9 Replies Latest reply on Aug 9, 2016 3:10 AM by scriptworker
    Write last folder naming
    karthiks94217840 Level 2
      Hi Friends,
      I need your help!
      @My work (write report): I need to write last revision folder name only. Also, i was try to some code, that code is write-report for all folder name is given. But. i need to last folder names only. I have place some example screenshot below:
      After run my script generate the report. (Wrong Report)
      I need report. (correct Report)
      My code below:
      var Report = new File("C:/Users/karthiks/Desktop/z/Client78_Revision Report.txt" );
      Report.open("w");
      Report.writeln("Journal Name\tArticle ID\tNumber of Revision\r*********************************\r\r");
      var basePath = "C:\\Users\\karthiks\\Desktop\\z";  // Local path:
      var basePathFiles = Folder(basePath).getFiles();
      var basePathFilesLen = basePathFiles.length;
      for (var bsf = 0; bsf < basePathFilesLen; bsf ++){
                  if (basePathFiles[bsf] instanceof Folder){
                      var articleFolder = Folder(basePathFiles[bsf].fullName);
                      var articleFolderSubFolders = articleFolder.getFiles();
                      var articleFolderSubFoldersLen = articleFolderSubFolders.length;
                      for (var i=0; i<articleFolderSubFoldersLen; i++){
                              var currFolder = articleFolderSubFolders[i];
                              var currFolderName = currFolder.name;
                              var  articleFolder2 = Folder(currFolder + '\\' + currFolder.name + '_Inputs\\');
                              var articleFolderSubFolders2 = articleFolder2.getFiles();
                              var articleFolderSubFoldersLen2 = articleFolderSubFolders2.length;
                                  for (var n=0; n<articleFolderSubFoldersLen2; n++){
                                          var currFolder2 = articleFolderSubFolders2[n];
                                          var currFolderName2 = currFolder2.name;
      //~                                            alert(currFolderName2);
                                     if (articleFolderSubFoldersLen2 > 4){
      //***************************** something i have missing code here  *********************
                                              Report.writeln(articleFolder.name + "\t" + currFolder.name+ "\t" + currFolderName2 + "\n")
      Report.close();
      please suggest friends.
      Thanks in Advance.
      KS
        • 1. Re: Write last folder naming
          HI,
          This my folder structure:
          Thanks in Advance.
          KS
          • 2. Re: Write last folder naming
            scriptworker
            If you do this:
            var currFolder2 = articleFolderSubFolders2[articleFolderSubFolders2.length-1].toString().split('_')[0];
            var revision = articleFolderSubFolders2[articleFolderSubFolders2.length-1].toString().split('_')[1]
            You will have the folder and revision number.
            Is that what you are looking for?
            Michel
            • 3. Re: Write last folder naming
              Hi SW,
              Thanks to your replay,
              Is that what you are looking for?  ----> I need to collect for all latest files (project voices) total No.of project above 100.
              EXP: Our Folder Structure below:
              Project Name --> AHMT --> 108531 --> 108531_Inputs -- > 108531_Final
        108531_First Proof
        108531_R1
        108531_R2
        108531_R3
              That above structure R2 and before all file default structure this is no needed. But R3 and after received files i need to write report.
              @One more question: I have add your above code in my script. That code alert(Final, First_proof, R1, R2 and R3) for one by one. But i need to alert(R3) latest folder only.
              Please suggest friends.
              Thanks in Advance
              KS
              • 4. Re: Write last folder naming
                This structure i like this,
                AA54321R4
                AHMT108531R4
                AHMT109587R3
                AHMT65820R3
                AHMT79060R2
                AMEP100660R4
                AMEP101099R3
                AMEP101395R1
                AMEP101698R2
                AMEP102000R7
                AMEP102081R2
                AMEP102111R1
                • 5. Re: Write last folder naming
                  scriptworker Level 1
                  Did you place the code outside the for-loop?
                  I think you do not need the last for-loop.
                  Michel
                  • 6. Re: Write last folder naming
                    Hi SW,
                    I have used your second code. That code i have modified one number only, after that working good.
                    Modified code:
                    var revision = articleFolderSubFolders2[articleFolderSubFoldersLen2-1].toString().split('_')[2] // change 1 to 2.
                    @One more thing: Some of the project i have received above 14 files "R14". But, Here with alert for only "R9" this code counsel for "R9" is last folder, but 14 folder is there). I have place screenshot for your reference.
                    Example:
                    I need to alert for last folder name R14. Please suggest friend
                    My code also below:
                    Report.open("w");
                    ************************************** In below your code ***********************
                                                alert(currFolder.name +  "/" + revision)
                                                    Report.writeln(articleFolder.name + "\t" + currFolder.name+ "\t" + revision + "\n")
                    Report.close();
                    Thanks In advance
                    • 7. Re: Write last folder naming
                      It has to do with the sortorder of the folders in the parent folder.
                      You should sort them first like this:
                      var folders = ['90737_Final','90737_FirstProof','90737_R1','90737_R10','90737_R11','90737_R12','90737_R 13','90737_R14','90737_R2','90737_R3','90737_R4','90737_R5','90737_R6','90737_R7','90737_R 8','90737_R9'];
                      var sorted = folders.sort(function(x,y)
                        var f1 = x.split('_')[1].match(/\d+/);
                        var f2 = y.split('_')[1].match(/\d+/);
                        return f1-f2;
                      alert(sorted[sorted.length-1].split('_')[1]);
                      • 8. Re: Write last folder naming
                        Hi SW,
                        One more thanks,
                        @Ok right: I understand that (thanks your good explain SW).
                        @simple one question: How to get folder 14 "R14" alert?
                        Thanks In advance
                        KS
                        • 9. Re: Write last folder naming
                          Well, if you do this:
                          var sortedFolders = articleFolderSubFolders2.sort(function(x,y)
                            return f1-f2;
                          alert(sortedFolders[sortedFolders.length-1].split('_')[1]);
                          You should get the result you want.
                          Michel
