7 Replies Latest reply on Aug 2, 2016 10:14 AM by kglad
    createJS:Bitmap
    JonnyDL Level 1
      I've been looking at createJS code for working with images. Im looking to bring in an image/bitmap from the library. I thought I had found some code to do it, but it does nothing. It compiles, but gives me nothing. Here is the Code, is there a reason why it isn't working (the circle was my first test, and I kept it as a check that the code was compiled without error.)
      Can you bring an image in this way? If not how?
      var circle = new createjs.Shape();
      circle.graphics.beginFill("DeepSkyBlue").drawCircle(0, 0, 50);
      circle.x = 100;
      circle.y = 100;
      stage.addChild(circle);
      createjs.Tween.get(circle, { loop: false })
        .to({ x: 200 }, 1000, createjs.Ease.getPowOut(12))
      //createjs.Tween.get(this.square_mc, { loop: true})
      // .to({ x: 300 }, 3000, createjs.Ease.getPowInOut(12));
      var image = new createjs.Bitmap("Sandies pic9.png"); //In library
      var MC_Container = new createjs.Container();
      MC_Container.addChild(image);
      MC_Container.x=100;
      stage.addChild(MC_Container);
      stage.update();
        • 1. Re: createJS:Bitmap
          that's for loading bitmaps.
          to use a library bitmap, assign a linkage id (eg, Sandies_pic9) and use:
          var image=new lib.Sandies_pic9;
          • 2. Re: createJS:Bitmap
            JonnyDL Level 1
            Thanks for the quick reply.
            I've seen that code before, and it didn't work/compile for me. thats why I went looking for other ways.
            I tried using what you had above, just to see if it would work, but it didn't compile?
            I am placing it as is directly into the actions window (below my shape code) am I missing something?
            • 3. Re: createJS:Bitmap
              just.emma Adobe Community Professional
              Did you assign a linkage ID?
              • 4. Re: createJS:Bitmap
                JonnyDL Level 1
                Wow Thanks! I have never used the Linkage before (didn't know it was an option, Duh). In AS2 AS3 it was a MovieClip and an instance.
                Apparently you use the linkage name in the code (Sandies_pic9). That makes sense now.
                     Thanks Again!
                • 5. Re: createJS:Bitmap
                  ClayUUID Adobe Community Professional
                  Canvas mode uses JavaScript. It is not compiled. There are no compile errors. What you do get are run-time errors
                  • 6. Re: createJS:Bitmap
                    JonnyDL Level 1
                    Clay
                       That was my BAD/LAZY (amateur) choice of words/wording. I can't remember the errors. Once KGLAD gave me a clue at what I was doing wrong and understood it, I got to work staring to try and and build a particle system (snow falling) using Animate CC, CreateJS, and Javascript. I did one before in AS2 I just need to see if I can figure it out in Javascript.
                    Thanks for the response, I appreciate the help.
                    • 7. Re: createJS:Bitmap
                      you're welcome.
                      p.s. message 1 should be marked correct and message 3, helpful.
