7 Replies Latest reply on Aug 23, 2016 4:58 AM by selvam214
    Can't add the old version files to book
    selvam214 Level 1
      Hi All,
      I'm working in CC2015, already we have the CS6 version files. I need to add the files in active book.
      Kindly check the below code and guide to me.
      Note: If the InDesign files are current version, no issue. But old version, the file can't add to book(save).
      myExtensions = [".indd"] ; var myFilteredFiles = new Array;  var myFolder; startDate= new Date();
      var myFolder = Folder.selectDialog("Select the folder containing the indesign files", "");
      if(myFolder != null){
      if(File.fs == "Macintosh"){
          myFilteredFiles = MyMacOSFileFilter(myFolder);
      else{
              myFilteredFiles = MyWinOSFileFilter(myFolder);
      var myBookFileName ,myBookFileName_temp;
      if (myFolder != null){
          var myFiles = [];
          var myAllFilesList = myFolder.getFiles("*.indd");
          for (var f = 0; f < myAllFilesList.length; f++){
              var myFile = myAllFilesList[f];
              myFiles.push(myFile);
          if ( myFiles.length > 0)
              if (app.books.length != 0) {
                  var myBook = app.activeBook;
                  myBook.close(SaveOptions.no);
              myBookFileName = myFolder + "/"+ myFolder.name + ".indb";
              myBookFileName_temp=myFolder.name;
              myBookFile = new File( myBookFileName);
              myBook = app.books.add(myBookFile);
              myBook.automaticPagination = false;
              for ( i=0; i < myFiles.length; i++){
                      myBook.bookContents.add(myFiles[i]);//struggle from here
      Selva
        • 1. Re: Can't add the old version files to book
          AriEss Level 1
          There seems to be some missing code. Where's the MyMacOSFileFilter and MyWinOSFileFilter functions?
          • 2. Re: Can't add the old version files to book
            Hi Selva,
            did you try to do it without scripting?
            Could you add the CS6 documents to a CC 2015 book file without opening and saving the CS6 docs to CC 2015?
            Best,
            Uwe
            • 3. Re: Can't add the old version files to book
              selvam214 Level 1
              Hi Uwe,
              Yes I tried with manual and I have added with opening and saving method only.
              So, I will try to open and save method before add the files to book?
              Selva
              • 4. Re: Can't add the old version files to book
                selvam214 wrote:
                … So, I will try to open and save method before add the files to book? …
                Exactly.
                But I would not do it with the original CS6 documents. Instead use duplicates so you can go back in case something is going wrong.
                Best,
                Uwe
                • 5. Re: Can't add the old version files to book
                  selvam214 Level 1
                  Thanks for your guidance Uwe.
                  Selva
                  • 6. Re: Can't add the old version files to book
                    selvam214 Level 1
                    Hi AriEss,
                    Here are the functions,
                    //Windows version of the file filter.
                    function MyWinOSFileFilter(myFolder){
                        var myFiles = new Array;
                        for(myExtensionCounter = 0; myExtensionCounter < myExtensions.length; myExtensionCounter++){
                            var myExtension = myExtensions[myExtensionCounter];
                            myFiles = myFolder.getFiles("*"+ myExtension);
                            if(myFiles.length != 0){
                                for(var myFileCounter = 0; myFileCounter < myFiles.length; myFileCounter++){
                                    myFilteredFiles.push(myFiles[myFileCounter]);
                            //Get subfolder
                            myFiles = myFolder.getFiles();
                                    var myFile=myFiles[myFileCounter];
                                    if (myFile instanceof Folder){
                                        MyWinOSFileFilter(myFile);
                        return myFilteredFiles;
                    //Mac OS version of the file filter.
                    function MyMacOSFileFilter(myFolder){
                    //----Get Sub folder-----
                                        MyMacOSFileFilter(myFile);
                                    } else{
                                        if(MyFileFilter(myFile)==true){
                                            myFilteredFiles.push(myFile);
                    function MyFileFilter(myFile){
                        var myFileType = myFile.type;
                        switch (myFileType){
                            case "IDd5":
                                return true;
                                break;
                            default:
                            for(var myCounter = 0; myCounter<myExtensions.length; myCounter++){
                                var myExtension = myExtensions[myCounter];
                                if(myFile.name.substring(myFile.name.length-5).toLowerCase()==myExtension){
                                    return true;
                                    break;
                        return false;
                    Selva
                    • 7. Re: Can't add the old version files to book
                      selvam214 Level 1
                      Thanks Uwe,
                      Finally I have followed before file saving method.
                      Selva
