5 Replies Latest reply on Aug 4, 2016 9:22 PM by IdamIndia
    How to maintain LR Catalog on 2 backup drives?
    lpolson53
      I have 2 identical external hard drives that I’ve purchased to use as back up for my MacBook Pro. I plan to keep one of them offsite and swap them around once a month to keep both updated. Both drives have been partitioned to use half the space for back up with Time Machine. The other half is used to store about 1/2 my photos files, which I have removed from my hard drive to make more space. These files are not included in the Time Machine backup, but all the same files are on both external drives.  I have a LOT of photos.
      So, I have Lightroom 5 & I can’t quite figure out how to handle my Lightroom catalog updates.  When I moved the files from my MAC hard drive to “Drive A”, I moved them within Lightroom to that drive, so it knows where they are. But what if I have “Drive B” at home instead, and want to work on some of those photos? How do I maintain LR catalog updates (including movement of files potentially) on both drives, and be able to use the catalog to find photos on either drive?
      Thanks in advance for any suggestions!
        • 1. Re: How to maintain LR Catalog on 2 backup drives?
          thedigitaldog MVP & Adobe Community Professional
          Clone using something like SuperDuper (inexpensive, easy to use).
          Not sure I'd have a TM Partition but that's a different story. But SuperDuper will treat the one partition like a single drive. It will clone from Drive A to Drive B, only new files so it's pretty fast.
          You might want to consider using the "Store Presets with Catalog" preference so that important data is saved with the catalog and cloned.
          SuperDuper!
          • 2. Re: How to maintain LR Catalog on 2 backup drives?
            Just Shoot Me Adobe Community Professional
            From my brief use of a Mac, about 2.5 years, the one thing that always came up was using an external drive for both Time Machine backups and that same drive for storing other files. It is not suggested to do that. A Time Machine drive should be dedicated to just that, Time Machine.
            This also goes for using any of the other backup/cloning software programs available for the Mac. It is always best to have specific dedicated drives for just backups and other drives for whatever other purpose you like.
            • 3. Re: How to maintain LR Catalog on 2 backup drives?
              Just Shoot Me wrote: A Time Machine drive should be dedicated to just that, Time Machine.
              I totally agree. And so should IMHO, a drive that has LR catalog and all associated files and images! You can take that drive to any machine that has LR app and have access to all your images and the catalog. Since image files (and previews) can take up a lot of drive space, (like TM), best to get the biggest drive you can find and dedicate only for those files.
              • 4. Re: How to maintain LR Catalog on 2 backup drives?
                JoeKostoss Adobe Community Professional
                I agree with thedigitaldog on using SuperDuper.  I have it and keep 2 EHDs connected to my iMac at all times.  It clones the 2nd drive with my 1st.  I import all photos onto the 1st EHD and keep a backup copy of the catalog on that same 1st EHD.  Lightroom works perfectly well with the photos on the EHD; there is no need to have them on your computer drive.  This eliminates the process of moving files and avoids any problems with missing files.  You can find SuperDuper here.
                • 5. Re: How to maintain LR Catalog on 2 backup drives?
                  IdamIndia
                  This is how I do it:
                  Where are the clones?
                  1. I have a dedicated 2TB ext USB drive (nearing completion soon) - but does not contain my slide scans which are on an another 2TB drive.
                  2. I use a RAID10 6TB drive that is used once in a while to "sync" its clone, manually using WinMerge
                  3. I have a 2TB internal drive that has (if one wants to think) the main catalog,where I dump pictures from the cameras.
                  BUT for me, my main LR is the ext USB 2TB drive that shuttles between the Studio and home. It is the source for sync of others.
                  Methods of cloning?
                  1. MANUAL: I use a little app called WinMerge to manually compare and sync files. The preview folders I skip as they have too many files and it is better to simply replace the entire folder with newer one. Winmerge is quick and fast and at times, when I do a much more lengthy binary compare, has pointed out image files mismatch - and I discovered a corrupted file (half had some green issue), which I could fix from the clone that was fine. Binary compare can take a real long time, do it only for image folders and catalog NOT preview folders.
                  2. AUTOMATIC: I use Bittorrent Sync, where I have setup a sync folder. The folders over the network keep themselves in sync automatically. It also has an auto archive and version control system - which has been useful for my work files (not LR or images sofar).
                  Note, if one thing is deleted, it is deleted everywhere with this method! Therefore I use only manual sync with my RAID10 6TB.
                  Why LR catalogs only? I do this for my project folders too. The bittorrent sync infact, even syncs over internet.
