4 Replies Latest reply on Aug 9, 2016 8:28 AM by Vamitul
    Error in script to relink in Indesing
    Dinafanoe
      Yesterday  I was given a script that relinked in Indesign so fast - and I have used  numerous times yesterday and today.
      BUT al of a sudden it gives me a java script error, no 29942 (se attached screenshot)Screen Shot 2016-08-05 at 14.28.09.png
      the script is:
      function main() {
          var doc = app.activeDocument;
          var myLinks = doc.links.everyItem().getElements();
          var linkObj = {};
          // create inital object
          /* linkObject {
                          [path]{missingNr,
                                arrayOfMissingLinks}
          for (var i = 0; i < myLinks.length; i++) {
              if (myLinks[i].status == LinkStatus.LINK_MISSING) {
                  var myPath = File(myLinks[i].filePath).path.toString();
                  if (linkObj[myPath] == undefined) {
                      linkObj[myPath] = {
                          missingNr: 1,
                          missingLinks: [myLinks[i]],
                          newPath: ''
                  } else {
                      linkObj[myPath].missingNr++;
                      linkObj[myPath].missingLinks.push(myLinks[i].getElements()[0]);
          //$.writeln(linkObj.toSource());
          var myDialog = new Window('dialog', 'Link Chaser:', undefined);
          var panel1 = myDialog.add('panel', undefined, 'Double click to select new path');
          panel1.align = ['fill', 'fill'];
          var myList = panel1.add('listBox', undefined, "", {
              columnWidths: [160, 160, 130],
              numberOfColumns: 3,
              showHeaders: true,
              columnTitles: ['Old Path', 'New Path', 'Nr. of missing links']
          myList.size = [450, 200];
          myList.align = ['fill', 'fill'];
          for (var missingPath in linkObj) {
              with(myList.add('item', missingPath)) {
                  subItems[0].text = linkObj[missingPath].newPath;
                  subItems[1].text = linkObj[missingPath].missingNr;
          myList.onDoubleClick = function() {
              var myNewPath = (new Folder(app.activeDocument.filePath).selectDlg("Select New Folder") || '').toString();
              myList.selection.subItems[0].text = myNewPath;
              linkObj[myList.selection.text].newPath = myNewPath;
          myDialog.add('button', undefined, "Ok", {
          myDialog.add('button', undefined, "Cancel", {
          if (myDialog.show() == 1) {
              for (var i in linkObj) {
                  if (linkObj[i].newPath != '') {
                      var fixedNr = 0;
                      var links = linkObj[i].missingLinks
                      for (var j = 0; j < links.length; j++) {
                          var newFile = File(linkObj[i].newPath + "/" + links[j].name);
                          if (newFile.exists) {
                              fixedNr++;
                              links[j].relink(newFile);
                      alert('In folder:\n' + linkObj[i].newPath + '\n' +
                          'Fixed ' + fixedNr + ' links out of ' + linkObj[i].missingNr + '\n' +
                          'Please check');
      app.doScript('main()', undefined, undefined, UndoModes.entireScript, "Link Chaser");
      I have NOT changed anything, any procedure and the document is similar to the other ones so I dont understand why this is failing :-(
      Any help please...???
