3 Replies Latest reply on Aug 8, 2016 10:42 AM by arop16461101
    Pathfinder Unite all objects on each layer
    arop16461101 Level 1
      I wonder if someone can help me to make script, wich doing unite shape mode via pathfinder on all objects on each layer.
      Manually i activate one layer, pushing ctrl + a, then clicking on Unite shape mode button. Then layers are more then 50, it making big peace of time.
        • 1. Re: Pathfinder Unite all objects on each layer
          pixxxel schubser MVP & Adobe Community Professional
          Hi arop16461101,
          in Illustrator DOM isn't a direct command for the pathfinder available.
          But:
          Are there only simple paths in your selection?
          And your Illustrator version is newer than CS5?
          You can try something like this (only CS6+ ):
          // select 2 or more path items
          app.executeMenuCommand("group");
          app.executeMenuCommand("Live Pathfinder Add");
          app.executeMenuCommand("expandStyle");
          Have fun.
          • 2. Re: Pathfinder Unite all objects on each layer
            zertle Level 2
            Piggybacking off of pixxxel schubser
            function MergeAllLayers() {
                // exit early if there are no files open
                if( !app.documents.length ) return;
                var doc = app.activeDocument;
                // clear selection
                doc.selection = null;
                // loop through all layers
                var layers = doc.layers;
                for( var i = 0, ii = layers.length; i < ii; i++ ) {
                    // select everything on the current layer
                    layers[i].hasSelectedArtwork = true;
                    // clear selection
            MergeAllLayers();
            Setting the hasSelectedArtwork Layer property equal to true is a fun trick to select everything on a layer, you just have to make sure to clear any other selection first.
            • 3. Re: Pathfinder Unite all objects on each layer
              I thought that now I will always do it manually. So, many thanks to u! It works  so fast!!!
