1 Reply Latest reply on Aug 5, 2016 1:44 AM by VectorP
    Need help with APK release
    hexrdesign
      I made my edits in the www folder and using the developer app on my android phone, I can see that it runs perfectly well. I then upload the whole thing to github and then pull the apk and it seems as though the Hello World initial thing comes back. I was wondering if there is a way to stop this and so I can see my own app.
      Thanks in advance
        • 1. Re: Need help with APK release
          VectorP Level 4
          I assume that you are building with Phonegap Build from your GitHub account.
          In that case, the Developer App was a bad start, since it isn't compatible with PGB.
          Phonegap Build requires your assets and a config file only, where both index.html and config.xml should be in the root of your repo, and no cordova.js or phonegap.js file should be present in your assets.
          Also, from the developer app, you may be using old, deprecated plugins from pgb instead of the latest versions of them from npm.
          See the Phonegap Build Docs.
