11 Replies Latest reply on Aug 26, 2016 9:20 AM by kerrishotts
    What has gone wrong with all the plugins?
    Dan Zen Level 1
      <gap:plugin name="org.apache.cordova.inappbrowser" />
      <gap:plugin name="org.apache.cordova.file-transfer" />
      <gap:plugin name="org.apache.cordova.media" />
      My three plugins (see above) have stopped working.  I get a build error:
      Error - The following core plugin is causing the build to fail and may need to be updated to a newer version: inappbrowser
      and if I comment that out then I get the same message for media, etc.  I also tried putting the last successful plugin code into the config - for instance:
      <gap:plugin name="org.apache.cordova.media" source="pgb" spec="0.2.16" />
      It gave the same error.  I tried deleting the app and starting a new one and the same thing happens.  My app used to work a couple months ago.  And the app build works if I remove all the plugins.
      Any suggestions?
      Vault7/www at master · danzen/Vault7 · GitHub
