7 Replies Latest reply on Aug 2, 2016 4:30 PM by oleh.melnyk
    Custom Event Listener (for Color Theme Tool)
    oleh.melnyk Level 3
      Problem description: While switching to "Color Theme Tool" selected text becomes deselected. I have already reported that to Adobe as a bug, and bug report received status "ToFix" which means that some day it probably will be fixed... Meanwhile, I thought that this might be fixed with a script.
      I already made a script that can save selected text and restore selection after text were deselected:
      function TextSelection(){
          this.storedSelection;
          function _isText(){
              return app.selection[0].hasOwnProperty("length");
          // Stores text selection in variable
          this.store = function(){
              if(_isText() && app.selection[0].length !== 0){
                  this.storedSelection = app.selection[0].contents;
          // Deselects text
          this.deselect = function(){
                  app.selection[0].insertionPoints[-1].select();
          // Restores stored text selection
          this.restore = function(){
              if(_isText() && this.storedSelection){
                  app.findGrepPreferences.findWhat = this.storedSelection;
                  app.select(app.findGrep());
                  app.findGrepPreferences = null;
      // init object
      dvar textSelection = new TextSelection();
      textSelection.store(); // store selection
      textSelection.deselect(); // deselect text
      textSelection.restore(); // restore selection
      And we can get currently selected tool like that:
      app.toolBoxTools.currentToolName
      In JavaScript, we can write custom event listeners - Creating and triggering events - Web developer guides | MDN
      And seems like Abobe allow us to do that since app.toolBoxTools contains events and eventListeners objects (they are empty by default)
      So, the idea is to create a custom event listener, that will listen for tool changes and call textSelection.store() method, then another eventListener - afterSelectionChanged - will check if currently selected tool is "Color Theme Tool" - then call textSelection.restore() method
      The problem is that I don't know how to implement custom event listeners in InDesign... Can anybody help?
        • 1. Re: Custom Event Listener (for Color Theme Tool)
          oleh.melnyk Level 3
          ToolBoxTools.addEventListener only works every second time seems to be what I was looking for, but still can't make everything work as expected
          • 2. Re: Custom Event Listener (for Color Theme Tool)
            oleh.melnyk Level 3
            Ok, it's almost working!
            It now remembers selection while switching between Type Tool and Color Theme Tool, but when switching between Eyedropper Tool and Color Theme Tool with the mouse - selection still gets lost...
            I made custom shortcuts, that works only for text - Eyedropper Tool - Alt+I, and Color Theme Tool - Ctrl + Shift + I and this allows me to switch with keyboard shortcuts without loosing text selection!
            But still would be nice to make it work with mouse tool switching
            #target indesign
            #targetengine myToolListener
            app.toolBoxTools.addEventListener ("afterAttributeChanged", storeSelection);
            app.toolBoxTools.addEventListener ("afterAttributeChanged", restoreSelection);
            app.addEventListener ("afterSelectionChanged", storeSelection);
            var storedSelection;
            function storeSelection(){
                if(app.selection[0] && app.selection[0].hasOwnProperty("length") && app.selection[0].length !== 0){
                if(app.toolBoxTools.currentToolName.toString() == "Eyedropper Tool"){
            function restoreSelection() {
                if(app.toolBoxTools.currentToolName == "Color Theme Tool") {
                    app.findTextPreferences.findWhat = storedSelection;
                    app.select(app.findText());
                    app.findTextPreferences = null;
            Also, I noticed, that app.toolBoxTools.currentTool for Color Theme Tool is NONE - so this is a bug
            • 3. Re: Custom Event Listener (for Color Theme Tool)
              Hi Oleh,
              today I have no time discussing, but I know that currentTool is returning NONE for the Color Theme Tool.
              The same goes for the Content Collector Tool.
              So currently we have three instances where NONE can be returned:
              1. No tool selected ( that is documented with the DOM documentation, I cannot see that in the UI )
              2. Color Theme Tool *
              3. Content Collector Tool *
              * This is a known bug I already reported and is acknowledged by the developers.
              Cannot tell if and when this will be fixed.
              Regards,
              Uwe
              • 4. Re: Custom Event Listener (for Color Theme Tool)
                Pickory Level 3
                These were introduced quite recently, so is it that the scripting interface is out of step with the application.
                P.
                • 5. Re: Custom Event Listener (for Color Theme Tool)
                  Hi Pickory,
                  introduced "recently" ?
                  At least the Content Collector Tool is with us since InDesign CS6.
                  Back to work now.
                  Uwe
                  • 6. Re: Custom Event Listener (for Color Theme Tool)
                    Pickory Level 3
                    I suspect that CS6 is when the inconsistencies between scripting and the application started.
                    Back to wishing I had one of these.
                    Bristol Channel Pilot Cutter Owners Association
                    P.
                    • 7. Re: Custom Event Listener (for Color Theme Tool)
                      oleh.melnyk Level 3
                      All these inconsistencies between Adobe programs, versions, and OS reminds me of a similar problem with browsers a few years ago. This problem was solved with the creation of the most popular JavaScript library - jQuery - which meant to  solve the problems with inconsistencies between different browsers API.
                      I think we need something similar for Adobe apps because it's really annoying to write hacks and fixes to make script work as expected, and do that all the time!
                      Currently, I have some ideas, but not sure if I would be able to handle all that alone, so if anyone is interested - let me know!
