Previous discussions were for older versions of ADE.
I am running ADE 4.5.1.139278 and Windows 10 (fully updated). I am on a relatively new computer and ADE worked the last time I used it on 22 July.
Today when I download a book with ACSM I get the above message. Previous advice suggested de-authorising and re-authorising the computer. When I try this I get a message that effectively says I cannot do this and please try later.
What can I do?
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
It Helped. Happy.
