13 Replies Latest reply on Mar 2, 2018 6:10 AM by ananthanj63180971
    "Event not covered" for transactional message
    hkurz Level 1
      I am trying to test transactional messaging (sending an email by SOAP request) to no avail.
      What i did:
      - created a template, type (called "t3") according to the steps in the documentation file "message-center-v6.1-en.pdf".
      - Created the event "t3"
      - published the template
      - sending a proof worked perfectly
      Then i created send SOAP message to the server with "Boomerang SOAP & REST client". This worked after using the content of a cookie "__sessiontoken" as "sessionToken".
      Request looks like this.
      <x:Envelope xmlns:x="http://schemas.xmlsoap.org/soap/envelope/" xmlns:urn="urn:nms:rtEvent">
          <x:Header/>
          <x:Body>
              <urn:PushEvent>
                  <urn:sessiontoken>___3a1ac7f7-8fc6-46fe-af52-db8f1865b60e</urn:sessiontoken>
                  <urn:domEvent>
                      <rtEvent xmlns="" wishedChannel="0" email="hermann.kurz@valtech.de" externalId="1749261730" expiration="2016/12/10 10:09:53" type="t3">
                          <ctx>
                               <commune>Poisson Ville</commune>
                          </ctx>
                      </rtEvent>
                  </urn:domEvent>
              </urn:PushEvent>
          </x:Body>
      </x:Envelope>
      l got back a response with HTTP code 200 (success) with this content:
      <?xml version='1.0'?>
      <SOAP-ENV:Envelope xmlns:xsd='http://www.w3.org/2001/XMLSchema' xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xmlns:ns='urn:nms:rtEvent' xmlns:SOAP-ENV='http://schemas.xmlsoap.org/soap/envelope/'>
          <SOAP-ENV:Body>
              <PushEventResponse xmlns='urn:nms:rtEvent' SOAP-ENV:encodingStyle='http://schemas.xmlsoap.org/soap/encoding/'>
                  <plId xsi:type='xsd:long'>72057594037964936</plId>
              </PushEventResponse>
          </SOAP-ENV:Body>
      </SOAP-ENV:Envelope>
      In the event history of the message center i see the event (see screenshot), but it is marked as "Event not covered" and no email is sent.
      I do not see any entry in any logfile i searched on the server for this event.
      Apparently the server cannot associate the request (type="t3") with the template for some reason. Event type of the template is "t3", as you see in this screenshot:
      Server works OK for workflows, but just not for transactional messages via SOAP (proof sending works also). We are using a linux machine for the server.
      Additional info
      in the Audit log of the Workflow "Processing real time events" i see "[Routing] 1 message(s) with errors" (see screenshot).
      But i cannot find out what the actual error was. How is this done?
      Does anybody know what's (not) going on here? Is there any place on the server where i can see what is going on?
      any help appreciated
      Hermann
