0 Replies Latest reply on Jun 2, 2006 9:58 AM by Anurag Mishra
    Mapping Java ResultSet to Flex
    Anurag Mishra
      I finally got java and flex working together as a team yesterday. After creating simple programs such as fetching string and calculating factorial, I went over to sql.
      I fetched some sql records and displayed them in a datagrid successfully. Unfortunately, I didnt save the results and I can't reaccomplish that again. Here's the code I used (as far as I know)
      I am not sure what did I change, as it worked before and populated the datagrid with the sql data. Now when I print result, all I see is lots of [object Object]. So the data is coming through, just not sure if its the right data, or how to map it to datagrid.
