• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Script to sort table in ascending order
New Here ,
Aug 01, 2016 Aug 01, 2016
I am not able to find any frame maker function to sort the table in ascending order with respect to column 1. Please, guide me how I can write the extended script in frame maker to sort the table.
Thanks & Regards
Lohith
TOPICS
Scripting
Views
2.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Aug 02, 2016 Aug 02, 2016
Here is how you can sort a table with ExtendScript:
#target framemaker
var doc = app.ActiveDoc;
// Set a variable for the selected table.
var tbl = doc.SelectedTbl;
// Select the table.
tbl.MakeTblSelection (Constants.FF_SELECT_WHOLE_TABLE);
// Sort the table.
CallClient ("TableSort", "row nocase 0 ascending -1 ascending -1 ascending");
Here is information from the FDK Programmers Reference for the TableSort parameters:
Votes
Translate
Translate
Community Expert ,
Hi, Lohith,
I do not understand Your question, because there is the menu Table > Sort:
I have set in the dialogue to sort at first by the first column, then by the second. If there are no heading rows then the drop-down list mention the columns by "1st column" etc.
Votes
Translate
Translate
Report
Report
New Here ,
Hi K.Daube,
I know how to sort a table in Frame Maker but I need ESTK script to sort a table.
I am creating a macro for one of my application using ESTK script. In that script, I want to sort a table, for that I need ESTK script to sort the table.
Votes
Translate
Translate
Report
Report
Community Expert ,
#target framemaker
// Sort the table.
Votes
Translate
Translate
Report
Report
New Here ,
Hi Frameexpert,
Thank you very much for your response.
your code is working fine only when you have the curser inside the table.
If I put the curser outside the table, it gives a alert message "? No table has been selected. Please select a table and try again."
Please guide me how can resolve this .
Votes
Translate
Translate
Report
Report
Advocate ,
Lohith,
Instead of using doc.SelectedTbl you need to find your target table via the list of tables in your document. Start with doc.FirstTblInDoc and walk through the linked list until you find the table to sort. Then execute the sort code on it.
Jang
Votes
Translate
Translate
Report
Report
New Here ,
Aug 03, 2016 Aug 03, 2016
LATEST
Hi Jang,
Thanks a lot for your information. Its Working...
Votes
Translate
Translate
Report
Report
