5 Replies Latest reply on Aug 1, 2016 2:33 PM by lepkemot
    Applying applescript to selected pages
    lepkemot Level 1
      Hi, how do I change the script below so it only applies to pages I have previously selected in Pages panel?
      tell application "Adobe InDesign CC 2015"
      activate
      set n to pages per document of document preferences of active document
      tell active document
      set c to 1
      repeat with i from 1 to n
      move page n to before page c
      set c to (c + 1)
      end repeat
      end tell
      display dialog "Done"
      end tell
      Thanks!
        • 1. Re: Applying applescript to selected pages
          Loic.Aigon Adobe Community Professional
          I don't thing a script can reach the user selection in the pages panel.
          • 2. Re: Applying applescript to selected pages
            S Hopkins Adobe Community Professional
            Why don't you just have the user enter the numbers for the pages to have the script applied to in a display dialog and then process the pages listed. Something like the following:
            set numberList to {}
            set userResponse to display dialog "Enter numbers for pages to process. Separate numbers with semicolon" default answer "1;4;7"
            set pageNumbers to text returned of userResponse
            set x to offset of ";" in pageNumbers
            if x > 0 then
              set oldDelim to AppleScript's text item delimiters
              set AppleScript's text item delimiters to ";"
              set numberList to text items of pageNumbers
              set AppleScript's text item delimiters to oldDelim
            else
              set pageNum to pageNumbers as number
              --maximum value below is number of pages in document
              if pageNum > 0 and pageNum < 100 then
                 set numberList to {pageNumbers}
               end if
            end if
            if numberList is not {} then
              set docRef to active document
              tell docRef
              set c to a reference to page 1
              repeat with i from 1 to length of numberList
              try
              move page (item i of numberList) to before c
              on error errStr
              activate
              display alert "Error " & errStr
              --do nothing
              end try
              end repeat
              end tell
              end tell
            display dialog "Done" giving up after 2
            end if
            Just a thought.
            • 3. Re: Applying applescript to selected pages
              lepkemot Level 1
              Hi S Hopkins, thanks for your reply. That's a good idea. Do you think it would be possible to input range of pages, for example "10-20" instead of listing single pages? Also, at the moment your script reverses the order but moves all pages to the beginning of document. Is it possible to reverse the order but keep pages in the same place within the document? For example: 1-2-3-4-5 becomes 1-4-3-2-5 if "2-4" input? Thanks again, T
              • 4. Re: Applying applescript to selected pages
                Sure you can do both. To get a range of numbers from the user the following can be used. Try the following:
                set minX to missing value
                set maxX to missing value
                set userResponse to display dialog "Enter page range. Separate maximum and minimum with hyphen" default answer "4-10"
                set x to offset of "-" in pageNumbers
                set len to length of pageNumbers
                if x > 0 then
                  set minX to (text 1 thru (x - 1) of pageNumbers) as number
                  set maxX to (text (x + 1) thru len of pageNumbers) as number
                end if
                {minX, maxX}
                With this information you can move your pages using the following:
                  tell document 1
                  set pageRef to page (minX - 1)
                  repeat with i from minX to maxX
                  move page i to after pageRef
                  end repeat
                  end tell
                end tell
                To bullet-proof your script you will need to make sure that numbers entered are valid. (minX and/or maxX is not missing value, maxX is greater than minX, minX - 1 is not 0, etc.). I will leave that up to you.
                Shirley Hopkins
                • 5. Re: Applying applescript to selected pages
                  lepkemot Level 1
                  Thank you Shirley
