4 Replies Latest reply on Jul 27, 2016 12:03 PM by sarahcoppen
    Trouble Running Script in InDesign CC, Result: undefined
    sarahcoppen
      I am trying to run a script in InDesign that I have run successfully on 2 other documents. Now when I try to run the script on another document that is identical to the ones that used it before it isn't working.
      I am using InDesign CC on Windows 10 and have tried running the script both through the ID scripts panel as well as through ExtendScript. When running the script through ExtendScript I receive the message "Result: undefined" under the JavaScript Console. I haven't changed anything in the script and am completely lost.
      Disclaimer: I am a scripting novice and don't know anything about the script itself. It was provided by another user as a solution to a design problem I had through another thread. Help?!
      Here is the script I am trying to run:
      // AddOnePageBeforeAnyPage-AddSections-RenumberPages-SinglePageDocument.jsx
      // Uwe Laubender
      * @@@BUILDINFO@@@ AddOnePageBeforeAnyPage-AddSections-RenumberPages-SinglePageDocument.jsx !Version! Tue Jun 21 2016 07:19:25 GMT+0200
          See discussion at InDesign forum:
          "Inserting Non-Numbered Pages into Existing Document"
          sarahcoppen Jun 20, 2016
          https://forums.adobe.com/message/8822592#8822592
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
      app.doScript
          addPages,
          ScriptLanguage.JAVASCRIPT,
          UndoModes.ENTIRE_SCRIPT,
          "Add pages before every page | SCRIPT"
      function addPages()
          if(app.documents.length == 0){return};
          if(app.documents[0].documentPreferences.facingPages){return};
          var doc = app.documents[0];
          var pages = doc.pages;
          var pagesLength = pages.length;
          doc.documentPreferences.properties =
              allowPageShuffle : true ,
              preserveLayoutWhenShuffling : true
          for(var n=pagesLength-1;n>=0;n--)
              doc.pages.add(LocationOptions.BEFORE , pages[n] , { appliedMaster : NothingEnum.NOTHING } );
          doc.documentPreferences.startPageNumber = 2;
          doc.documentPreferences.facingPages = true;
              allowPageShuffle : false ,
          pages = doc.pages;
          var counter = 0;
          for(var n=1;n<pagesLength;n=n+2)
              counter++
              doc.sections.add( pages[n] , { continueNumbering : false , pageNumberStart : counter } );
