6 Replies Latest reply on Aug 10, 2016 7:47 AM by abhijeett89122812
    PDF Script
    abhijeett89122812 Level 1
      var gScriptName = "Batch export INDD-files to PDF"; // Name of the script
      var gScriptVersion = "1.0"; // Version
      var gSet = GetSettings();
      CreateDialog();
      //===================================== FUNCTIONS  ======================================
      function CreateDialog() {
      var pdfPresetsList =app.pdfExportPresets.everyItem().name;
      var win = new Window("dialog", gScriptName + " - " + gScriptVersion);
      win.p = win.add("panel", undefined, "");
      win.p.alignChildren = "right";
      win.p.alignment = "fill";
      win.p.g = win.p.add("group");
      win.p.g.st = win.p.g.add("statictext", undefined, "PDF-presets:");
      win.p.g.ddl = win.p.g.add("dropdownlist", undefined, pdfPresetsList);
      win.p.g.ddl.selection = gSet.selectedPdfPresetIndex;
      win.p.g.ddl.preferredSize.width = 220;
      win.buttons = win.add("group");
      win.buttons.orientation = "row";
      win.buttons.alignment = "center";
      win.buttons.ok = win.buttons.add("button", undefined, "OK", {name:"ok" });
      win.buttons.cancel = win.buttons.add("button", undefined, "Cancel", {name:"cancel"});
      var showDialog = win.show();
      if (showDialog == 1) {
        gSet.selectedPdfPresetIndex = win.p.g.ddl.selection.index;
        app.insertLabel("Kas_" + gScriptName + gScriptVersion, gSet.toSource());
        Main();
      function Main() {
      var folder = Folder.selectDialog("Select a folder with InDesign files to export");
      if (folder == null) exit();
      var files = GetFiles(folder);
      var pdfFolder = new Folder(folder.fsName + "/" + "Pdf");
      VerifyFolder(pdfFolder);
      if (files.length == 0) {
        alert("No files to open.", gScriptName + " - " + gScriptVersion);
        exit();
      var pdfPresets =app.pdfExportPresets.everyItem().getElements();
      var selectedPdfPreset = pdfPresets[gSet.selectedPdfPresetIndex];
      var count = 1;
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
      var progressWin = new Window ("window", gScriptName + " - " + gScriptVersion);
      var progressBar = progressWin.add ("progressbar", [12, 12, 350, 24], 0, files.length);
      var progressTxt = progressWin.add("statictext", undefined, "Starting exporting files");
      progressTxt.bounds = [0, 0, 340, 20];
      progressTxt.alignment = "left";
      progressWin.show();
      for (var i = 0; i < files.length; i++) {
        var currentFile = files[i];
        try {
         var doc = app.open(currentFile, false);
         var docName = doc.name;
         // Progress bar -----------------------------------------------------------------------------------
         progressBar.value = count;
         progressTxt.text = String("Exporting file - " + docName + " (" + count + " of " + files.length + ")");
         var file = new File(pdfFolder + "/" + GetFileName(docName) + ".pdf");
         if (file.exists) {
          var increment = 1;
          while (file.exists) {
           file = new File(pdfFolder + "/" + GetFileName(docName) + "(" + increment++ + ").pdf");
         doc.exportFile(ExportFormat.pdfType, file, false, selectedPdfPreset);
         doc.close(SaveOptions.NO);
         count++;
        catch(e) {}
      progressWin.close();
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
      alert("Done.", gScriptName + " - " + gScriptVersion);
      function VerifyFolder(folder) {
      if (!folder.exists) {
        var folder = new Folder(folder.absoluteURI);
        var array1 = new Array();
        while (!folder.exists) {
         array1.push(folder);
         folder = new Folder(folder.path);
        var array2 = new Array();
        while (array1.length > 0) {
         folder = array1.pop();
         if (folder.create()) {
          array2.push(folder);
         } else {
          while (array2.length > 0) {
           array2.pop.remove();
          throw "Folder creation failed";
      function GetFiles(theFolder) {
      var files = [],
      fileList = theFolder.getFiles(),
      i, file;
      for (i = 0; i < fileList.length; i++) {
        file = fileList[i];
        if (file instanceof Folder) {
         files = files.concat(GetFiles(file));
        else if (file instanceof File && file.name.match(/\.indd$/i)) {
         files.push(file);
      return files;
      function GetFileName(fileName) {
      var string = "";
      var result = fileName.lastIndexOf(".");
      if (result == -1) {
        string = fileName;
      else {
        string = fileName.substr(0, result);
      return string;
      function GetSettings() {
      var set = eval(app.extractLabel("Kas_" + gScriptName + gScriptVersion));
      if (set == undefined) {
        set = { selectedPdfPresetIndex : 0 };
      return set;
      Above is the script for indesign which help me to make pdf's of certain folder, but when I run this script it makes new folder and create all pdf's in that... I need a script which creates pdf in same path where its indd file is located... and it should have "_" character before pdf file naming, so it should not be replace with previous one...
