6 Replies Latest reply on Aug 11, 2016 12:27 PM by RoninEdits
    Help. What's the best drive set up
    Dina Sigma
      Hi, I've been searching for days to understand what drive is suitable for each task.
      I own an iMac 2011 with 12GB RAM and a 500GB (7200 rpm) hard drive and two external hard drives. One of them is HDD 1TB with USB3 interface but my iMac doesn't support USB3 so it has the speed of USB2. The other one is HDD 500GB with Firewire interface.
      I want to color correct a short film, my footage is Apple Prores HQ with data rate around 320 MB/s and the total size is 45 GB. I found this using the Aja Datacalc application. My system is slow for this job so I'm trying to figure out a way to make this happen.
      From what I found on the internet, an SSD drive would make a difference. But I don't know if it'd be better to buy an external SSD with thunderbolt interface or add internally an SSD but also keeping the original hard drive of my iMac.
      But most important of all, I don't know how to use these drives. And I mean basic level.
      Should I for example:
      -add an internal SSD and use it as a boot drive, so it'll run all the programs I guess
      -use the Internal HDD for keeping the media and project files
      -use the External HDD with firewire for cache
      -and the External HDD with USB2 for exports
      Also, what is the minimum size for the SSD in this case? I guess it's 256GB but maybe it needs more space, I dont know.
      Anyone?
        • 1. Re: Help. What's the best drive set up
          Bill Gehrke Most Valuable Participant
          Since you only have USB2 and only Thunderbolt 1 I doubt you find anything that you unit can support that data rate.  But then I a a PC person.
          • 2. Re: Help. What's the best drive set up
            RoninEdits Most Valuable Participant
            the 320 MB/s seems really high. when i use aja data rate calc i have to select 4k @ 60fps to get close to that. if that's what you are using then you may want two ssd's. one for os/apps/cache and a second ssd for project/media. another option is to use the internal 500gb hdd for os/apps and use an external thunderbolt ssd(s) for cache/projects/media. if you are using HD media around 30fps you may be fine using an external firewire hdd or thunderbolt hdd for projects/media. there are also 2-4+ drive bay thunderbolt enclosures that can hold several combinations of ssd's and/or hdd's, including raid configs. it might even be possible to use a thunderbolt ssd as the boot/os/apps drive instead of tearing apart the imac to install an ssd internally. i think that internal 500gb hdd is going to be slow, so it may only work with lower bitrate HD media. thunderbolt 1 is 10gbit/s so it should be able to handle ssd's and fast hdd's, where as the firewire and usb 2.0 can't.
            i don't use mac, so i'm not familiar with your machine and mac os. there are some video's on youtube for upgrading the imac and it looks like it requires alot of work. if you are willing to do that, upgrading to one or two internal ssd's might save some money as external thunderbolt drive enclosures are going to be somewhat expensive. i think i read somewhere only mac ssd's use trim, but owc drives work properly. its something to look into, if you can get any ssd to work properly in the imac the samsung 850 evo's are good drives.
            color grading normally requires fast video cards, so whichever gpu is in that imac you may find the performance somewhat slow and faster storage may have limited impact. even with an i7 cpu in that imac the cpu may also limit performance, as those are much older intel cpu's. if you plan on doing more color grading in the future you may need to look at using a better machine. a windows pc is cheaper and often a better option as the mac's are more difficult to upgrade. sometimes its not possible at all, like the mac video cards. if you don't want to use windows but want something affordable and/or powerful enough to do color grading, you could look into building a hackintosh. also if you are focusing on color grading you may eventually want to look into davinci resolve, its free version may be all you need and is much better than premiere and speedgrade.
            • 3. Re: Help. What's the best drive set up
              Dina Sigma Level 1
              Thank you so much for your help.
              I found the bitrate from VLC, it seemed odd to me too since I shot Full HD at 30 fps. I put it now in Quicktime and it says 185MB/s.
              I know that adding an SSD in iMac is quite difficult but on the other hand an external SSD wih thunderbolt is much more expensive. But if I'm going to use it for OS and software then I guess it'd be better to put it inside.
              So if I'm correct, you suggest that I use the fastest drive for projects and media rather than run the OS and software?
              • 4. Re: Help. What's the best drive set up
                sometimes the projects/media drive is the fastest drive and sometimes its the slowest drive. it depends on budget and project needs. by "full hd" i take it you have 1080p media, which should be ok on a medium to fast hdd and firewire. so you could try using the drives you have now and try the cache on the firewire or internal hdd. once you start color grading chances are very good that the video card will bottleneck the system and drive performance won't matter.
                if you do decide to get a ssd, a single 500gb+ ssd may be fast enough for os/apps/cache and some media types as well. a single fast ssd may outpace all of your existing drives combined. some of the thunderbolt enclosures start around $100 for a single 2.5"/ssd case and around $150-$200 for one with a ssd included. empty multi-bay drive enclosures jump up to $300-400+. thunderbolt 1 is 10 gbit/s where as that imac internal sata connector is either 6 or 3 gbit/s. so you want to do some internet research on booting from thunderbolt and thunderbolt ssd performance with similar imac's, to see if the cost of an enclosure is worth using vs the trouble of installing a ssd internally.
                • 5. Re: Help. What's the best drive set up
                  Dina Sigma Level 1
                  Ok, so from what you say I understand that it's not necessary to have an SSD which is fine because it means less money for me. I also understand that the most important factor is the GPU which is slow on my system. I just wanted to be able to color correct and not grade my footage. So far my system lags after a while and I thought the SSD could solve that. I'll test using the firewire HDD for the cache.
                  Generally speaking is it preferable to have the faster drive for media/project or previews/cache/exports?
                  • 6. Re: Help. What's the best drive set up
                    if you stick with some of the non lumetri color fx, your gpu may handle a little bit of color correction. lumetri is from speedgrade and is used to powerful gpu's. you say the system lags after a while, if that is on returning to the same project that you have already been working on you might want to check memory usage to see if the 12gb of ram is being used up. if it works fine with a new project with this footage and then lags after you add color fx, it might be the gpu slowing it down with the color fx. there are supposedly utilities you can use on the mac to check cpu, ram, and even gpu usage to help identify bottlenecks...
                    for media, previews, and exports the drives just have to be fast enough for their purpose with the codecs being used. if you have a fast media drive but are constantly rendering previews to a slow drive, it may be counter productive. if the media drive is slow and the preview drive is fast but you don't render previews very often it may also be counter productive. its preferable to have a ssd drive for numerous small files, like the os/apps/cache files, as hdd's do not handle lots of small files well.
