I am having an issue updating my flash player. I uninstalled the previous version of flash player and followed all instructions trying to reinstall. I keep getting a failure message at 55% install. Please help!!!
Here is the link to all of the normally requested files:
Below link might be helpful:
https://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-mac.html
Hey, I appreciate the feedback but Ive already followed all of those steps and even tried researching the web for possible solutions. No matter what I do, the installation always fails at 55%.
If you haven't rebooted yet, that's a great place to start. At minimum, it will eliminate a bunch of potential roadblocks for other steps.
If rebooting doesn't help, please see the installation troubleshooting guide:
Collecting and posting the logs would help us improve the product, and the links to the offline installers at the bottom of the guide should get you going.
i have the same issue, i've tried rebooting, uninstalling and installing again, nothing works progress for the installation reaches 55% and then fails, i have flash player plug in on chrome working fine, but is impossible to install it on Safari.
Could you provide us with few log files that would help us debug. Please go through the FAQ Where do I find the Flash Player installation log on the Macintosh? and provide the Adobe_GDE.log, Adobe_ADM.log and FlashInstall.log files. Upload the files to cloud.acrobat.com/send using the instructions at How to share a document and post a link here.
Thanks!
I am having the same problem on my Mac OS 10.11.6
Here's a link to my files:
Please help!
Thank you!
Fixed it with a clean install. Thanks!
How to perform a "clean install" of Flash Player in Mac OS X
Same problem on my iMac running OS 10,11.5. Install reaches 90%, stops and then cannot be aborted. Have to use Force Quit.
I was getting an Installation error at 90%. Clean install did not work for me.
inspecting the log file in the terminal ...
# cat ~/Library/Logs/FlashPlayerInstallManager.log
revealed a permission error...
2016-08-09 10:23:28 +0100 IM: [install started]
RA: Unable to launch FPInstallHelper. Error = 'launch path not accessible' 2016-08-09 10:23:28 +0100
RA: Attributes for '/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/FPInstallHelper':
NSFileCreationDate = "2016-06-29 01:09:55 +0000";
NSFileExtensionHidden = 0;
NSFileGroupOwnerAccountID = 0;
NSFileGroupOwnerAccountName = wheel;
NSFileHFSCreatorCode = 0;
NSFileHFSTypeCode = 0;
NSFileModificationDate = "2016-06-29 01:09:55 +0000";
NSFileOwnerAccountID = 0;
NSFileOwnerAccountName = root;
NSFilePosixPermissions = 2541;
NSFileReferenceCount = 1;
NSFileSize = 27184;
NSFileSystemFileNumber = 90527959;
NSFileSystemNumber = 16777220;
NSFileType = NSFileTypeRegular;
RA: Attributes for '/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T':
NSFileCreationDate = "2015-07-04 14:58:09 +0000";
NSFileModificationDate = "2016-08-09 09:23:28 +0000";
NSFilePosixPermissions = 449;
NSFileReferenceCount = 12;
NSFileSize = 408;
NSFileSystemFileNumber = 3805633;
NSFileType = NSFileTypeDirectory;
2016-08-09 10:23:29 +0100
IM: [install failed: 30] 2016-08-09 10:23:29 +0100
IM: Install failed with error code: 30. 2016-08-09 10:23:29 +0100 IM: NPAPI 22.0.0.209 ---------- log end ----------
checking this folder...
# ls -l /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/
revealed that the 'T' sub folder was only writable by root
total 0
drwxr-xr-x 7 root wheel 238 9 Aug 10:23 0
drwx------ 13 root wheel 442 20 Jul 09:26 C
drwxr-xr-x 4 root wheel 136 9 Aug 10:02 Cleanup At Startup
drwx------ 11 root wheel 374 9 Aug 10:23 T
adding permissions for wheel group to 'T' folder...
# chmod 750 /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T
then running installer again succeeded.
Thanks for your solution, which is alas incomprehensible to me. Could you write some simple instructions please?
Here's official, user-friendly installation troubleshooting guidance. I'd recommend starting here before going down more esoteric paths.
The permissions issue is right on track. Mine was stopping at 53% and I could see the same error in the logs.
The correct fix is documented here:
macos - How can I fix permissions for files in the /var/folders/zz? - Ask Different
But basically you can do this:
sudo rm -rf /var/folders/zz/zy*
sudo shutdown -r now
After a reboot things should work.
Same problem here:
MAC OSX El Capitan, Safari: I try to install the flash player, but the installer stops at 90 %. Tried it with browser on and of, dropbox on/of and no virus scanner.
