4 Replies Latest reply on Aug 3, 2016 4:43 PM by Monteigo99
    How to script: If (field 1 through 5 ="N/A") event.value="N/A"
    Monteigo99
      I'm
      still learning and have a script as follows:
      var
      totalY = 0;
      var
      total = 0;
      for
      var totalY = 0;
      var total = 0;
      for (var i=1; i<=5; i++) {
          var f = this.getField("JDCRDropdown"+i);
          if (f.valueAsString=="Y") {
              totalY++;
              total++;
          } else if (f.valueAsString=="N") {
              total++;
      if (total==0) event.value = "N/A";
      else event.value = totalY + " of " + total;
      The
      problem is that and N/A is different than zero of zero. If I leave as is, then the output field defaults to N/A. If I remove: if (total==0) event.value = "N/A";  then it spits out 0 of 0 as the default. What I need is for it to default to 0 of 0, UNLESS all 5 fields are N/A. Then I need the output to be N/A.
      ALL 5 fields must have N/A selected in order for it to populate N/A.
      I've attempted a few different scripts to no avail.
