0 Replies Latest reply on Jun 3, 2006 3:03 PM by walkingcrab
    using the last frame from the effect
    walkingcrab
      So I'm making this flash header for a website, and I applied the effect that makes text move to the side while shrinking. After that the flash stops and it stays as a logo. But for the last frame of the effect, I cannot copy it and have to make a frame and manually place the text. The problem with this is that it's impossible to put it in exactly the same place and there is a small jump at the end, as you will see in the flash. http://media.putfile.com/giudeselliottflashheader123
      Is there any solution to the problem, here is the fla if you want to have a look and see if you can fix it. Thanks
      http://www.oxyshare.com/get/1902463554448205cf32086/giudeselliottflashheader123.fla.html
