2 Replies Latest reply on Jul 27, 2016 2:39 AM by try67
    How to create and save Excel file to DAM using java
    MaheshNarayanan
      I am trying to create one excel sheet and save it into DAM.I am able to create excel in DAM, but no data is there in that excel. I am using following codes to create it.
      String filename = "updatedMetadata.xls";
          FileOutputStream fos = new FileOutputStream(filename);
          WritableWorkbook workbook = Workbook.createWorkbook(new File(filename));
          WritableSheet writableSheet = workbook.createSheet("Updated Metadata", 0);
          Label label = null;
          label = new Label(0, 0, "Header1");
          writableSheet.addCell(label);
          label = new Label(0, 1, "Header2");
          label = new Label(0, 2, "Header3");
          label = new Label(0, 3, "Header4");
          label = new Label(0, 4, "Header5");
          label = new Label(0, 5, "Header6");
          label = new Label(0, 6, "Header7");
          label = new Label(0, 7, "Header8");
          label = new Label(1, 0, "col val");
          label = new Label(1, 1, "col val");
          label = new Label(1, 2, "col val");
          label = new Label(1, 3, "col val");
          label = new Label(1, 4, "col val");
          label = new Label(1, 5, "col val");
          label = new Label(1, 6, "col val");
          label = new Label(1, 7, "col val");
          label = new Label(2, 0, "col val");
          label = new Label(2, 1, "col val");
          label = new Label(2, 2, "col val");
          label = new Label(2, 3, "col val");
          label = new Label(2, 4, "col val");
          label = new Label(2, 5, "col val");
          label = new Label(2, 6, "col val");
          label = new Label(2, 7, "col val");
          workbook.write();
          workbook.close();
          ResourceResolver resourceResolver = request.getResourceResolver();
          AssetManager manager = resourceResolver.adaptTo(AssetManager.class);
          InputStream is = this.getClass().getResourceAsStream("/content/dam/company/fileFolder/" + filename);
          Asset asset = manager.createAsset("/content/dam/company/fileFolder/" + filename, is, "application/vnd.ms-excel", true);
      File is creating in this Path "/content/dam/company/fileFolder/"
      File name is "updatedMetadata.xls"
      Thanks in advance
      Mahesh Narayanan
        • 1. Re: How to create and save Excel file to DAM using java
          MaheshNarayanan Level 1
          I found it myself. I am sharing the code so that in future someone else can use it.
            File excelFile = new File(filename);
            WritableWorkbook workbook = Workbook.createWorkbook(excelFile);
              Label label = null;
              workbook.write();
              workbook.close();
              InputStream stream = new FileInputStream(excelFile);
          • 2. Re: How to create and save Excel file to DAM using java
            Why did you post all of this to the Adobe forums? This has nothing to do with any Adobe product, as far as I can see.
