2 Replies Latest reply on Jul 25, 2016 9:27 AM by mihaj73682042
    Phonegap not opening links in system browser
    mihaj73682042 Level 1
      I am new to PhoneGap and Cordova. I am trying to create an application for now just for personal purposes.
      The problem:
      When I run the app on the phonegap desktop I can easily open the links when I press the desired content (#first). But when I upload app on build.phonegap and then download the app on a phone it does not work anymore.
      Also I'm getting the error: Error initializing Cordova: Class not found
      Here is my content from github: https://github.com/unforgivenJ/Test
      And app for download: https://build.phonegap.com/apps/2182437/share
      Any help would be appreciated. Regards, Miha.
        • 1. Re: Phonegap not opening links in system browser
          VectorP Level 4
          Phonegap Build expects something different from what you are uploading:
          a. never upload platforms, plugins and other Cordova related directories
          b. only upload your assets and a config, where both index.html and config.xml must be in the root of your zip file. To get that done easily:
          - move config.xml into /www
          - adjust the paths in config (icons/splashes) accordingly
          - zip up only the contents - not the directory itself - of /www, now.
          BTW: this would be a perfect time to start reading the Phonegap Build documentation!
          Your app won't build/work properly, even after uploading a correct zip file, for instance because:
          - you have included references to both phonegap.js and cordova.js
          - you are using a density attribute with compound qualifiers for splashes
          - you are specifying older versions of most plugins
          - you included an 'engine' element in your config
          - you are making incorrect use of the inappbrowser plugin's interface functions.
          • 2. Re: Phonegap not opening links in system browser
            Hi, thank you so much for your help, now it works everything, thank you for slapping me in the face
