Hello,
I'm creating a site that will have two seperate SWFs on
screen. One will be playing music, the other will contain a
start/stop button for the music. I'm using LocalConnection to
communicate between the two SWFs.
I have this working, sort of. The music will start playing, I
can stop it, restart it and stop it again, but the second time I
attempt to restart it, it does nothing. You can view it at:
http://www.outshinewebdesign.com/spider/index.html
For the life of me, I cannot figure out what is happening
that it won't restart the second time. This is the first time I
have attempted to use LocalConnection, so I'm hoping this is just a
small syntax error on my part.
I zipped up all relevant files and have placed it online at:
http://www.outshinewebdesign.com/spi...connection.zip
If anyone is inclined to take a peak. I'll also post an
outline of what I am doing.
The movie that contains the controls is sending the
LocalConnection data with the following AS:
(Frame 1, stopping music)
Code:
buttonInstance.onRelease = function() {
outgoing_lc = new LocalConnection();
outgoing_lc.send("lc_name", "methodToExecute", 2);
delete outgoing_lc;
_root.gotoAndStop(2);
(Frame 2, playing music)
Code:
outgoing_lc.send("lc_name", "methodToExecute", 1);
delete outgoing_lc;
_root.gotoAndStop(1);
The movie with the music that is receiving the
LocalConnection data is receiving with the following AS:
Code:
incoming_lc = new LocalConnection();
incoming_lc.methodToExecute = function (param) {
if (param == 1) {
gotoAndPlay(1);
musicStatus = "Playing";
} else {
gotoAndStop(20);
musicStatus = "Stopped";
incoming_lc.connect("lc_name");
I've tried everything I can think of, including rewriting
everything multiple times, but I'm getting the same result. I don't
understand why it works the first couple of times, but then stops.
I very much appreciate anyone's insight on this issue. Thanks!
Luke
