3 Replies Latest reply on Aug 5, 2016 12:44 AM by Peter Kahrel
    'Cancel' Export Option should stop
    BEGINNER_X Level 3
      Hi All,
      I have small clarifications, but not work out...
       app.activeDocument.exportFile(ExportFormat.JPG, File("~/Desktop/abc.jpg"), true);
      If I click Cancel, then the Script should stop.
      If I click Export, then the Script move to next task in the same script.
      Siraj
        • 1. Re: 'Cancel' Export Option should stop
          karthiks94217840 Level 2
          Hi G,
          Try this below code;
          app.activeDocument.exportFile(ExportFormat.JPG, File("~/Desktop/abc.jpg"), false);
          One more thing;
          What your need to export jpg?
          1. Export to JPG - all pages
          2. Export to JPG - page range
          3. Export to JPG - selection
          KS
          • 2. Re: 'Cancel' Export Option should stop
            BEGINNER_X Level 3
            Hi All,
            Trying code is below:
            Please read comments,
            var myJpeg_name = app.activeDocument.name.replace(/\.indd/i, ".jpg")
            var myFolder=Folder.selectDialog("Choose JPG Save Location");
            if(myFolder != null)
              var myFile = File(myFolder + "/" + myJpeg_name);
              var myCheck = app.activeDocument.exportFile(ExportFormat.JPG, myFile, true);
              //-----------------Here is facing problem------------------
              if(myCheck != null)   //If customer click Export, then export
                  //Proceed
              else    //If customer click cancel, then the 'Process Completed" not shown
                  exit(0)
            else
                exit(0)
                  alert("Proceed")
            var myRes = app.jpegExportPreferences.exportResolution;
            alert(myRes)
            var myColor = app.jpegExportPreferences.jpegColorSpace;
            alert(myColor)
            alert("Process Completed")
            • 3. Re: 'Cancel' Export Option should stop
              Peter Kahrel Adobe Community Professional & MVP
              Use undefined, not null:
              if (myCheck === undefined) {
                 // Cancel clicked, exit
                 exit()
              You can figure out a return value just by executing the single command. So if you run this in the ESTK:
              and click Cancel in the dialog window, the ESTK prints undefined, not null.
              Peter
