4 Replies Latest reply on Aug 5, 2016 4:53 AM by karthiks94217840
    Fix Tab Position
    karthiks94217840 Level 2
      Hi Friends,
      I want a script that can fix tab position for starting all paragraph first 3 tabs position only. Otherwise, don't change to other tabs potions.
      (That function working to single line).
      I was try some code but not work out and all tab position automatically changed. Please see my code below:
      Example:
      First tab position - 10 points:
      Second tab position - 30 points:
      Three tab position - 50 points:
      app.findGrepPreferences = app.changeGrepPreferences = null;
      app.findGrepPreferences.findWhat = "(\\t\\t\\t)";
      var myFnd = myDoc.findGrep();
      var a = 0;
      for(var i=0;i<myFnd.length;i++)
          var tabstops = myFnd[i].tabStops;
          for(var j =0;j<tabstops.length;j++)
                  tabstops[j].position =  a+=20;
      Please see my screenshot also below:
      Please suggest friends,
      Thanks in Advance.
        • 1. Re: Fix Tab Position
          Peter Kahrel Adobe Community Professional & MVP
          Do a grep search for ^\\t\\t\\t
          In your script, you change all tab stops in a paragraph, not just the ones in your selection. Instead, do something like this:
          var tabStops = myFnd[i].tabStops;
          tabStops[0].position = 10;
          tabStops[1].position = 30;
          tabStops[2].position = 50;
          Peter
          • 2. Re: Fix Tab Position
            Hi Pkahrel,
            Thank to your replay.
            I have add your code in my script. But, not full fill my requirement. First 3 tab position it's working fine. But, continues (tab-4, tab-5, tab-6, .........) tab position is also changed. No need to change other tabbed positions.
            Below my merge code:
            var a = 0;
            I am going is right way? Please suggest friends.
            Thanks in Advance.
            • 3. Re: Fix Tab Position
              tpk1982 Level 4
              karthik see hwta Peter said in first line
              so use ^, it is missing in your code
              • 4. Re: Fix Tab Position
                Hi Friends,
                @Pkahrel: Sorry! My bad time, I have missing your first line comment.
                @TPK: Thanks, you are find out my missing Grep function.
                My requirement Done.
                Thanks to all
                KS
