2 Replies Latest reply on Aug 4, 2016 1:17 PM by Silly-V
    Scaling a pathItem over and over.
    richardw26639360 Level 1
      I'm to create a hexagon and duplicating it 23 times. But I also need each duplicate to scale 96% off the one before it. This is what I have so far...
      var doc = app.activeDocument;
      var p = doc.pathItems.polygon(0,0,23,6);
      p.filled = false;
      p.stroked = true;
      q = 23;
      percentageX = 96
      percentageY = percentageX
        for (var j=0; j<q; j++)
      {myDuplicate = p.duplicate();
        for (var k=0; k<myDuplicate; k++)
        { myDuplicate.resize(percentageX, percentageY);}
      It only scales once and then every duplicate after that is the same size as the first duplicate. How can I get it to scale each duplicate to be smaller than the duplicate before it?
        • 1. Re: Scaling a pathItem over and over.
          Alexander Ladygin Level 2
          as an option:
          var doc = app.activeDocument,
              p = doc.pathItems.polygon(0, 0, 23, 6),
              myDuplicate = p,
              percentageX = 96,
              percentageY = percentageX,
              q = 23;
          p.filled = false;
          p.stroked = true;
          for ( var i = 0; i < q; i++) {
              myDuplicate = myDuplicate.duplicate();
          • 2. Re: Scaling a pathItem over and over.
            Silly-V Adobe Community Professional
            You can also try to use this cool effect method:
            #target illustrator
            function test(){
                var p = doc.selection[0];
                var effectStr_2 =
                '<LiveEffect name="Adobe Transform">' +
                    '<Dict data="' +
                        'R scaleH_Factor 0.96 ' +
                        'R moveV_Pts 0.00 ' +
                        'R scaleV_Percent 96.00 ' +
                        'I pinPoint 4 ' +
                        'B scaleLines 0 ' +
                        'I numCopies 23 ' +
                        'B randomize 0 ' +
                        'R rotate_Radians 0.00 ' +
                        'R moveH_Pts 0.00 ' +
                        'R scaleV_Factor 0.96 ' +
                        'B reflectY 0 ' +
                        'B reflectX 0 ' +
                        'R rotate_Degrees 0.00 ' +
                        'R scaleH_Percent 96.00 ' +
                        'B transformPatterns 1 ' +
                '</LiveEffect>';
                p.applyEffect(effectStr_2);
            test();
