1 Reply Latest reply on Apr 27, 2006 4:50 PM by TimSymons
    New IE activeX issues and FScommand
    dr.Evol Level 1
      Hi!
      Im fixing the new MS IE behaviour about restricting non-MS activeX content. Probbably many of you guys are in the same task these days... Anyway, I followed this article:
      http://www.macromedia.com/devnet/activecontent/articles/devletter.html
      Everything is OK, BUT FScommand capture javascript function is not working anymore when SWF is embeeded via external javascript function...
      Any ideas?
      Thanks...
        • 1. Re: New IE activeX issues and FScommand
          TimSymons Level 1
          I have not had any issues with communicating using the FSCommand once a JS solution was in place. You need to make sure that you do not reference the "id" or "name" of the embedded file before JS has had a chance to create it. I had to make minor adjusts to some of my code to fix this. Also, another very good solution for the IE trouble is the following:
          http://blog.deconcept.com/swfobject/
          This is a very good solution and will work as you expect with the FSCommand.
          Tim
