2 Replies Latest reply on Aug 10, 2016 7:00 AM by BobLevine
    Exporting Pages with pre-determined info
    rsukhram@tgioa.com Level 1
      So i have this file that I created as a template.  It consist of 2 sizes and black and white for each (so it's 4 pgs).  My process has been to export the doc as a pdf, then split the pages from Acrobat.  Then remove the suffix from the split file and move it to a certain folders.
      My question is there a way to have your pages export specifically to a folder as a pdf.
      so lets assume the the filename is 123.indd
      pg 1 would export to [folder-1] as filename 123.pdf
      pg 2 would export to [folder-2] as filename 123.pdf
      pg 3 would export to [folder-3] as filename 123.pdf
      pg 4 would export to [folder-4] as filename 123.pdf
      The reason i need to keep the filenames the name is for the link to folder option (which i use to handle quick changes from color to b&w.
      thanks in advance for your replies.
