) originally imported the photos using the COPY option, and the photos were imported into Lightroom and exist in Lightroom in some other folder (where the COPY placed them). The instructions others have given are what you need to do. Find the photos in Lightroom.
                Importing will not solve your problem. Synchronizing the folder will not solve the problem.
                Last, Lightroom is not a file browser. It doesn't see or know what files are in your folders. It only knows what files have been imported.
                • 6. Re: Why doesn't Lightroom see all the photos in my folder?
                  jewboy54 Level 1
                  OK, yes I believe you're correct about my error.
                  To compound it further, I removed the original folder, which was in error, and put them where i wanted them using my Mac Finder.
                  Lightroom sees the folder but refuses to recognize the files.  Is there anyway to get these pictures imported to Lightroom and have the program stop ignoring them?
                  • 7. Re: Why doesn't Lightroom see all the photos in my folder?
                    jewboy54 Level 1
                    That didn't solve my issues but the reminder was appreciated.
                    • 8. Re: Why doesn't Lightroom see all the photos in my folder?
                      dj_paige Level 10
                      As I said, and as others have said, Importing will not solve the problem. It will only make the problem worse. You have to find the copy of the photo that has already been imported into Lightroom by searching within Lightroom. Per Berntsen explained how to do this in reply #2 in this thread.
                      • 9. Re: Why doesn't Lightroom see all the photos in my folder?
                        ManiacJoe Adobe Community Professional
                        If you moved the folder outside of Lightroom, you just need to tell LR where you moved it to.
                        Go to the Library module, Folders panel, right-click on the "missing folder" (marked with a ?) and select "find missing" or "relocate".
                        • 10. Re: Why doesn't Lightroom see all the photos in my folder?
                          dj_paige Level 10
                          It seems likely he imported the photos using COPY and Lightroom now knows about the photos, but they are not in the folder that he thinks they should be. So he has to find them in Lightroom and then he can move them as desired. There are no reported ? icons or ! icons.
                          • 11. Re: Why doesn't Lightroom see all the photos in my folder?
                            jewboy54 Level 1
                            I have removed all the filters as Per recommended.  Those pictures are still not visible in LR.  I also upgraded LR to the current version.
                            The problem is my own doing (I realize that).  But the files are in the correct folder now.  Is there really not a way to get LR to see them?
                            I still have the originals in my camera.  Should I delete the last download and reload it?
                            • 12. Re: Why doesn't Lightroom see all the photos in my folder?
                              dj_paige Level 10
                              That's only part of the instructions. Per recommended you turn off filters, click on All photographs and then search by File Name using the filter bar. You have to do all three things to find the photos.
                              Yes, we have given you the instructions to find them. Once you find them, you can fix the problem by telling Lightroom to use the files in the directory you want. We will give you the instructions on how to do this if you find the photos.
                              • 13. Re: Why doesn't Lightroom see all the photos in my folder?
                                jewboy54 Level 1
                                there is no missing folder as I deleted it (I should never have let LR create it) in Mac Finder and have removed it from my preferences
                                • 14. Re: Why doesn't Lightroom see all the photos in my folder?
                                  dj_paige Level 10
                                  No, because you won't be able to import the photos, Lightroom will tell you that they are previously imported.
                                  You HAVE TO stop thinking in terms of importing here, that WILL NOT help.
                                  • 15. Re: Why doesn't Lightroom see all the photos in my folder?
                                    jewboy54 Level 1
                                    What do you mean by the filter bar?  I do not understand (as is fairly
                                    obvious by now).
                                    To me the problem is that the program cannot sync to the present reality of
                                    the folder.  I just don’t understand why there isn’t a reset.
                                    I cannot find the pictures (and there are several hundred) in Lightroom but
                                    maybe it’s just because I don’t understand your and Per’s instructions.
                                    I got turning the filters off but I have no idea what you mean by filter
                                    bar to find them.
                                    Harry Klane
                                    salesmook@gmail.com
                                    • 16. Re: Why doesn't Lightroom see all the photos in my folder?
                                      This is the filter bar:
                                      Make sure only Text is active, and then search for filename or other metadata.
                                      • 17. Re: Why doesn't Lightroom see all the photos in my folder?
                                        jewboy54 Level 1
                                        I do appreciate all the help you and DJ have given me but I am no closer to a solution.
                                        The filters only find stuff that is already visible in Lightroom.
                                        Even though the files are in the very same named folder it cannot find them.
                                        This is terribly frustrating and completely thrown me off my project because some of the last 1000 pictures I've taken were copied over to the program improperly.
                                        So, what have we learned?
                                        We've learned that when transferring photos to LR be DAMN sure they are going to the right place the first time.
                                        Otherwise there appears NO way to fix this.
                                        As I said, the files are ALL in the right directories but they will not, despite your ideas, show up in LR.
                                        Yes, I'm unhappy this is such a problem.
                                        At this point, I don't know what to say or do.
                                        • 18. Re: Why doesn't Lightroom see all the photos in my folder?
                                          jewboy54 Level 1
                                          Should I remove the folder from LR and then is there for me to re assign it (believe there is)?
                                          • 19. Re: Why doesn't Lightroom see all the photos in my folder?
                                            dj_paige Level 10
                                            We keep telling you how to find the photos.
                                            Yes, that is what we have been advising, for you to find the photos that are already in Lightroom, and then it is EASY to associate the photos with the ones in the folder that you are interested in.
                                            Did you turn filters off? Yes or No?
                                            Did you click on All Photographs? Yes or No?
                                            Did you use the filter bar to search for one of the files by name? Yes or No?
                                            Did you find the photos of interest in Lightroom? Yes or No? You should be able to find those photos using this method.
                                            If  you found the photos, then the fix is simple.
                                            Yes, it is for us too because it sounds like you have been extremely reluctant to actually do what we are advising. You have fought against doing it this way and insisted on doing it other ways that we have told you will not work. The entire process shouldn't take even 5 minutes (and probably less than 1 minute) if you do it right.
                                            • 20. Re: Why doesn't Lightroom see all the photos in my folder?
                                              jewboy54 Level 1
                                              No I cannot find the desired photos in LR
                                              Sent from my HAL9000 Abacus to you
                                              • 21. Re: Why doesn't Lightroom see all the photos in my folder?
                                                jewboy54 Level 1
                                                I would love to solve this issue but again, I cannot find the pictures in LR which is why I seem "reluctant."
                                                My reluctance isn't related to avoidance of doing what you're asking, it is lack of understanding since my exact issue is different from what you've expected or built up in your mind.
                                                If I could have just found these files in LR, this would have been over long ago.  I can't so I'm stalled.  I wish there was some way we could just speak on the phone with the program running and we work it out together.
                                                • 22. Re: Why doesn't Lightroom see all the photos in my folder?
                                                  yebooos
                                                  I am having the same issue on MAC OS X 10.11.6 and LR 2015.6.1
                                                  When connecting my external hard drive where 99% of my photos are stored lightroom shows the green dot for the connected hard drive but EVERY single folder on it has the question marc showing that lightroom thinks it is missing.
                                                  When relocating a "missing" file lightroom says "the file is associated with another another photo in the catalogue" and the photo it is associated with is the actual "missing" photo I wanted to relocate.
                                                  So at one hand LR says something is wrong and at the other one that everything is right.
                                                  Any help out there? adobe? how can every update be that buggy?
                                                  • 23. Re: Why doesn't Lightroom see all the photos in my folder?
                                                    dj_paige Level 10
                                                    This is not a bug. This is an unfortunate user error.
                                                    Your symptoms indicate that you have (accidentally?) imported the photo twice, and most likely one time you imported using COPY and one time you imported using ADD. If you search for a photo, you will most likely find two copies of the photo in your Lightroom Library, one where you think it ought to be, and one where you don't expect it to be. To search for the photo, click on All Photographs, then turn off any filters (Ctrl-L once or twice) and then sort the photos by file name (View->Sort->File Name) and then scroll up or down until you find the two versions of the same file in your Lightroom library module. Probably one version has edits and user-supplied metadata, and one does not.
                                                    The solution is to delete the version that does not have the edits, then reconnect, and you won't get the message "the file is associated with another another photo in the catalogue".
                                                    • 24. Re: Why doesn't Lightroom see all the photos in my folder?
                                                      yebooos Level 1
                                                      thank you @dj_paige for your fast reply. I don't think this is a user error. I was working like this for 2 years by now – without any problems so far
                                                      I actually found a solution right now: REBOOT. I cannot believe it but everything works well again as if there would haver never been a problem. I am not used to that kind of solutions at an APPLE machine, that is why I did not come up with it immediately.
                                                      I have no idea what happened but I just hope that it will never appear again.
                                                      • 25. Re: Why doesn't Lightroom see all the photos in my folder?
                                                        MaineMan Level 1
                                                        This is common it appears. After you've done the stand Mac troubleshooting: repair permissions, restart. Simply do this.
                                                        Open Lightroom. Go Under the FILE dropdown and chose "Optimize Catalog".
                                                        This should fix the problem.
                                                        All the Best,
                                                        Steve
