5 Replies Latest reply on Aug 3, 2016 4:35 AM by VectorP
    splashscreen display default image cli-6.3.0
    dinhl75813859
      Hi
      After i updated to phonegap cli-6.3.0, did a build and when i open the application it displays the default phonegap image.  Below is my configuration settings for splash screen for ios.  Is there something i must include to remove it?
      <platform name="ios">
        <gap:splash src="res/screen/ios/Default-667h@2x.png"       gap:platform="ios"     width="750" height="1334" />
        <gap:splash src="res/screen/ios/Default-Portrait-736h@3x.png"       gap:platform="ios"     width="1242" height="2208" />
        <gap:splash src="res/screen/ios/Default-Landscape-736h@3x.png"      gap:platform="ios"     width="2208" height="1242" />
        <gap:splash src="res/screen/ios/screen-iphone-portrait-2x.png"      gap:platform="ios"     width="640" height="960" />
        <gap:splash src="res/screen/ios/screen-iphone-portrait-568h-2x.png" gap:platform="ios"     width="640" height="1136" />
        <gap:splash src="res/screen/ios/screen-ipad-portrait.png"           gap:platform="ios"     width="768" height="1024" />
        <gap:splash src="res/screen/ios/screen-ipad-landscape.png"          gap:platform="ios"     width="1024" height="768" />
      </platform>
        • 1. Re: splashscreen display default image cli-6.3.0
          VectorP Level 4
          1. You should use the syntax without gap: namespace. See Icons and Splash | PhoneGap Docs
          2. You apparently want splashes for both landscape and portrait. Your set is quite incomplete, as it doesn't contain both landscape and portrait for each dimension pair.
          • 2. Re: splashscreen display default image cli-6.3.0
            dinhl75813859 Level 1
            hi VectorP
            so if i do the below and follow the Icons and Splash | PhoneGap Docs
            it should work?  Thanks btw
            <!-- iPhone and iPod touch --> <splash src="Default.png" platform="ios" width="320" height="480" /> <splash src="Default@2x.png" platform="ios" width="640" height="960" />  <!-- iPhone 5 / iPod Touch (5th Generation) --> <splash src="Default-568h@2x.png" platform="ios" width="640" height="1136" />  <!-- iPhone 6 --> <splash src="Default-667h@2x.png" platform="ios" width="750" height="1334" /> <splash src="Default-Portrait-736h@3x.png" platform="ios" width="1242" height="2208" /> <splash src="Default-Landscape-736h@3x.png" platform="ios" width="2208" height="1242" />  <!-- iPad --> <splash src="Default-Portrait.png" platform="ios" width="768" height="1024" /> <splash src="Default-Landscape.png" platform="ios" width="1024" height="768" />  <!-- Retina iPad --> <splash src="Default-Portrait@2x.png" platform="ios" width="1536" height="2048" /> <splash src="Default-Landscape@2x.png" platform="ios" width="2048" height="1536" />
            • 3. Re: splashscreen display default image cli-6.3.0
              VectorP Level 4
              That's the proper syntax.
              However:
              - of course, I can't check whether or not you included those images, with the correct dimensions, under the specified path
              - you still need to include the other splash images, since several are still missing.
              • 4. Re: splashscreen display default image cli-6.3.0
                VectorP
                If i include the below for IOS it should be complete?
                <splash src="res/screen/ios/Default.png" platform="ios" width="320" height="480" />
                <splash src="res/screen/ios/Default@2x.png" platform="ios" width="640" height="960" />
                <splash src="res/screen/ios/Default-568h@2x.png" platform="ios" width="640" height="1136" />
                <!-- iPhone 6 -->
                <splash src="res/screen/ios/Default-667h@2x.png" platform="ios" width="750" height="1334" />
                <splash src="res/screen/ios/Default-Portrait-736h@3x.png" platform="ios" width="1242" height="2208" />
                <splash src="res/screen/ios/Default-Landscape-736h@3x.png" platform="ios" width="2208" height="1242" />
                <!-- iPad -->
                <splash src="res/screen/ios/Default-Portrait.png" platform="ios" width="768" height="1024" />
                <splash src="res/screen/ios/Default-Landscape.png" platform="ios" width="1024" height="768" />
                <splash src="res/screen/ios/Default-Portrait@2x.png" platform="ios" width="1536" height="2048" />
                <splash src="res/screen/ios/Default-Landscape@2x.png" platform="ios" width="2048" height="1536" />
                • 5. Re: splashscreen display default image cli-6.3.0
                  VectorP Level 4
                  No!
                  You should have both landscape and portrait for each and every image.
                  (The first four of your set don't have a landscape version)
