11 Replies Latest reply on Aug 12, 2016 7:10 AM by eyepoker
    First time using PGB - app never builds, constant file plugin error
    eyepoker Level 1
      Hello - I'm trying to build for the first time and a lot of plugins are giving errors. I'm commenting them out one at a time from the config XML and one of the culprits is the file plugin which I need to use. The other one is the network plugin which also gives errors. The errors state that they are not compatible with CLI 6.3.0
      I realize it is up to the plugin developer to make it compatible - is there something somewhere that shows what versions of plugins are compatible with what versions of PGB? How do i know what previous version of PGB is compatible with anything?
      Also, and this might be relevant to the issue - when i look at PGB to see what versions I'm building for, I see this that apparently I'm targeting iOS4.2?
      http://www.rickluna.com/pgb_err.png
      In my XML I'm trying to deploy to iOS 9 but the value in PGB doesnt change from v 4.2
      <preference name="deployment-target" value="9.0" />
      TIA for any suggestions!
      -r
