0 Replies Latest reply on Aug 3, 2016 12:37 PM by jbrock777
    CF2016 uriworkermap.properties not loading in Apache2 Virtualhost
    jbrock777
      Hello Community!
      Working on application isolation paired with multi instance load balancing and came across what I would consider a bug.
      The uriworkermap.properties file included in the mod_jk.conf for Apache on RHEL 7 is seemingly completely ignored by my virtualhost.
      In all the documentation I came across, the uriworkermap.properties is where to specify the mount points for each of the workers.
      What clued me into it not working as I had anticipated, was that every time I ran ab to test the load balancing between different application paths, the first worker listed in workers.properties->worker.list would always handle the requests.
      The solutions I have come across so far :
      1. Include the uriworkermap.properties inside of the <virtualhost> config
      JkMountFile "/opt/coldfusion2016/config/wsconfig/1/uriworkermap.properties"
      2. Or Add JkMount entries in the <virtualhost> config
      #Load balanced application isolation
      JkMount /mysecureapp1 secureapps
      JKMount /mysecureapp1/* secureapps
      JKMount /* generalapps
      I am very curious if this is by design.
      Here is the setup and configs (minus the tomcat instance's server.xml files) if anyone cares to have a look.
      Setup :
      RHEL 7 X64 Minimum install
      Coldfusion2016 Enterprise Edition patched to 2016.0.02.299200
      Tomcat Version 8.0.32.0
      Java JRE Server 1.8.0_102
      mod_jk shipped with cf2016
      Config Files :
      /etc/httpd/conf/httpd.conf  (tail end)
      # Supplemental configuration
      # Load config files in the "/etc/httpd/conf.d" directory, if any.
      IncludeOptional conf.d/*.conf
      Include "/etc/httpd/conf/mod_jk.conf"
      # Load mod_jk module
      LoadModule    jk_module  "/opt/coldfusion2016/config/wsconfig/1/mod_jk.so"
      # Where to find workers.properties
      JkWorkersFile "/opt/coldfusion2016/config/wsconfig/1/workers.properties"
      # Where to put jk logs
      JkLogFile "/opt/coldfusion2016/config/wsconfig/1/mod_jk.log"
      # custom environment variables
      JkEnvVar REDIRECT_URL
      JkEnvVar REDIRECT_REMOTE_HOST
      JkEnvVar REDIRECT_PATH
      JkEnvVar REDIRECT_QUERY_STRING
      JkEnvVar REDIRECT_HTTP_ACCEPT
      JkEnvVar REDIRECT_HTTP_USER_AGENT
      JkEnvVar REDIRECT_REMOTE_ADDR
      JkEnvVar REDIRECT_SERVER_NAME
      JkEnvVar REDIRECT_SERVER_PORT
      JkEnvVar REDIRECT_SERVER_SOFTWARE
      # Where to put jk shared memory
      JkShmFile "/opt/coldfusion2016/config/wsconfig/1/jk_shm"
      # Set the jk log level [debug/error/info]
      JkLogLevel info
      # Select the timestamp log format
      JkLogStampFormat "[%a %b %d %H:%M:%S %Y] "
      AddHandler jakarta-servlet .cfm .cfml .cfc .cfr .cfswf
      DirectoryIndex index.cfm
      Alias /cf_scripts "/opt/coldfusion2016/cfusion/wwwroot/cf_scripts"
      <Directory "/opt/coldfusion2016/cfusion/wwwroot/cf_scripts">
      Options Indexes FollowSymLinks
      AllowOverride None
      Require all granted
      </Directory>
      <Files ~ ".hbmxml$">
      Require all denied
      </Files>
      worker.list=generalapps,secureapps,tomcatstatus
      worker.cfusion1.type=ajp13
      worker.cfusion1.host=localhost
      worker.cfusion1.port=8012
      worker.cfusion1.max_reuse_connections=250
      worker.cfusion1.lbfactor=1
      worker.cfusion1.cachesize=30
      worker.cfusion1.route=cfusion1
      worker.cfusion2.type=ajp13
      worker.cfusion2.host=localhost
      worker.cfusion2.port=8013
      worker.cfusion2.max_reuse_connections=250
      worker.cfusion2.lbfactor=1
      worker.cfusion2.cachesize=30
      worker.cfusion2.route=cfusion2
      worker.cfusion3.type=ajp13
      worker.cfusion3.host=wt-cf2016-2
      worker.cfusion3.port=8012
      worker.cfusion3.max_reuse_connections=250
      worker.cfusion3.lbfactor=1
      worker.cfusion3.cachesize=30
      worker.cfusion3.route=cfusion3
      worker.cfusion4.type=ajp13
      worker.cfusion4.host=wt-cf2016-2
      worker.cfusion4.port=8013
      worker.cfusion4.max_reuse_connections=250
      worker.cfusion4.lbfactor=1
      worker.cfusion4.cachesize=30
      worker.cfusion4.route=cfusion4
      worker.tomcatstatus.type=status
      worker.secureapps.type=lb
      worker.secureapps.balance_workers=cfusion1,cfusion3
      worker.secureapps.sticky_session=false
      worker.generalapps.type=lb
      worker.generalapps.balance_workers=cfusion2,cfusion4
      worker.generalapps.sticky_session=false
      /mysecureapp1=secureapps
      /mysecureapp1/*=secureapps
      /*=generalapps
