6 Replies Latest reply on Sep 17, 2016 8:21 PM by nurlybek
    How to use AP property of the stamp type annotation in javascript
    peculiar_liar
      I have been trying to insert a stamp using the AddAnnot method and this is the code I have:
      Function Doug(FileName, path) As Long
      Dim Acroapp As Acrobat.Acroapp
      Dim Doc1 As Acrobat.AcroPDDoc
      Dim CodeBox As Acrobat.AcroPDAnnot
      Dim Page As Acrobat.AcroPDPage
      Dim Cod1 As Acrobat.AcroPDDoc
      Dim gap As Acrobat.AcroPDPage
      Dim annot As Object
      Dim prop As Object
      Dim jso As Object
      Dim arr(0 To 3) As Integer
      Set Acroapp = CreateObject("AcroExch.App")
      Set Doc1 = CreateObject("AcroExch.PDDoc")
      'Set Cod1 = CreateObject("AcroExch.PDDoc")
      arr(0) = 0
      arr(1) = 0
      arr(2) = 300
      arr(3) = 300
      If Doc1.Open(path & FileName) = True Then
      Set Page = Doc1.AcquirePage(0)
      Set jso = Doc1.GetJSObject
      If Not jso Is Nothing Then
           Set annot = jso.AddAnnot()
           Set prop = annot.GetProps
                prop.Type = "Stamp"
           annot.setprops prop
                prop.AP = "#kZBRdNJ8NdlGCzWSCKIn3A"
                prop.rect = arr
           annot.setprops prop
      End If
      Doc1.Save 1, path
      Doc1.Close
      End If
      End Function
      It adds an annotation, but its just a box with no text in it. What am I doing wrong?
