1 Reply Latest reply on Aug 8, 2016 12:05 PM by WolfShade
    RegEx not behaving as expected
    WolfShade Level 4
      Hello, all,
      I think I may have posted regarding this issue, before, but didn't get any response; I (unfortunately) have to try, again.
      I am using a Regular Expression to map the full physical location on the HD of where the website is located.  I need this for a CFFILE tag.
      The reason I'm using a RegEx instead of hard coding the location is because the location varies depending upon whether it is being used in development, staging, or production.  (Yeah, I know.. all three should be mirrors of each other - I'm working on that.  )
      For example, our DEV environment needs the CFFILE tag to point to E:\ColdFusion10\cfusion\wwwroot\www\ folder.
      Our staging environment needs the CFFILE tag to point to C:\ColdFusion10\cfusion\www\ folder.
      Our production environment needs the CFFILE to point to F:\webdocs\cf\www\docs\ folder.
      I really do NOT want to be hackish about this and use a CFIF or CFSWITCH to set the "this.webrootmapping" variable.  Besides, if anything gets changed, I'd have to go in and change the code.  Not ideal.
      So, I'm using a RegEx.  I'm also setting it so that it will always point to the ROOT, no matter what sub-folder the user is in.
      What I have (and isn't working for the production environment) is:
      <cfset this.webrootmapping = REreplaceNoCase(ExpandPath('./'),
                 '(.+[\\|\/]www([\\|\/]docs)?[\\|\/])(.+)',
                 '\1',
                 'all') />
      What this is supposed to do is accept everything up to the "www" folder, or up to "www\docs" folder, and remove everything after that.
      It's working in dev and staging; it is NOT working in production (where the root ends in "\docs\".)  The question mark should be indicating "zero or one of \docs".  But it isn't.
      Any insight greatly appreciated.
      V/r,
      ^_^
        • 1. Re: RegEx not behaving as expected
          WolfShade Level 4
          *headdesk*
          *headdesk*
          *headdesk*
          *headdesk*
          *headdesk*
          *HEADDESK*
          It is starting to slowly kill me, the way I type it all out and then it somehow solves itself.
          *headdesk*
          *headdesk*
          *headdesk*
          I did experiment with something VERY, VERY simple, and it is now resolved.
          *headdesk*
          *headdesk*
          *headdesk*
          I will share it with you, after I'm done banging my head into my desk.
          *headdesk*
          *headdesk*
          *headdesk*
          *headdesk*
          *headdesk*
          *headdesk*
          *headdesk*
          *headdesk*
          *headdesk*
          *headdesk*
          The last '+' (one or more) was replaced with '*' (zero or more), and it worked.  Just in case anyone else runs across this problem and spends weeks or months trying to figure it out.
          *headdesk*
          *headdesk*
          *headdesk*
          I need a nap, now.
          *headdesk*
          *headdesk*
          *headdesk*
          Good night.
          V/r,
          ^_^
          *headdesk*
          *headdesk*
          *headdesk*
