2 Replies Latest reply on Apr 28, 2006 10:53 PM by Devendran
    setFocus Problem
    Devendran Level 1
      Hi all
      here with i have attahced the Code,
      Its working fine for Text to text,...
      But If new Focus is Combo box, its not working.
      My aim is to get last Focused element when i focused on combo
      Here is the simple code
        • 1. Re: setFocus Problem
          You can get only the current object to which the event occured using the "oldFocus" object.
          Try like this
          input_txt.background = true;
          input_txt.border = true;
          input_txt.type = "input";
          var LastFocComponent bject = new Object();
          input_txt.onFocusOut = funtion(evtObj bject){
          LastFocComponent = evtObj.target;
          //My old focus is not retrived here
          myCombo.onSetFocus = function(oldFocus bject){
          • 2. Re: setFocus Problem
            Devendran Level 1
            Hello Porkodi,
            Which version of Flash You are using?
            No such a function "onFocusOut"
            Did u got the result Correclty?
            instead of this u have to use "onKillFocus" function
            onSetFocus will give u the OldFocus Name as a parameter,
            onKillFocus Will give u the NewFocus as a parameter.
            It is working fine for two combo component, and other component
            only problem is with InpuText and Combo, InputTextField and combo...
