2 Replies Latest reply on Aug 2, 2016 1:57 PM by bmurfey
    Remove Characters from Filename during File Export
    bmurfey
      Hi all,
      I have been working with Silly-V who has been immensely helpful in creating a script to automate file creation through Illustrator.
      What I need some help with now is the ability to add into this script the ability to remove "x #" of characters from a filename during export. This would be ideal as it will totally automate what I have been doing by hand for months.
      The current script we have put together takes what generally would take me ~1 minute per file, and has reduced it to 10 seconds. Translate that across the need to process roughly 800-1,000 files, and you can see where the time invested is decreased significantly.
      The final piece of the puzzle is the removal of characters from only a ONE of the two files that are created via this script.
      First, here is the current script. It seems to be working flawlessly for what I'm asking it to do.
      #target illustrator-19
      function test(){
        var folder_1 = Folder("~/Desktop/Header CAD");
        var folder_2 = Folder("~/Desktop/Clean CAD");
        app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
        function revealAllLayers(doc) {
            for (var i = doc.layers.length - 1; i >= 0; i--) {
                doc.layers[i].visible = true;
        function hideLayer(doc, name) {
            doc.layers.getByName(name).visible = false;
        function exportMyPng(dest, doc, props) {
            if(props.hasOwnProperty("antiAliasing")){
              switch(props.antiAliasing){
                case "ARTOPTIMIZED" : {
                    app.preferences.setIntegerPreference("plugin/PNGFileFormat/AntiAlias", 1);
                    break;
                default : {
                    break;
            var pngOpts = new ImageCaptureOptions();
            pngOpts.antiAliasing = true;
            for (var all in props) {
                if (pngOpts.hasOwnProperty(all) && all != "antiAliasing") {
                    pngOpts[all] = props[all];
            doc.imageCapture(File(dest + "/" + doc.name.replace(/\.\w+$/, props.extraStuff + ".png")), doc.visibleBounds, pngOpts);
        var doc = app.activeDocument;
        revealAllLayers(doc);
        hideLayer(doc, "Materials");
        hideLayer(doc, "Detail Artwork");
        exportMyPng(folder_1, doc, {
            transparency: false,
            antiAliasing: "ARTOPTIMIZED",
            resolution: 300,
            extraStuff: "_header"
        hideLayer(doc, "Header");
        exportMyPng(folder_2, doc, {
            resolution: 300,
            extraStuff: ""
        app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
      test();
      test();
      I have found that the program Name Mangler does an exceptional job of accomplishing the renaming task. Here is a screenshot of what I'm asking for looks like with that program.
      My ultimate goal is to be able to build that single functionality of Name Mangler into the existing script I posted above. Now, the catch is that I ONLY need it to affect the file created by the section of Lines 66-71. As you can see, I need it to remove 14 characters from the filename starting at the index.
      Is this possible, and something anyone can help with?
      Thank you in advance!
      Brooks
        • 1. Re: Remove Characters from Filename during File Export
          Silly-V Adobe Community Professional
          Whew busy days!
          Okay, I got this here:
          #target illustrator
          function test(){
                        break;
                    default : {
                        break;
                doc.imageCapture(File(dest + "/" + doc.name.replace(/\.\w+$/, props.extraStuff + ".png").substr(props.charsOffStart)), doc.visibleBounds, pngOpts);
                resolution: 300,
                extraStuff: "_header",
                charsOffStart: 0
                resolution: 300,
                extraStuff: "",
                charsOffStart: 14
          test();
          This one has a new parameter "charsOffStart" that you've got to stick into your two saving-functions, and it will lop off however many starting characters now!
          • 2. Re: Remove Characters from Filename during File Export
            bmurfey Level 1
            I actually just encountered a small hiccup. About 5-10% of our files are still using the old naming convention from before we switched to a new PLM system. What that means is those 5-10% of files have a prefix that is longer than 14 characters. The only constant that will always be the same is that the last 5 characters of the filename are what is needed for that second created file.
            Silly-V, via email, clarified that to accomodate that factor, I had to change the code from:
                  charsOffStart: 14
            to this:
                  charsOffStart: -9
            This has solved the file naming on export issue perfectly!
