1 Reply Latest reply on Aug 1, 2016 6:06 AM by VectorP
    Error when building IOS app with Adobe RoboHelp
    bernd_steffens
      When I tried to build an IOS app from a RoboHelp 2015 created zip file, the following error message is displayed:
      Error - The following 3rd-party plugin is causing the build to fail and may need to be updated to a newer version: com.indigoway.cordova.whitelist.WhitelistPlugin.
      From the same zip file, an Android app was built without errors.
      The log file for the IOS app build shows the following error:
      The following build commands failed:
      CompileC build/PrinectCockpitHelp.build/Release-iphoneos/PrinectCockpitHelp.build/Objects-normal/a rmv7/CDVNavigationWhitelistPlugin.o PrinectCockpitHelp/Plugins/com.indigoway.cordova.whitelist.WhitelistPlugin/CDVNavigationW hitelistPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
      (1 failure)
      Example: App "Prinect Cockpit Help" with App ID 2188397
      This error does also occur with other Projects which should be built since last friday (07/29/2016).
      This error didn´t occur wiht another similar Project which was built last wednesday (07/27/2016).
      Older Projects were rebuilt without Errors.
