4 Replies Latest reply on Aug 1, 2016 2:08 AM by tssee@imgof.com
    Select all text layers
    Level 1
      I have a psd file with many text levels
      I would select them all at once
      you think you can do this with a script
      thank you
        • 1. Re: Select all text layers
          Yes you can do that in a script.
          // 2015  John J. McAssey (JJMack)
          // This script is supplied as is. It is provided as freeware.
          // The author accepts no liability for any problems arising from its use.
          // This script will fail when there are text layer that do not have unique layer names
          // enable double-clicking from Mac Finder or Windows Explorer
          #target photoshop // this command only works in Photoshop CS2 and higher
          // bring application forward for double-click events
          app.bringToFront();
          // ensure at least one document open
          if (!documents.length) alert('There are no documents open.', 'No Document');
          else main();
          //  main function
          function main() {
              var textLayers = new Array;
              var numberOfText = 0;
            try { textLayers = processArtLayers(activeDocument,numberOfText,textLayers);}
            // display error message if something goes wrong
            catch(e) { alert(e + ': on line ' + e.line, 'Script Error', true); }
            setSelectedLayers( textLayers )
          // End - main function
          // Function: processsArtLayers
          // Input: document or layer set
          function processArtLayers(obj,numberOfText,textLayers) {
              for( var i = obj.artLayers.length-1; 0 <= i; i--) {
                  try {
                      if(obj.artLayers[i].kind==LayerKind.TEXT) {
              textLayers[numberOfText]=obj.artLayers[i].name
              numberOfText++
                  catch (e) { }
              for( var i = obj.layerSets.length-1; 0 <= i; i--) {
                  processArtLayers(obj.layerSets[i],numberOfText,textLayers);
            return textLayers
          // Function: setSelectedLayers
          // Usage: Selects an array of layers
          // Input:  Array selectedLayers
          // Return: <none>
          function setSelectedLayers( layerIndexesOrNames ) {
            // first select the first one
            setSelectedLayer( layerIndexesOrNames[0] );
            // then add to the selection
            for ( var i = 1; i < layerIndexesOrNames.length; i++) {
            addSelectedLayer( layerIndexesOrNames[i] );
          // Usage: Selects the first layer
          // Return: <none>
          function setSelectedLayer( layerIndexOrName ) {
            try {
            var id239 = charIDToTypeID( "slct" );
            var desc45 = new ActionDescriptor();
            var id240 = charIDToTypeID( "null" );
            var ref43 = new ActionReference();
            var id241 = charIDToTypeID( "Lyr " );
            if ( typeof layerIndexOrName == "number" ) {
            ref43.putIndex( id241, layerIndexOrName );
            } else {
            ref43.putName( id241, layerIndexOrName );
            desc45.putReference( id240, ref43 );
            var id242 = charIDToTypeID( "MkVs" );
            desc45.putBoolean( id242, false );
            executeAction( id239, desc45, DialogModes.NO );
            catch(e) {
            alert(e + ":" + e.line); // do nothing
          // Function: addSelectedLayer
          // Usage: adds the rest of the layers in the array to the first layer
          // Return: <none>
          function addSelectedLayer( layerIndexOrName ) {
            try {
            var id243 = charIDToTypeID( "slct" );
            var desc46 = new ActionDescriptor();
            var id244 = charIDToTypeID( "null" );
            var ref44 = new ActionReference();
            var id245 = charIDToTypeID( "Lyr " );
            ref44.putIndex( id245, layerIndexOrName );
            } else {
            ref44.putName( id245, layerIndexOrName );
            desc46.putReference( id244, ref44 );
            var id246 = stringIDToTypeID( "selectionModifier" );
            var id247 = stringIDToTypeID( "selectionModifierType" );
            var id248 = stringIDToTypeID( "addToSelection" );
            desc46.putEnumerated( id246, id247, id248 );
            var id249 = charIDToTypeID( "MkVs" );
            desc46.putBoolean( id249, false );
            executeAction( id243, desc46, DialogModes.NO );
            catch(e) {
          • 2. Re: Select all text layers
            nvkzNemo Level 2
            • 3. Re: Select all text layers
              Chuck Uebele Adobe Community Professional & MVP
              If you have CC, you can just use the filter for text layers in the layer panel. If you actually then want to select them all, just press shift-alt/opt-A.
              • 4. Re: Select all text layers
                Level 1
                Chuck Uebele
                I know this function but I did not need to use it that way
                anyway thank you for the help.
                Thanks to you too JJMack
