2 Replies Latest reply on May 1, 2006 4:59 AM by tomintown
    Rectangle (remove a side)
    tomintown
      If I have a rectangle with only a stroke (no fill), can I remove one of the sides?
      Tom
        • 1. Re: Rectangle (remove a side)
          Level 7
          Hi Tom,
          Yes you can.
          You can cut the side of the rectangle you wish to remove with the knife
          tool, then delete the side you wish to remove.
          Personally I would use the pen tool. If you hold the shift key down it will
          give you perfect vertical and horizontal lines.
          Peter
          "tomintown" <webforumsuser@macromedia.com> wrote in message
          news:e2vv4b$87c$1@forums.macromedia.com...
          the sides?
          | Thanks,
          | Tom
          • 2. Rectangle (remove a side)
            tomintown Level 1
            Thanks Peter,
            It works well with the knife. I will use it.
            Can you give me a step-by-step of the "pen" method?
            Thanks Again,
            Tom
