1 Reply Latest reply on Jun 5, 2006 1:53 PM by Newsgroup_User
    beta 2 project upgrade to beta 3
    tophe1603
      I am trying to open/upgrade an earlier Beta 2 test project into Beta 3.
      Is it possible? I did read somewhere in the docs about needing to "rebuild" projects, but I took that to mean maybe "import" or some such.
      Maybe I'm missing something - unable to find any reference in searches.
      Thanks for any assistance,
      Chris
        • 1. Re: beta 2 project upgrade to beta 3
          Level 7
          Hi tophe1603,
          > Hi,
          You should be able to just do File > New > Flex Project in Beta 3, and
          select your existing project folder as the location of the new project.
          After creating the project, you should do Project > Clean.
          Most likely, there will be some new compiler or runtime errors in your
          application due to API or language changes between Beta 2 and Beta 3.
          You can find a list of changes here:
          http://labs.adobe.com/wiki/index.php/Flex:Beta_2_to_Beta_3_Changes
          If you run into weird issues with the imported project in Flex Builder,
          I would suggest doing the following:
          -- Delete the project from FB without deleting its contents.
          -- Go into the project folder and delete all the files and folders that
          start with "." (e.g. ".project", ".flexProject", ".actionScriptProject",
          ".settings/"), as well as the "bin" and "html-templates" folders
          (assuming you haven't modified the latter). It's possible that the beta
          2 versions of these files might cause problems in beta 3 (although I
          think we try to automatically fix these up).
          -- Re-create the project in FB again as before.
          Hope this helps.
          nj
          Flex Builder team
