4 Replies Latest reply on Aug 2, 2016 1:20 AM by lwilhelmer
    Working and publishing with multiple authors
    lwilhelmer
      Assume author 1 and author 2 are working on the same RH project using version control ("Collaborate" tab).
      Author 1 is editing topic A. Author 2 is editing topic B.
      Both topics already exist in the help project and are published online.
      Now, author 1 has finished updating topic A and wants to publish the new version.
      Unfortunately, author 2 is not done with updating topic B yet. Therefore, his changes on topic B should not be included in the output.
      --> The newly published version of the help project should include:
      - Updated topic A
      - Old topic B
      What would be the easiest way to achieve that in RH 2015?
        • 1. Re: Working and publishing with multiple authors
          Willam van Weelden Adobe Community Professional & MVP
          As long as author 2 doesn't check in the changes, author 1 will have old topic b on his system (and in the version control server). You will get the exact situation as you describe.
          As soon as author 2 checks in, that version is the latest version. And you will get that from RH, unless you specifically get an old version from version control. But that is cumbersome and very error prone.
          • 2. Re: Working and publishing with multiple authors
            lwilhelmer Level 1
            Thanks, Willem. I didn't think of that as an option, because we have "Check in all files when closing a project" enabled in RH settings. So right now, every author always has the latest version of all files. But yes, if we disable that option, that might be a simple solution.
            My concern is that we will run in a lot of version conflicts with that option disabled. Not only topic-related, but also related to project files like rhbag.apj, root.fpj etc. These files will no longer be automatically synced - is that really manageable? Do you know any authoring team that works like this?
            • 3. Re: Working and publishing with multiple authors
              In the update all files dialog, an author can uncheck the files he wants to keep checked out. That would only mean the topics in your case. So that might be a way. That is how some people work. But most of what I've encountered is having this issue with existing topics. And not checking in seems to work most of the time.
              Otherwise, you can use conditional tags. If every author has a tag like Author_1_edit, you can exclude these tags in the output. When someone works on a topic, all new content or changes can be tagged.
              • 4. Re: Working and publishing with multiple authors
                lwilhelmer Level 1
                Thanks, that helped a lot. We will evaluate the options.
