This content has been marked as final.
Show 8 replies
1. Re: FLASH Files reduce in size on preview in IE 6 & IE 7
Aaron_RH Jun 30, 2008 12:09 PM (in response to Eirehotspur)do you have any of this work on a url, yet?
I'll take a look if you can post a url here. -
2. Re: FLASH Files reduce in size on preview in IE 6 & IE 7
Eirehotspur Jun 30, 2008 2:24 PM (in response to Aaron_RH)Thanks for that Aaron.
Thing is you will probably see it fine in your IE
http://www.ferbane.tv/multimedia/ProductImageGalleryXMLv2b_home_index1/index1.php
Is my IE frigged up some way?
I noticed it dying on me in the past few weeks too.
I'd be browsing and window would just hang and I'd have to close and open a new window. -
3. Re: FLASH Files reduce in size on preview in IE 6 & IE 7
Eirehotspur Jun 30, 2008 2:32 PM (in response to Eirehotspur)Just to prove And show I am having this issue.....here is a Screen Capture of what I am seeing in IE 7.
http://www.ferbane.tv/multimedia/ProductImageGalleryXMLv2b_home_index1/ie.php
I upgraded to IE 7 from 6 because I thought it might resolve my issues but it didn't. -
4. Re: FLASH Files reduce in size on preview in IE 6 & IE 7
Newsgroup_User Jun 30, 2008 3:14 PM (in response to Aaron_RH)The flash seems fine on 3 browsers. IE6, FF3, Safari 3.1. But I'm seeing a
bunch of other problems.
http://validator.w3.org/check?uri=http%3A%2F%2Fwww.ferbane.tv%2Fmultimedia%2FProductImageG alleryXMLv2b_home_index1%2Findex1.php&charset=(detect+automatically)&doctype=Inline&group= 0
First, your links to stylesheets belong between the <head> and </head> tags.
Not inside the <body> </body> tags. Move this (it appears to be inside a
library item)
<link href="../../SpryAssets/SpyHorizontalMenu.css" rel="stylesheet"
type="text/css">
Div ID Names can be used only once per page. Not multiple times as you have
done.
<div id="photostorybox498">
<div id="photostorybox498-photo"><img
src="../images/ftv-B-BTP-02035_120x80.jpg" alt="IT Centre, Ferbane"
width="120" height="80" border="0" /></div>
<div id="photostorybox498-headline">
Last but not least, you're using APs (aka layers) which will break your
heart and your webpages. Increase text size and see what happens to your
page.
--Nancy O.
Alt-Web Design & Publishing
www.alt-web.com
"Eirehotspur" <webforumsuser@macromedia.com> wrote in message
news:g4bitp$i73$1@forums.macromedia.com...
> p
a
> new window.
5. Re: FLASH Files reduce in size on preview in IE 6 & IE 7
Eirehotspur Jun 30, 2008 3:44 PM (in response to Newsgroup_User)Thanks for taking the time for that detailed response Nancy.
I will certainly work through them.
It doesn't answer my problem though as you can see from this page which has no stylesheets or anything else apart from the Flash file.
http://www.ferbane.tv/multimedia/ProductImageGalleryXMLv2b_home_index1/ie2.php
I did say you will probably see it working fine as I do on Ie on my other PC.
What is the problem with mine though? -
6. Re: FLASH Files reduce in size on preview in IE 6 & IE 7
Newsgroup_User Jun 30, 2008 4:05 PM (in response to Newsgroup_User)Could be a bad installation. Do you have all the latest updates for IE7 yet?
--Nancy O.
www.alt-web.com
news:g4bnk1$n3d$1@forums.macromedia.com...
has no
PC.
7. Re: FLASH Files reduce in size on preview in IE 6 & IE 7
Eirehotspur Jun 30, 2008 4:44 PM (in response to Newsgroup_User)I do Nancy yes...dowloaded it last week.
Thought it would fix the problem of IE 6 but no go.
Mulder And Scully Job as I am out of ideas.
I think though if you check out a site like cbs.com and increase the text it will break the design.....you can drive yourself nuts with perfecting and trying to find a design that looks year 2000 web design or functioning webdesign. -
8. Re: FLASH Files reduce in size on preview in IE 6 & IE 7
Eirehotspur Jul 2, 2008 7:50 AM (in response to Eirehotspur)Anyone from Adobe got any idea of this?
Am sure someone has come accross this at some stage?
